Joined Apr 2008
"Tower Club" is a good idea if you buy much from them. You can sometimes catch membership special for $9.95. Gives you better discounts as well as free shipping on orders of $150 or more. BTW- until Wed they are offering free shipping on $100 or more to everyone. Also, current price on RX ready from Tower is $139.99 - flyer does not reflect the new price but website does.
Now would be a good time to pick up one from Tower - $120 shipped with club discount. Another $5 off if you increase original order to $150. Wings can be a little difficult to install - especially at first. Try reaching into the fuse and pushing up on the retainer area while installing plastic rod. I had to work with mine a few minutes at first but after first time, it goes together fairly easily. |
Western Nebraska
Joined Aug 2010
My apologies if I'm in the wrong forum. Just say so and give me a pointer if that is the case. This is my first post here.
Having been interested in RC flying since before they existed, I was thrilled when I won the 182 Skylane at a recent RC event. I wanted to be very careful and not fly it until I had someone else test fly it and talk me through things. My work schedule has had me extremely busy since I won it, but I have had it out in the driveway a couple of times taxiing and trying to get used to the controller. While I do have a SEL/MEL & Commercial ticket, I haven't flown for decades, and never an RC. I wanted to get used to using the left stick for rudder control and throttle. Steering on the ground with the left stick comes unnaturally for me, especially since I have years of flight sim experience with a single stick in the right hand. The controls seem a little touchy, but that's probably just my lack of experience with it. Now the problem. While taxiiing the last time out, I managed to run the nose into a brick. Actually, the contact point was the front gear, not the actual nose. But, the prop was turning at a pretty low power setting. The prop caught on the top of the same brick, stopping it. I killed the throttle immediately upon contact. Out of this incident, I have two problems. First, the nose wheel and the rudder no longer match up. Second, the motor itself vibrates. The rudder/nose wheel alignment I am assuming comes from a slipped wire going to the servo, since that servo arm drives both wires. I detect a slight bend in the wire going to the nose wheel. Can anyone confirm whether it should be there, or is that part of the accident? The bend is right at the front of the bottom hatch, and not nearly enough to cause the offset I see in the wheel. There appears to be no problem with the wish bone suspension, and the shaft the gear is mounted on is not bent. How can I get access to the servo screws that clamp the control wires? Taking this thing apart is a bit of a mystery. The nose cone and prop were loose after the impact. I removed both and the shaft is not bend. They both reinstall straight and tight. I'm not sure, but it looks like there is a little more gap between the back spacer and the nose, but I don't remember exactly what that gap was before it happened. The proble now is, both with and without the prop, there is a vibration in the motor when it runs. It appears to turn just as freely as it did before the incident, but under power vibrates badly. There is no binding. I'm wondering if something in the ESC might be bad, or did I screw the motor? Ideas? I've removed the nose cone, and that wasn't nearly as easy as the manual led me to believe it would be. They say to cut the decals and slip it off. No way. It was stuck on there with something, possibly glue. I'm just sick that this happened to the plane before I ever got to fly it, something I've wanted to do nine tenths of my life or more! I want to repair it and get on with it. |
Joined Apr 2008
There is a much more active discussion of this plane in the thread shown below. The issue with the nose wheel rotating was addressed somewhere near the middle of the thread. I haven't had a problem with it and I'm not sure exactly what needs to be done to yours.
http://www.rcgroups.com/forums/showthread.php?t=945874 If the motor is vibrating badly with no prop or spinner installed, it most likely has a bent shaft. The bend can occur near the rear of the shaft and not be immediately apparent. Replacement motors are available from several sources and are not very expensive. These are also discussed in the above mentioned thread. Don't get discouraged! You can repair the plane. The learning process results in lots of similar mishaps and you will soon learn how to overcome them. If you don't like the idea of learning by trial-and-error, you should consider the purchase of a simulator. Basic orientation and control skills can be built this way and it is fairly easy to transition to real flight with minimal plane damage. |
Joined Apr 2008
Humm. Don't understand the motor issue, then. Is the motor bell running true? No wobble? Are the grub screws on the bell tight against the shaft? Maybe a magnet was knocked loose and is causing the imbalance.
You are right about the cowl. It's secured with some sort of rubber or silicone cement that requires a good deal of coaxing to remove. |
Joined Oct 2009
Hi absolutenewbie
Cessna 182 was my first plane. After the first flight my trainer detect a problem with the motor mount. This mount is made with plastic and in my case was broken. You need to remove the cowl and after this check you can glue with light glue (liquid silicone) not CA Foam Safe. We build a new mount using a piece of aluminium and plywood. The second change was a reinforce the back support of the nose gear with plywood too because after a hard landing it moves. The nose gear is not hard enough you must take care of this. Good flights |
Western Nebraska
Joined Aug 2010
Sorry, guys. I haven't been back here since the other link was posted. I believe in reading the archives, and have been doing that when I have time, a few pages a night. I've learned lots over there, but still have about 300 posts to go to get to the end of it (1800 plus).
