Old Aug 29, 2011, 08:58 PM
fuzzyhead is online now
Find More Posts by fuzzyhead
Old F-4 Crewchief
fuzzyhead's Avatar
Schertz, Texas, United States
Joined May 2004
Anybody swapped out the wheels yet? The stock tires are too hard. Even with a decent landing the shock will often move the steering wire throwing the nose wheel off center. Have to pull the wing off to realign it at the servo attach point. Starting to get a rattle from the wheel pants as well. All is tight. Considering just pulling the wheel pants off then if need be go to a slightly larger and softer tire.
fuzzyhead is online now Find More Posts by fuzzyhead
Old Aug 29, 2011, 10:45 PM
viper69 is offline
Find More Posts by viper69
Cheaper than botox
viper69's Avatar
Escondido California
Joined Oct 2006
I have the stock wheels with over 100 landings on them. They are very hard and mine are almost worn off completely. I guess I am agreeing with you, that is it getting to be that time. New tires sometime soon.
My LED on the tail is somewhat burried in the tail since I made my last inverted touch and go on a Camp Pendleton helicopter Landing Zone, LZ53. Still loving this plane, especially with the 480 up front. It is a rocket, but still slows to a crawl for landings.
Someone mentioned that it tip stalls if you get it too slow. That is a correct statement. It will, so you have to watch it and be ready to punch the throttle if it begins to dip a wing. After a bit you will be able to tell about how far you have pushed the limit.
My biggest issue so far is the nose wheel steering. I broke the arm some time ago, and have since rigged it but if I land hard the wheel will flip past 90 degrees and lock. My fault totally, but it is annoying.
viper69 is offline Find More Posts by viper69
Old Aug 30, 2011, 08:49 AM
eaglescry24 is offline
Find More Posts by eaglescry24
Flying the Spyder
eaglescry24's Avatar
United States, PA, Parkesburg
Joined Mar 2008
I have a new vid and will post soon after loading on yt. I have experienced a spin stall with this to the ground. Mind your airspeed (have vid of that too). The landing gear... I needed something more. I beefed her right up and made her a tail dragger. Talk about a rigid plane now...
eaglescry24 is offline Find More Posts by eaglescry24
Old Aug 30, 2011, 05:03 PM
Old F-4 Crewchief
fuzzyhead's Avatar
Joined May 2004
Would like to see the tail dragger. May be my direction as well. What size wheels/tires did you use and from which vendor?
Old Aug 31, 2011, 01:41 PM
Flying the Spyder
Joined Mar 2008
here are some pics of tg conv
Old Aug 31, 2011, 01:47 PM
Flying the Spyder
Joined Mar 2008
I dont rember the vendor nor the size, I found em in my stock and i thought theyd work... and they do. I will take better pics at a later time or you could email me. Its much eaiser to show pics there... i have iphone so id have to dig out the pc to upload on here as i have. this plane has been crashed a few times. I scrapped the wheel pants all together.
Old Aug 31, 2011, 06:39 PM
Old F-4 Crewchief
fuzzyhead's Avatar
Joined May 2004
Not sure if I want to go that in depth yet. First I'll try slightly larger and softer tires. Would like to retain the scale look of wheel pants but that ain't gonna happen if I increase tire size. Got a new Mustang due in tomorrow so I'll play with this one as time permits. Will pass on my results.
Old Sep 01, 2011, 09:10 AM
Flying the Spyder
Joined Mar 2008
Cessna 182 Select Scale (no place to land).wmv (4 min 1 sec)
ran out of power, alt, time and airspeed. bad combo. seems i get all the bad landings on tape.
Old Sep 02, 2011, 11:39 AM
JIMBOJONES is offline
Find More Posts by JIMBOJONES
JIMBOJONES's Avatar
United States, IN, Milan
Joined Feb 2009
they look like dubro 1.45" microlite wheels could be 1.86" as well
JIMBOJONES is offline Find More Posts by JIMBOJONES
Old Sep 02, 2011, 07:25 PM
Flying the Spyder
Joined Mar 2008
I think the bigger ones, closer to the 2" mark. I am going to try some dubro softies pretty soon it may help absorb the rocks.
Old Sep 06, 2011, 09:11 AM
Flying the Spyder
Joined Mar 2008
http://www.rcgroups.com/forums/showthread.php?t=1501360
Here is a link to my gs. I have some cessna parts on the first pic I believe.
Old Sep 17, 2011, 06:17 PM
Old F-4 Crewchief
fuzzyhead's Avatar
Joined May 2004
Been thinking about adding some color for better visibilty. This is the result. Haven't flown her with the new top coat.
Old Sep 17, 2011, 08:05 PM
viper69 is offline
Cheaper than botox
viper69's Avatar
Joined Oct 2006
Wow that looks fantastic! I love it.
Retired as a Master Sergeant eh? Nicely done!
Old Sep 17, 2011, 08:33 PM
f1wanabe is offline
Find More Posts by f1wanabe
f1wanabe's Avatar
United States, PA, Easton
Joined Dec 2010
This was my second plane and still one of my favorites. I hadn't flown it for a year so i took it out a couple weeks ago. Had a surprise at the end of the flight!
Flyzone Select Cessna 182 Skylane with surprise visitor! (3 min 32 sec)
f1wanabe is offline Find More Posts by f1wanabe
Old Sep 17, 2011, 08:42 PM
Old F-4 Crewchief
fuzzyhead's Avatar
Joined May 2004
What gave it away? Crewchief for every bit of it. Notice a lot of F-4's on the wall?
New Product Hobbico® FlyZone Cessna 182 Skylane RTF dnorm Electric Plane Talk 251 Jul 20, 2014 11:37 AM
Discussion Flyzone Cessna 182 Skylane - Odd engine noise, just bought today Overspeed Micro Ready-to-Fly 12 Feb 20, 2009 08:20 PM
Sold Hobbico FlyZone Cessna 182 Skylane 4 Channel- RTF rcfunhouse Aircraft - Electric - Airplanes (FS/W) 2 Mar 25, 2008 10:44 AM
For Sale Cessna 182 Skylane - RTF $150 = Dick07 Aircraft - Fuel - Airplanes (FS/W) 0 Nov 28, 2005 04:44 PM
