Old Feb 26, 2009, 09:29 PM
BadClams is offline
Find More Posts by BadClams
United States, LA, Bossier City
Joined Aug 2008
Thanks gents...
BadClams is offline Find More Posts by BadClams
Old Feb 27, 2009, 07:31 AM
big-john-52 is offline
Find More Posts by big-john-52
big-john-52
big-john-52's Avatar
Tyler Texas
Joined Feb 2005
The wind has been 20 to 30 mph for 4 days now and today was going to be 5 to 10
for a change..... but guess what ....I get up this morning and they or calling for
thunder storms all day long %$#$%$$##@@#$$% well maby it will stop raining this
afternoon I can only hope.
John
big-john-52 is offline Find More Posts by big-john-52
Old Feb 27, 2009, 07:40 AM
BadClams is offline
Joined Aug 2008
John
That's the rule you know....just like getting a telescope guarantees cloudy nights for about a month...
Old Feb 27, 2009, 04:58 PM
big-john-52
Tyler Texas
Joined Feb 2005
The sun came out at 3:00 today and I was at the field at 3:30 but the wind
was still up Around 18 to 20 mph but I was there........ And it may be weeks
till I can get back out There.......lol (at least that is what I told my self) any
way I got a friend to tosss the AMX For me and the clime out was fine but
way touchy on ailerons at low rates and the AMX Did not like the high winds
at all. Turns were way scary it was very cloudy and the dark
Color on the nose made it hard to see, for my old eyes any way.
Oh yea the mystery bumps must go where I put them because after a long
skid there was no sign of any damage at all on the bottom of the jet just
some grass stains on two of the bumps.
Going to try on a calm day next time
John
Old Feb 27, 2009, 09:23 PM
BadClams is offline
Joined Aug 2008
congrats John!
Might you divulge what you have your throws set at and what holes you've set your control arms into? (Same goes for you, Jon!!! Whattcha using??) I'm about half-way built after taping the belly, leading edges of the wings and horizontals and installing carbon rods a-la Jon's review. Also "secured" the ESC and Elevator wires with velcro/tape. I plan to use some SAPAC F-16 belly pans to protect things further.
I CAN CONFIRM THAT THE FOAM BULDGES ARE TO PROTECT THE BELLY. (I emailed Jalin...) I just don't think foam bubbles will last long or help much in the long run.
I'm seriously considering running an elevon setup so as to dedicate the wing surfaces to flaps-only duty.
I haven't carved out any foam to make room for a bigger batt yet...but I will eventually (probably after maiden).
J-Power needs to use slightly bigger shipping boxes to afford more room between the sidewalls and the model as the nose and tail have some slight crush damage on them.
After a brief test, motor sounds good and servos seem happy.
Old Feb 28, 2009, 08:18 AM
big-john-52
Tyler Texas
Joined Feb 2005
I set up throws as per instructions low rates at about 1/8 in but I never
Went to low rates, control rods were in the second from the top hole.
This plane slows down so well that I see no need to add flaps, just cut
Power and drop down to about one foot off the deck and raze the nose she
Will just flop to the ground with a slight skid to a stop.
I was a little unhappy with the speed though, my phase 3 f-16 is much faster.
So I may be looking for some hop ups any suggestions motor and fan or just
motor?
Old Feb 28, 2009, 08:54 AM
invertman is offline
Find More Posts by invertman
fly it like you stole it
near Springfield Il
Joined Apr 2003
I just started working on the airframe only kit and have one question as it came with no instructions. What is the recommended CG? I'm using Don's motor and Alfa EDF out of a crashed F-16. It looks like the nose cone from the F 16 is a perfect fit. It may help with not so perfect landings. I may WBPU and glass the belly also.
invertman is offline Find More Posts by invertman
Old Feb 28, 2009, 08:58 AM
Bajora is online now
Find More Posts by Bajora
AA6JB
Bajora's Avatar
Joined Sep 2004
Jason of Hobby Lobby asked me to remind you guys that when you feel the need for MORE speed on these birds, they have everything you need:
Hotter Motor
Hotter Fan Unit
Rotor Plug for 3mm shaft
Hotter Speed Control
2200 4S 20C Lipo
Bajora is online now Find More Posts by Bajora
Old Feb 28, 2009, 11:22 AM
BadClams is offline
Joined Aug 2008
Please post control throws
motor?
"Per instructions"??? I don't have any such info in my instructions... What are you guys using? (high and low rates please???)
Clams...
Old Feb 28, 2009, 01:25 PM
big-john-52
Tyler Texas
Joined Feb 2005
I am out of town today and not near my work bench but I think the throws were 1/4in high rates and something like 3mm low rates....just a guess at this point .
Ill check again when I get home tonight .
Old Feb 28, 2009, 02:14 PM
big-john-52
Tyler Texas
Joined Feb 2005
do you think a littlescreamer wll work on stock ducted fan?
Old Feb 28, 2009, 07:52 PM
BadClams is offline
Joined Aug 2008
No experience on that one!!! (I'd say yes?)
I've got to call HL on Monday....I've noticed my fan has been rubbing the shroud (static runs) and one blade has 2 issues: a "ragged" end (not clean) and a small chip out of the trailing edge.
Also noticed that the ragged blade is shorter than the others when referencing its distance fron the shroud.
What do you folks think???
Old Feb 28, 2009, 09:22 PM
BadClams is offline
Joined Aug 2008
here's a gripe...
hey all...
As i've only done static runs with guts and wires and batts hanging out, I've only just noticed a "small issue"...I can't close the friggin canopy over the stock batt cuz the wire leads are poking up-and-out of the battery in such a way as to prevent the canopy from being able to close (by a fair amount, at that). Has anyone else experinced this???
The canopy fits well up until you put in the battery. Looks like I need to cut. These issues really get me stewing.......
Old Feb 28, 2009, 09:23 PM
big-john-52
Tyler Texas
Joined Feb 2005
Well I just orderd a littlescremer for my AMX and im wondering if I need This (Rotor Plug for 3mm shaft ) for this motor ?
Just asking.....lol I dont have a clue,
John
Old Feb 28, 2009, 09:25 PM
AA6JB
Bajora's Avatar
Joined Sep 2004
Stuff the battery wires/connectors down into the hole at the front of the battery compartment, the one that the battery power lead comes up through.
Article Hobby Lobby JPower A-7 Corsair II ARF RC Jet Bajora Foamy EDFs 134 Jul 09, 2016 10:18 AM
Article Hobby Lobby's F9F Panther EDF Jet ARF Review Michael Heer Foamy EDFs 802 Oct 07, 2012 06:42 PM
Build Log AMX Light Attack Fighter Jet - Hobby Lobby gquiring Foamy EDFs 161 Mar 24, 2009 07:46 AM
Discussion AMX Light Attack Fighter Jet NJAIRSTRIKE Foamy EDFs 1 Oct 29, 2008 08:56 PM
Cool AMX Light Attack Fighter Jet Jason Cole Hobby Express (Formerly Hobby Lobby) 8 Oct 25, 2008 08:39 AM
