| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
Erik with a K
HURRY! TVC's 50" F4U WORKSHOP: Starts Nov 20!
[EDIT] 10/13/2009 Looking to do a group build of this model.
We have the following members who are going to participate: RogueTitan Derek_S prunner riivopii I would like to add a few more names to this list, why not yours? ![]() Parts list as follows... Standard Equipment:
Total all up weight will be targeted for no more then 1100g (40 Oz). This post will be update as more information is available. Projected finsih date will be late 01/2010 Origianl PDF Files available! Check Serban's post here vector based PDFs (out of date 11/24/08, Note: Model flies but wing incidence is too steep (~3.5 degrees too steep). Updated PDF Files here: http://www.rcgroups.com/forums/showp...&postcount=187 PDFs to update your original plans http://www.rcgroups.com/forums/showp...&postcount=188 Updated ver 7 SKP file found here: http://www.rcgroups.com/forums/showp...&postcount=128 Videos here: Vid #1 Vid #2 video on page 10 .... Stared modeling a 50 inch F4U today. Here's what I got so far, step by step. Hope to get a lot of this done this week, if I can manage to get the mess in the garage somewhat together. Again, all based on making the model as simple as possible. I got the plan view from http://www.voughtaircraft.com/ Converted it to a png (from GIF) and just started working. The first step was to make the formers... Last edited by tvcasualty; Nov 10, 2009 at 09:05 PM. |
#2 |
Mi-e dor de Retezat
tv,
Curious people are waiting to see how you'll get around the wings Can the phlatprinter carve it from solid foam?Serban |
#3 | |
So much Foam..but no time
The best way to do this is to build it like a wooden built up wing. Ribs, spars, stringers and sheeting. All but the spars should be foam. They will most likely be CF. |
#4 |
Erik with a K
Well to tell the truth I'm gonna break some new ground on the wings here.
I'd normally just run 3 profiles of the airfoil and hot wire them out in 4 parts. but.... I got this expensive printer just collecting dust right now so I'm gonna give it my best shot on unfolding these beasts!! This took an exceptional amount of work to get the wings to this point, and it's still going to be VERY rough getting them to come out right. And I still feel these is a lot more to do. |
#5 |
So you are going for the full ribs, spars, and sheeting then? Should work great! Nice work too by the way.
How did you get the nice airfoil? Did you draw it by hand? I can't get the oval to push or pul the way I want so I have to get the LE and apex then draw lines between them and delete the intersects. |
#6 |
Erik with a K
thewz, yeah, the plan view has 3 airfoils, I assume root, mid, and tip. Otherwise I would-a guessed.
There are all kinds of tricks to get the software to do what you want, construction lines are a good way to do it. But I try not to use the arc / circle command unless it specifically has a good (conservative) use. A few more modeling pictures... and then some take about the wing... So what I've done is created formers the same way I make the fuses. But instead of ending the section at each former I created tabs for the wing. The idea being I can locate the profile in the wing. Printed out a starboard wing and just finished rolling it together... There are a few small issues. Number one, I still didn't manage to get my zero down on the phlatprinter (PHP) so my fold lines were not defines as nicely as I wanted them. This left the largest bend very difficult to manage. A few more fold lines certainly would help out. Number two I think the 3/16 offset might be a little bit much in this case as the profiles do not site square to the surfaces (by accidental design). I think 1/8 or 5/32 might have worked better. Number three, the ailerons and flaps need more work. They are impossible to fold as intended. That being said, these is a whole lot right about this wing. It's very light, and yet fairly strong, I feel I could get away without fiberglassing the bottom. Also the angles all look to be correct! But I have yet to see how the port wing turn out in comparison. [edit] oops can't get UBS drive to load pic of the wing! Last edited by tvcasualty; Nov 04, 2008 at 12:56 AM. |
#7 |
Mi-e dor de Retezat
pictures, pictures, we want pictures (of the phlatprinted wing)!
#8 |
Erik with a K
Woot! Got my SD to work!
Here's three pics of the wing. Looks pretty good, I circled in red one possible problem area, as I want both wings to be symmetrical |
#9 |
Erik with a K
Here's a huge picture of the complete (w/ out control surfaces) wing. The port wing, (one on the right of the pic) was cut second on the PHP, and the bend line was much better since the zero worked this time... If you look closely you can see the leading edge (LE) is more crisp and looks neater. The port wing tip also sits about 1/8-1/4 inch higher then the starboard, I should be able to bend that correct.
#10 |
Awesome work - subscribed.
KW |
#11 |
tvc...
Watching your build with interest. I've scratch built two corsairs (37" span) and find that the stab needs some +degrees incidence too. Considerable down trim needed otherwise. |
#12 | |
Erik with a K
These flaps have been kicking my butt for the past hour, I'm about ready to re-print the wings, as it would save me a servo anyhow. Once I get the plans up for those who really dont want flaps I would unfold the entire wing, it would make things so much easier... |
#13 |
Mi-e dor de Retezat
tv,
was the wing scored and cut using the phlatprinter? |
#14 |
Electrical burning stench....
Dang another great build! nice job! looking great!
by the way have you ever used the Soapbox form curves tool? makes really nice curvy surfaces but only problem is unfolding. |
#15 |
Erik with a K
Serban, yes it was! Here is a pic of what it looks like unfolded...
GreenAce, Thanks man! I've used a spline tool before which works really well for shaping those parts that do not need unfolded, but for things that need to unroll, well simple is best, and sometimes they still break... Amazingly, these wings unfolded easier then the fuse! BTW I just decided that the flaps were not worth the effort. So I'm gonna unfold another set and make another wing, this will give a good idea on the repeatability anyhow as well. |
| Thread Tools | |
| Build Log Scratch Built Foam F4U Corsair | thedave172 | Foamies (Scratchbuilt) | 28 | Aug 11, 2009 04:04 PM |
| Build Log Scratch Built Foam F4U Corsair | thedave172 | Electric Plane Talk | 5 | Jan 01, 2007 12:23 PM |
| F4U corsair foam | Sunspot | Foamies (Kits) | 1 | Jan 04, 2004 04:31 PM |
| Foam wing repair for GWS F4U Corsair | Stenchy | Foamies (Kits) | 4 | Dec 26, 2003 10:35 PM |
| Good Foam F4U Corsair?? | mpj220 | Foamies (Kits) | 10 | Oct 18, 2001 10:35 AM |
