Old Oct 30, 2008, 10:06 PM
maxaintright is offline
Find More Posts by maxaintright
supercrash
Morrison IL
Joined Oct 2008
Help!
whats the best size motor for a Acrobatic Extra 330 90 - 63"
I am just trying to fly gas powered planes Ive had a few electrics but i got a good deal on a Acrobatic Extra 330 90 - 63" and I was hoping someone could give me some direction
maxaintright is offline Find More Posts by maxaintright
Old Oct 30, 2008, 10:17 PM
WCB is offline
WCB
Find More Posts by WCB
WCB
NC
Joined Aug 2005
The wingspan is in the 60 range. Assuming the plane weighs 7 to 8 pounds...
61-75 2 stroke
91-100 4 stroke
WCB is offline Find More Posts by WCB
Old Oct 31, 2008, 09:59 PM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
Acrobatic Extra 330 90, Acrobatic Extra 330 90, Acrobatic Extra 330 90.
OK, we know what an Extra 330 is, we also know that it is aerobatic (the term used in some countries is acrobatic). I wonder what "90" stands for? Maybe size - 0.90cu.in. or 15cc?
Alright, now seriously - 63" WS for an Extra is usually a 60-size plane. As an Extra will benefit from some extra power, and a 90 engine is usually a bored-out 60 (same dimensions on the outside, same mounting pattern), then a 90 sounds like a good size.
Ivan
ivanc is offline Find More Posts by ivanc
Old Oct 31, 2008, 10:33 PM
EJWash1 is online now
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
By "Acrobatic Extra 330 90" do you mean to say that you have an Acrobatic Extra 330 90 MARKETED (offered) by Nitro Models? Are the pictures I post of your model? If so, the listed specifications by Nitro Models are:
Wing span: 63 in / 1600mm
Wing area: 713sq in /46 sq dm
Flying weight: 6.6 lb / 3000g
Fuselage length: 60 in / 1520mm
Engine Required: 4c 0.91 cu in
Radio Required: 4channels,5 servos
If this is your model, are you asking for recommendations/opinions of what the best manufacturer of a 0.91 4-cycle engine would be best for this model?
EJWash
EJWash1 is online now Find More Posts by EJWash1
Old Nov 05, 2008, 09:32 PM
supercrash
Morrison IL
Joined Oct 2008
yes that is my model and any direction to a good manufacturer would be apprecated
Old Nov 05, 2008, 09:42 PM
crashEMhard is offline
Find More Posts by crashEMhard
Moline IL
Joined Sep 2007
http://cgi.ebay.com/ws/eBayISAPI.dl...em=260310543231
im selling a motor that will be more then enough, and then some!
crashEMhard is offline Find More Posts by crashEMhard
Old Nov 08, 2008, 06:51 AM
Stevo Revo is offline
Find More Posts by Stevo Revo
over user
Stevo Revo's Avatar
North of Milwaukee, Wisconsin
Joined Jun 2007
A friend at the field has that EXACT model, in another one of their color schemes. He's running a Saito 1.00 and a 15x6 prop. He's very happy with the setup.
Me............ I have an Edge 540 (similar to extra) with a 68 inch wing, with about the same weight, and I run a 1.20ax.
Stupid fun
Stevo Revo is offline Find More Posts by Stevo Revo
Old Nov 08, 2008, 06:54 AM
over user
Stevo Revo's Avatar
Joined Jun 2007
Oh and btw............. BRACE THAT MOTOR MOUNT ...............or it WILL come apart!!!!! Use triangle stock in all the corners for support. I saw it first hand. Only took three flights to cause almost irreparible damage!
Old Nov 29, 2008, 11:14 PM
supercrash
Morrison IL
Joined Oct 2008
thanks for the help
thanks for the help
Old Dec 07, 2008, 08:42 AM
huck1133 is offline
Find More Posts by huck1133
Joined Jan 2006
Depends on your flying style but if you are into 3-D then put in a YS-110 and be done with it
huck1133 is offline Find More Posts by huck1133
Old Dec 09, 2008, 11:50 AM
lucasavaitor is offline
Find More Posts by lucasavaitor
Joined Aug 2008
Go bigger than you need, you can't go wrong!
lucasavaitor is offline Find More Posts by lucasavaitor
Question Whats the best JR reciever for .40 size planes?? Crash549 Fuel Plane Talk 7 Apr 20, 2006 09:57 AM
Whats the best flying plane for a sp400 geared motor??? raythomas Parkflyers 12 Feb 21, 2002 09:17 PM
Best size prop for 6v sp400 on 7 and or 8 cells?? deadcell Power Systems 2 Oct 05, 2001 03:39 AM
whats the best battery pack for brushless voyager? misskimo Electric Heli Talk 2 May 30, 2001 03:52 PM
Whats the best battery pack for the Litestick? mrebman Parkflyers 10 May 30, 2001 11:01 AM
