Old Feb 22, 2009, 04:20 PM
tdearth is offline
Find More Posts by tdearth
USA, IN, Nineveh
Joined Apr 2002
I had to take mine apart again to remember how I did it.
I didn't trust the fan to hold with just the tabs. so I put a line of epoxy
on each tab before closing it up. The glue will keep it mounted well, but will still
break lose if I ever have to take it out for any reason.
Tim
tdearth is offline Find More Posts by tdearth
Old Feb 27, 2009, 11:41 AM
Reverend is offline
Find More Posts by Reverend
Reverend's Avatar
Innsbruck, Austria
Joined Oct 2003
Well, finished my Slamander this morning before work. Weather looks fine for tomorow so it looks like it will be maidentime!
btw, my stock Fan does 550g of thrust on a 3S. That actually rocks for a 615g Plane!
I supported the tail too, melted away some of the foam with the soldering iron and glued in a 5mm carbon tube.
Wish me luck fo tomorow!
Reverend is offline Find More Posts by Reverend
Old Feb 27, 2009, 12:23 PM
SammyB is offline
Find More Posts by SammyB
Rem The Wasp CV-7 9/15/42
SammyB's Avatar
Santa Clarita,CA
Joined Apr 2004
That looks great! Looks like you did a repaint?
SammyB is offline Find More Posts by SammyB
Old Feb 27, 2009, 12:44 PM
tdearth is offline
USA, IN, Nineveh
Joined Apr 2002
Good luck Reverend.
Let us know how it goes.
Tim
Old Feb 27, 2009, 12:55 PM
Reverend is offline
Reverend's Avatar
Innsbruck, Austria
Joined Oct 2003
Hi!
Thanks! Yes, repainted it with a paint roller after airbrushing all the panel lines black. Looks quite nice in real.
Also did some work to the cockpit.
Will get some nice in flight shots tomorow I hope.
Rgds,
Rev
Old Feb 27, 2009, 01:30 PM
SammyB is offline
SammyB's Avatar
Santa Clarita,CA
Joined Apr 2004
Like a house paint roller? Did you use craft paint?
Old Feb 28, 2009, 11:55 AM
Reverend is offline
Reverend's Avatar
Innsbruck, Austria
Joined Oct 2003
Right, maidened the Heinkel today.
First, that 162 in the "gay music" video definitely does not have the stock motor.
BUT: Flew three packs today. Didn't start the Heinkel myself, had a friend toss it. You have to toss it slightly up as it loses some height while picking up speed. Plane flies quite well actually. It is true, that the Heinkel has an awkward tendancy to "fall" out of the turns but if you don't overdo the angle it tracks through well. Balanced the Heikel to the recommended CG for the first flight. Added 15g of weight for the second and third flight. Great improvement!
Landing is easy, power off and glide her in! Glides very well!
@sammyB: yet, normal spongue handroller. The roller is 5cm (aprx 2in.) wide. works very well with water based acryl and is very wife friendly as there is almost no smell (have to work in the appartement in winter).
rgds,
Rev
Old Feb 28, 2009, 12:09 PM
Tommy D is offline
Find More Posts by Tommy D
Hooper, full throttle!
Tommy D's Avatar
USA, NY, East Islip
Joined Feb 2004
Rev
Nice report. Did you add the weight to the nose or tail?
Also, very nice photos.
Tommy D
Tommy D is offline Find More Posts by Tommy D
Old Feb 28, 2009, 12:25 PM
Reverend is offline
Reverend's Avatar
Innsbruck, Austria
Joined Oct 2003
Thanks!
added 15g to the nose due to a larger LiPo (1400 instead of 1350)
Rev
Old Mar 11, 2009, 09:02 PM
Aerobatman is online now
Find More Posts by Aerobatman
Aerobatman's Avatar
Akron, Ohio
Joined Nov 2005
Hi all. I just purchased my own He-162 from Hobby Lobby with their "spare parts" special. I was able to get everything to make my own "kit" for $104. All I need now is a manual. Does anyone know where I can download a PDF? What I really need is the CG location and basic internal installation.
Did anyone ever try the 4800kv Don's RC Wicked motor in this airframe?
Aerobatman is online now Find More Posts by Aerobatman
Old Mar 11, 2009, 11:42 PM
SammyB is offline
SammyB's Avatar
Santa Clarita,CA
Joined Apr 2004
I can scan the manual for you and email it. Might take a little time as I have to get it down from the rafters. Regarding Don's motor. Email him. He will hook you up nicely. This fan is used in a lot of these China jets so he has done his testing.
Old Mar 12, 2009, 06:58 PM
Aerobatman's Avatar
Akron, Ohio
Joined Nov 2005
SammyB whatever you can do I'd appreciate it. I live right close to where he flies so I might go up and make a transaction this weekend. Weather looks good for flying Saturday, at least here in Ohio! :-)
Old Mar 12, 2009, 07:09 PM
Tommy D is offline
Tommy D's Avatar
USA, NY, East Islip
Joined Feb 2004
I have one installed and ready for a test flight. That is if the #$%^ weather ever warms up here.
Ill tell you this, running it up static there is no comparison between "stock" and Don's setup.
Tommy D
Old Mar 20, 2009, 04:07 AM
multiPLEX66 is offline
Find More Posts by multiPLEX66
Joined Mar 2009
Cg
hY GUYS,
I receive this week my HE-162 and i have a question.
Wat is the good CG for this model ?
Thanks a loot for your help and greats from Belgium
multiPLEX66 is offline Find More Posts by multiPLEX66
Old Mar 21, 2009, 01:19 AM
WTFLYR is offline
Find More Posts by WTFLYR
WTFLYR's Avatar
West Central PA
Joined Dec 2008
It is true, that the Heinkel has an awkward tendancy to "fall" out of the turns but if you don't overdo the angle it tracks through well. Balanced the Heinkel to the recommended CG for the first flight.
Even more so when you fly it with insufficient power. I finally flew mine with a 3s-1345 EVO, but I think the batt is no longer quite up to par. I was amazed at how slow it would fly, as I barely hovered 5 feet above the ground for a half circuit. Should have grounded it, but dummy me figured "well it seems to be flying well for what little power I have, so we'll slowly gain some height and keep going". Sure enough, I got a pretty strong crosswind while approaching a line of trees. Turned the plane, but it would simply bank and not turn, with the insufficient power. As Murphy would have it, the plane found the tree.
I'll test it now with a 3s-1800 EVO, and won't fly again until I see reasonably more power on the meter. I'm really looking forward to flying this plane again, as it flew so well, for being just, and I mean just, above stall speed.
Model Masters RLM76 is basically a perfect match for the bottom.
The green is another story. Mixed a good match, which blended virtually unnoticable, using the airbrush. Used MM medium green, an MM light flat grey, and some blueish green also, topped with flat afterwards. It's now fully repainted, and actually looks almost as good as new. I won't sweat the first few scrapes anymore, as we always do with a new plane.
WTFLYR is offline Find More Posts by WTFLYR
HL He-162 Salamander EDF LTChip Parkflyers 4 Sep 01, 2010 07:56 PM
Sold Kavan HE-162 Salamander Jet ARF New in Box badbill Aircraft - Electric - Airplanes (FS/W) 4 Feb 12, 2006 05:56 PM
Kavan He-162 Salamander U812 Electric Ducted Fan Jet Talk 66 Mar 28, 2005 04:38 PM
HL He-162 Salamander Power System Options C. Alan Electric Ducted Fan Jet Talk 6 Nov 05, 2004 11:31 AM
He 162 Salamander in Depron RubSon Foamies (Kits) 4 Jan 08, 2003 12:49 PM
