Old Nov 02, 2008, 06:11 PM
kevin is offline
Find More Posts by kevin
kevin's Avatar
United States, OH, Grove City
Joined Aug 1999
Jet Hangar A4 / dynamax conversion.
My buddy Paul showed up at the field today with his new dynamax / scorpion /12cell conversion installed into his JHH A4.
I had previously flown the plane with the glow fan and Paul gave me the honors on the conversion today. rtf weight on the electric version is 13lbs if i remember correctly.
In a word...Awesome...It like an entirely new plane. MUCH more vertical and speed.
Here are a few pics that i said i would post for him (no video )
hopefully he will jump in with the particulars on how he did the conversion.
After having flown this i can see the e-dynamax showing up in more than a few scale birds.
kevin is offline Find More Posts by kevin
Latest blog entry: Video of my HK Cobra
Old Nov 02, 2008, 06:20 PM
Sean Sweeney is offline
Find More Posts by Sean Sweeney
Sean Sweeney's Avatar
Kissimmee, FL
Joined Mar 2001
Was that flown with out inlet ducting, or an inlet lip?
Sean
Sean Sweeney is offline Find More Posts by Sean Sweeney
Old Nov 02, 2008, 06:30 PM
E-FlyGuy is offline
Find More Posts by E-FlyGuy
Joined May 2005
No intake lip, no ducting.
I was impressed.
Very nice sound, very quiet.
E-FlyGuy is offline Find More Posts by E-FlyGuy
Old Nov 02, 2008, 06:54 PM
kevin is offline
kevin's Avatar
Joined Aug 1999
flown the way it is shown in the pics. it goes against conventional wisdom, but works well.
Old Nov 02, 2008, 07:35 PM
k_sonn is offline
Find More Posts by k_sonn
k_sonn's Avatar
Bellevue, WA
Joined Feb 2004
Wow Kev, that's pretty cool. Tell Paul congrats for me.
Did you get any numbers? What scorpion motor and how was it mounted? Any info would be awesome.
Kirk
k_sonn is offline Find More Posts by k_sonn
Old Nov 03, 2008, 08:10 AM
eazyp2 is offline
Find More Posts by eazyp2
United States, OH, Columbus
Joined Oct 2007
Hi guys its me Paul,this is what I did to make the conversion. first I started with the byron fan adapter,yes the byron fan adapter will fit,you must hone out the dynamax center,also cut the IC engine mount off, then I chose to use the scorpion 4035-630 with replacment 8mm shaft, then last but not least called up fred baldwin and purchased a 8mm collect,roter and spinner,I have to tell you his collect is bullet proof. to get all this to work all you have to do is drill and tap the byron adapter where the stater bolts are located,with I think 16 staters theres no way this things coming loose.I only use 8 bolts for this conversion. will post some pics of how it all is done this evening after work as they are on another cpu. kevin thanks for all the help.
eazyp2 is offline Find More Posts by eazyp2
Old Nov 03, 2008, 08:13 AM
eazyp2 is offline
Joined Oct 2007
Thanks K sonn hope to see you again soon.
Old Nov 03, 2008, 08:16 AM
Whistling Watts is offline
Find More Posts by Whistling Watts
Braintree, Essex
Joined Mar 2006
Brilliant!
Very Well done, lets see some video if you can.
Steve
Whistling Watts is offline Find More Posts by Whistling Watts
Old Nov 03, 2008, 08:28 AM
eazyp2 is offline
Joined Oct 2007
oh yeah you guys might wanna know this stuff. hv110, 90amps 3600 watts those are the numbers, they didnt change with the tale pipe added,I know it just stayed the same outlit diameter is right around 3 1/2 inches.
Old Nov 03, 2008, 01:05 PM
bladexz2 is offline
Find More Posts by bladexz2
BladeRunner
Indianapolis, indiana
Joined Dec 2007
Dyn-E-Max /Scorpion
Hi Paul,
I know we talked last night, but I also wanted to congratulate you on a will earn effort. If I can be of any additional help, don't hesitate to call.
Fred / 1-317-293-6449
bladexz2 is offline Find More Posts by bladexz2
Old Nov 03, 2008, 01:42 PM
bigjohn is offline
Find More Posts by bigjohn
dare to be dull
bigjohn's Avatar
Deland, FL
Joined Jun 2002
Yes, we need some details on this! I have a few planes that could benefit.
I have more Ramtech fans than Dynamax sitting around. I would think this would work just as well for a Ram-tech. What do y'all think?
bigjohn is offline Find More Posts by bigjohn
Old Nov 03, 2008, 02:09 PM
Kissimmee, FL
Joined Mar 2001
Yes, please post the details of how you did this conversion! I have a YA F-16a that had a Dynamax fan in it. I was going with a DS fan, but this sounds like an easier way to go.
Sean
Old Nov 03, 2008, 08:27 PM
racer1 is offline
Find More Posts by racer1
5kW Club
racer1's Avatar
United States, AZ, Tucson
Joined Feb 2007
During my testing of fans and deciding to convert my Dynamax, the Ramtech has a much more agressively pitch blade. The amp draw was quite a bit more with less static thrust than the Dynamax. It may perform differently in the air. It is a future build for me since I have had great preformace out of the Dynamax.
Originally Posted by Whistling Watts
Just got sight of the video posted of Clay Sherrows Scorpian outrunner equipped Dynamax Falcon 120.
See what I mean about how quiet this fan is and this is hanging in the open air, imagine how it would sound in ducting!
I will let someone else post the details of setup later on if they wish (come on Clay/Darren dont be shy).
http://www.rcgroups.com/forums/showt...6#post10818887
This is very nice, my sort of model (I wonder why!).
Thanks Clay
racer1 is offline Find More Posts by racer1
Old Nov 03, 2008, 09:19 PM
eazyp2 is offline
Joined Oct 2007
Ok guys heres a couple pics to show how the byron adapter does the trick. guys I personally have a good feeling about this dynamax fan unit being converted,I will tell you why,im no big specialist on thrust and eflux, but what I can tell you is that there was a apples to orange comparison in performace in the way the plane flies,this plane is well battle tested many of flights on glow and almost all of them sucked. I have had this plane for over 10 years and never had any plans on any kind of upgrades, but I can tell you with this new power system, she will get a full overhaul this winter. also for all those guys out there with planes that have been sitting in the basement long forgottin about. I think Im about $700.00 dollars into this conversion, batteries an all. anybody have any questions I will do my best to answer them. thanks
Old Nov 03, 2008, 09:44 PM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
How much did you open up the mount to allow the Byron adapter to fit?
Bob
bruff is online now Find More Posts by bruff
Hangar 9 Aresti conversion to electric rrickp43 Sport Planes 18 Jun 08, 2004 11:16 PM
Jet hangar Hobbies captinnitro Electric Ducted Fan Jet Talk 16 Mar 13, 2004 02:26 PM
Jet Hangar Bae Hawk GlasairAllen Fuel Jet Talk 14 Nov 20, 2002 06:25 PM
Hobby Hangar SU-26 Conversion PanzyPoof Sport Planes 1 Aug 01, 2002 12:27 PM
Jet Hangar Hobbies GlasairAllen Fuel Jet Talk 11 Apr 09, 2002 10:08 PM
