Old Jun 17, 2009, 09:32 AM
Bajora is online now
Find More Posts by Bajora
AA6JB
Bajora's Avatar
Joined Sep 2004
I agree that the stock components are worthy of consideration. Especially if you want an all around great flying trunk jet! ( I think you just coined a new phrase with that one!?<G>) I think the stock power system is good for 65 to 70 but yet it is so light that you can launch and land with ease.
Bajora is online now Find More Posts by Bajora
Old Jun 17, 2009, 04:49 PM
kevinb120 is offline
Find More Posts by kevinb120
kevinb120's Avatar
United States, VA, Woodbridge
Joined May 2009
Thanks guys. I guess they fixed the servo issues fairly quickly from the original few I saw in the threads with issues. I was just pricing out 40 or 60 plush ESC's and cheap HXT servos. Its a tough choice with an extra $40-50 or so for 'quality' aftermarket products. The only thing I am thinking is that if I upgrade, I will end up with yet another set of electronics from an arf (I have 2 sets that I doubt I will ever have a use for already from crash-and-burns).
I just wish they would 'amp up' ARF's a bit more for the price difference we would still buy them rather then using bare minimums. Most of the ones I see would be so much better if they stepped up the ESC's or servos or batteries just ONE more 'notch'...The two Parkzone planes I have have been nothing but excellent with very good components, and I haven't had a single reason to worry about reliability nor feel compelled to change anything. Makes me a little nuts, do I order the ARF version just one more time...
kevinb120 is offline Find More Posts by kevinb120
Old Jun 17, 2009, 09:58 PM
BadClams is offline
Find More Posts by BadClams
United States, LA, Bossier City
Joined Aug 2008
Guess it all depends on the performance you're looking for! So what ARE you looking for? There's enough of us here to give you an idea of what to expect if you get spefcific...
BadClams is offline Find More Posts by BadClams
Old Jun 17, 2009, 11:33 PM
kevinb120's Avatar
Joined May 2009
I was thinking for dead-nuts reliable, expandable, and reusable electronics that can find a home in other aircraft down the road.
Something like
Turnigy plush 60A
HXT 9g's
3c 1550 25C's and/or 4c 1750 20C's
The airframe and this stuff is about the same as the ARF(ordering the 'factory' motor replacement with the airframe)
It's probably going to be the AMX or Starmax Panther, but they force you to buy that as an ARF. I could stay 3c with that and just swap out to the electrifly 25A from my deceased L-39...And of course, there is always the Alfa A4
Old Jun 18, 2009, 07:58 AM
BadClams is offline
Joined Aug 2008
No...you can get any of the HL J-Power jets as "Airframe Only" kits; I have another F-4 and the F-18 on order now...
Old Jun 18, 2009, 08:08 AM
AA6JB
Bajora's Avatar
Joined Sep 2004
AMX Airframe only from Hobby Lobby $69.90
Old Jun 18, 2009, 06:42 PM
kevinb120's Avatar
Joined May 2009
I was referring to the Starmax Panther. I really want that one too, but not as an ARF.
Ugh, the more I look at this stuff the harder it gets to settle on something...
Old Jun 22, 2009, 07:39 PM
BadClams is offline
Joined Aug 2008
Ok...now ur just getting flaky!
Old Jun 22, 2009, 09:09 PM
kevinb120's Avatar
Joined May 2009
Heh, I ordered the HP F-16 and the Morgan mill goodies Figured it's a safe bet
Old Jun 26, 2009, 06:53 PM
b-29er is online now
Find More Posts by b-29er
Buzz Run Extraordinare!
b-29er's Avatar
USA, MI, Sanford
Joined Jul 2006
A suggestion- I installed most of the components on this plane using the included glue, but not for the wings. The wings were far too weak. My suggestion- buy some matching paint and use Sumo Glue. I can hold my plane by an area about 4 inches in from either wingtip without breaking the glue. resilient aircraft. going to do a demonstration at an electric flight show.
b-29er is online now Find More Posts by b-29er
Old Jun 27, 2009, 10:36 PM
b-29er's Avatar
USA, MI, Sanford
Joined Jul 2006
I am flying my amx for the first time tomorrow, Are their any tips i should know about the plane?
Old Jun 28, 2009, 06:10 AM
BadClams is offline
Joined Aug 2008
Keep control throws low(ish) as its VERY nimble! Dial in some expo if you have it available. CG as per manual is just fine. Launch is a snap! Just a slight up angle to the toss is all you need and it tracks out straight as an arrow. Also resist the urge to do slow/low power turns as it doesn't tell you the stall is coming at all! (try this with plenty of altitude and feel it out!) Also, even though its colorful, orientation can be tricky depending on the lighting and it can get small fast!
Please post your thoughts on this bird later and good luck! We can talk about the mini F4 next!!!
B
Old Jul 11, 2009, 02:21 PM
pwu_1 is offline
Find More Posts by pwu_1
USA, CA, Dublin
Joined Jul 2006
can the GWS BLM005A(20 mm diameter can, 3900kv, 2mm shaft diameter) be used to power this edf? The motor should fit the fan perfectly and the kv value matches the factory version according to this post
http://www.rcgroups.com/forums/showp...4&postcount=29
The only difference is according to GWS website, the BLM005A motor running on 3 cells on the GWS 64mm edf only produced 301grams of thrust while the J-power AMX is claimed to produce 550-580 grams of thrust?
I'm thinking of getting the airframe only version and building it up since it would be a considerable discount from the ARF version(I already have the motor and esc and servos, etc)
Also, according to the post linked above, the motor shaft is 2mm but I think Don mentioned that it is 2.3mm?
Sorry about all these questions...this will be my first EDF and I have no idea how everything works yet.
pwu_1 is offline Find More Posts by pwu_1
Old Jul 11, 2009, 05:21 PM
ozzi supercub is offline
Find More Posts by ozzi supercub
WiggleWiggleWiggle
ozzi supercub's Avatar
South Australia
That motor in a GWS EDF64 will produce near on 600 grams of thrust for under 20 amps on 4S.
ozzi supercub is offline Find More Posts by ozzi supercub
Old Jul 11, 2009, 06:13 PM
pwu_1 is offline
USA, CA, Dublin
Joined Jul 2006
Right, but Jpower is claiming their motor produces almost the same amount of thrust on 3 cell!
I guess my real question is, if the GWS motor produces roughly 300 grams of thrust on 3 cell, will that be enough to fly the AMX?
Article Hobby Lobby JPower A-7 Corsair II ARF RC Jet Bajora Foamy EDFs 133 Aug 21, 2014 06:57 AM
Article Hobby Lobby's F9F Panther EDF Jet ARF Review Michael Heer Foamy EDFs 802 Oct 07, 2012 06:42 PM
Build Log AMX Light Attack Fighter Jet - Hobby Lobby gquiring Foamy EDFs 161 Mar 24, 2009 07:46 AM
Discussion AMX Light Attack Fighter Jet NJAIRSTRIKE Foamy EDFs 1 Oct 29, 2008 08:56 PM
Cool AMX Light Attack Fighter Jet Jason Cole Hobby Express (Formerly Hobby Lobby) 8 Oct 25, 2008 08:39 AM
