Old Nov 04, 2008, 06:59 PM
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Video
Prop in slot noise test
Here is a video of a small test for the FireFly which was done to see if I could improve the noise generated by the "prop in slot".
There are 3 clips: 1) As built, 2) tapered forward edge 3) and curvy glade propeller.
See if you can hear a difference.
Thread on the FireFly: http://www.rcgroups.com/forums/showthread.php?t=943610
Update Nov 06, 08. Second video added comparing straight slot to dogbone slot.
leadfeather is online now Find More Posts by leadfeather
Old Nov 04, 2008, 07:13 PM
DaOldGuy is offline
Find More Posts by DaOldGuy
Flying Half Pound and Down
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
With head phones, Test 3 had a deeper tone and a little less volume, I would say. Seems like test 2 started out quiet to start, but 2 didn't jump to full throttle as fast as 1.
DaOldGuy is offline Find More Posts by DaOldGuy
Old Nov 06, 2008, 08:14 AM
Winging it >
Joined May 2006
A second test was done to compare slot shapes. The video was added to the first post.
Old Nov 07, 2008, 05:35 PM
Frankenator is offline
Find More Posts by Frankenator
Canton, Michigan, United States
Joined Nov 2000
Prop Distance
IMHO, I think that the dogbone, in your testing, was probably the quietest.
FWIW, I had wondered a while back, during the "Zagi Craze", about prop noise. I wondered why a gunther prop made so much noise on my Zagi in pusher configuration, but was very quiet in tractor mode on my Tumblewatt. My conclusion was that the proximity of anything close to the spinning prop is what caused noise. The Zagi was noisey because the prop was so close to the trailing edge of the model!
Try this! Take a motor with a spinning prop (on or off a model) and while holding it in your hand, move an object slowly as close to the prop as you can. By the time you get within a half inch, you will start to hear noise.
Unfortunately, for your mid-mounted prop your only choice is to make a bigger gap in front of and behind the prop.
Frankenator is offline Find More Posts by Frankenator
Old Nov 07, 2008, 05:51 PM
macboffin is offline
Find More Posts by macboffin
North London ENGLAND
Joined Dec 2006
Hi Leadfeather.Interested in the pic of the foreplane delta with tiger stripes. Made a slimer powered plane like that a few years back in Canada. Flew well once CG sorted,(started out a bit nose heavy).
macboffin is offline Find More Posts by macboffin
Old Nov 07, 2008, 06:41 PM
Winging it >
Joined May 2006
Hi Macboffin,
It is a VTOL tail sitter jet called the LevJet
Hovers, VTOL's and flies great.
Discussion Slot design for "prop in slot" leadfeather Foamies (Scratchbuilt) 32 Oct 17, 2008 09:45 PM
Discussion Plan for "Prop in a slot" profile Epp jet model ? dekan Pusher Prop Jet Models 0 Jul 11, 2007 01:36 PM
modify GWS prop in folding prop?? maulionc Scratchbuilt Indoor and Micro Models 3 Oct 24, 2002 12:26 PM
First Crazy Max flight, lost prop in flight 10Thumbs Foamies (Kits) 7 Aug 12, 2002 05:44 AM
Sailors Sprayed With Nerve Gas in Cold War Test, Pentagon Says Gman2 Life, The Universe, and Politics 2 May 24, 2002 07:22 PM