I was able to get some ideas as soon as I started reading that thread and fixed the misalignment with no problem. Glad I did, because the person who put this thing together didn't get everything tight. It was slippage in the servero linkage that caused the nose wheel to be misaligned on such a gentle hit. The motor vibration never did get resolved completely, but I was able to get it down to a pretty decent level and wasn't afraid to fly it. By the way, removing the shaft from this motor was an absolute PIA. With both screws removed, and putting it on a homebrew jig to hold the bell, I couldn't knock the shaft loose. I finally got it out by using circuit cooler on it several times to shrink the metal. I still had to use a real hammer on it to get it to budge and drove it out with another rod when it got into the bell. It was very tight. It went back in the same way. If all of the new motors are this way, they won't be very repairable. Removing the shaft and rolling it on a hard table showed no problem anyway. I got the nerve up and did a maiden flight last night. I was more scared during that than when my instructor jumped out in the middle of the runway and told me to take it around once on my first solo in a real plane. I just didn't handle the RC version very well at all. First flight - landed safely. Second - not so much. More repairs. I'm wondering if I should go back to just watching , instead of flying . A new motor should be here in a few days anyway, and I might just need it. She's vibrating again, and has a visible wobble. The nose gear really took it in the shorts this time. Not sure what I'll do about that. May just "freeze" it. I think there is a CG problem with this one. I checked it, but by the way it flew, I think it may be way heavy in the tail. I'm going to lean to the nose next time. I also don't like the way the battery isn't gripped tightly. It doesn't move much, but the battery and the hole don't match shape, so there is some possibility for side to side movement, even with the velcro strap in place. To be continued... |
Congrats on the successful maiden! For a very first RC attempt, that is definitely an achievement! There's an old saying here - `a nose-heavy model flies poorly, but a tail-heavy model flies once', so you did well if the CG was aft where it should be (for first flights, error on the nose heavy side...). Also, double check the motor thrust angle, as it can cause similar problems.
Any video or photos of the historic maiden? ~R |
I got it in 4 days from http://secure.hobbyzone.com/greatpla.../hcaa2525.html
Simply awesome! (great price too, when you go to checkout is only 129 shipped) I had it ready in couple of hours. Next morning: fri was the maiden. Plane flew just great. This is my second cessna. First was smaller one SkyArTec from Hobby King about week ago. What a difference! I will fly them both, but I can tel,l I will go out of my way to fly Flyzone one. It looks like the real thing. Handles good too. I didn't figure how much time I get out of my turnigy 2200mAh, but it looks like at least 15-20 minutes. Takes a little to get used to taxiing. I have to take a look at the front steering setup. Should be able to make it less touchy I know I should read all the posts. Somebody probably already figure it out. At first I had the lights on, but I couldn't even tell they were on. They might become handy flying when is a little darker. I'll try them then. My came with 1400kv and 25A speed control. I added BEC and rx. I tried, but didn't use the flaps for landing. Thats next. Too bad, I am on business trip for next couple of weeks. Rob |
Joined Apr 2008
I've gotten over 45 flights on mine and I'm liking it more and more.
The nice thing about the flaps is that they are totally optional. If you want to fly it 4 channel, it has no problem with that. Simply requires a shallower approach and lands just a little faster. Flaps add realism and allow steeper approach but, either way, the plane behaves nicely. I would suggest to anyone who wants a little more power - try a GWS 9x5 DD prop. This draws about 15% more power and results in noticably improved performance. I've had one on mine for over 30 flights with no problems overheating the motor or ESC. Newbie: Place a piece of velcro on the floor of the battery compartment and one on the bottom of the battery to secure it. The velcro strap in not sufficient to retain the battery. I use it only for backup. This Cessna looks so realistic in the air it's easy to believe you're seeing the real thing from a distance. |
Joined Jul 2009
I had a similar problem with attaching the wing...
Also be sure to check the clip that holds the tail on after each flight to be sure it doesn't work loose. I found that the clip had partially worked loose after my second flight. I used some double-sided clear tape positioned inside the clip to make it grip more tightly. I will let you know how this fix works. If the tape fails, I will likely Gorilla glue the tail posts into the fuselage to ensure that the tail doesn't loosen up again. |
| Thread Tools | |
| New Product Hobbico® FlyZone Cessna 182 Skylane RTF | dnorm | Electric Plane Talk | 244 | Sep 14, 2010 03:06 PM |
| Discussion Flyzone Cessna 182 Skylane - Odd engine noise, just bought today | Overspeed | Micro RTF | 12 | Feb 20, 2009 08:20 PM |
| Sold Hobbico FlyZone Cessna 182 Skylane 4 Channel- RTF | rcfunhouse | Aircraft - Electric - Airplanes (FS/W) | 2 | Mar 25, 2008 10:44 AM |
| For Sale Cessna 182 Skylane - RTF $150 = | Dick07 | Aircraft - Fuel - Airplanes (FS/W) | 0 | Nov 28, 2005 04:44 PM |
