Old Oct 29, 2008, 07:35 PM
bryadelm is offline
Find More Posts by bryadelm
United States, PA, West Chester
Joined Mar 2006
United Hobbies EDF Ducted Fan Unit 7 Blade 5 inch 127mm
Has anyone installed the United Hobbies EDF Ducted Fan Unit 7 Blade 5 inch 127mm, along with United Hobbies - KB45-08XL 1600kv Brushless Inrunner (or equivalent), and TURNIGY Sentilon100A HV 2-12S Speed Controller (or CC 110 HV)?
Did you get the calculated (see http://www.s4a.ch/eflight/fancalc_e.htm) 7-9 lbs of thrust, substituting a DS-75 and Neu Motor 1515 1.5Y for UH EDF 5 inch and UH1600kv Brushless Inrunner, using 2 x 6S 3700 Lipo's?
bryadelm is offline Find More Posts by bryadelm
Old Oct 30, 2008, 04:12 AM
jjantti is offline
Find More Posts by jjantti
jjantti's Avatar
Finland
Joined Sep 2004
Sentilon is know to work with EDF- abuse. Go for it.
But UH/HC/HK doesn't have any motor for that big fan. kv you suggested is way too high. It needs to be somewhat third of that.
see here: older disscussion about the fan and motors
/Jyri
jjantti is offline Find More Posts by jjantti
Old Oct 30, 2008, 08:01 AM
Scarey is offline
Find More Posts by Scarey
Registered EDF abuser
Scarey's Avatar
Michigan
Joined Jan 2006
That fan is a Amp hog. Lots of high pitched blades. You will need a large low Kv motor ran on 9S + to get 9+ Lbs static and keep your Amps < 100.
A good motor (inrunner) that weighs around 600 gms will do it. But it will be hard to find an inexpesive one (Neu makes them but there not cheap).
Scarey is offline Find More Posts by Scarey
Old Oct 30, 2008, 08:53 AM
Scarey is offline
Scarey's Avatar
Michigan
Joined Jan 2006
Read this thread same type of fan
http://www.rcgroups.com/forums/showthread.php?t=935467
You can get more thrust out of a Midifan Pro with greater efflux (top end speed) Read this
http://www.rcgroups.com/forums/showthread.php?t=846287
Old Oct 30, 2008, 08:13 PM
bryadelm is offline
Joined Mar 2006
Originally Posted by jjantti
...But UH/HC/HK doesn't have any motor for that big fan. kv you suggested is way too high. It needs to be somewhat third of that.
/Jyri
Thanks, I will search for a lower Kv motor to use with this fan.
Old Oct 30, 2008, 08:27 PM
bryadelm is offline
Joined Mar 2006
Unsure of where the first of two above threads is leading yet... Second one is for 90 mm fan, while I need shroud outer diameter to be 133 mm (E-Turbax) for 5 in/127 mm inside diameter.
Old Oct 30, 2008, 08:42 PM
Scarey is offline
Scarey's Avatar
Michigan
Joined Jan 2006
All I was saying is that this fan by design is an Amp hound. For a needed amount of thrust 9Lbs can be easily achieved with a 90mm Midifan and your jet would be lighter and much faster and cheaper. But if you can`t or don`t want to re-work the ducting then so be it.
Old Oct 30, 2008, 09:10 PM
bruff is offline
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
I have installed a Hacker A50-14S outrunner in one the great results. It was pulling 62 AMPs at 22500 RPM about 8 lbs of thrust on a 10S LiPo pack.
Bob
bruff is offline Find More Posts by bruff
Old Nov 01, 2008, 06:08 PM
bryadelm is offline
Joined Mar 2006
I found test data to answer my questions at:http://myhobbycity.com/showthread.php?t=351
Old Nov 03, 2008, 06:42 PM
bryadelm is offline
Joined Mar 2006
On Saturday, I met with Danny, who has experience with installing two EDF's on a Nitromodels Honda Jet (posted here at RCG), at my AMA club field (VFSS). He will be working with me on bench testing out 5 inch fan/motor/ESC/bat combo's this Fall prior to us installing it in my BAE Hawk and Dannys' Nitromodels Formost 160. Thus, we will also obtain our own test data here.
Old Nov 06, 2008, 11:47 AM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
Bob
Bob-- Is it the Midifan or some other fan that you're referring to here?
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
For Sale EDF Electric Ducted Fan Unit and Motor sale shschon Aircraft - Electric - Jets (FS/W) 1 Jun 04, 2008 01:37 PM
Sold KB45-11XL Brushless Inrunner & Haoye 4.5" Ducted Fan Unit lbergman Aircraft - Electric - Power Systems (FS/W) 3 May 28, 2008 09:23 PM
Sold NIB GWS EDF-75 Ducted Fan Unit !!!! niner555 Aircraft - Electric - Jets (FS/W) 4 Feb 02, 2008 10:20 AM
Sold Hurricane 8 blade custom ducted fan unit! airmcn_3 Aircraft - Fuel - Airplanes (FS/W) 0 Apr 27, 2005 11:53 AM
