Old Feb 21, 2003, 01:17 AM
gregw is offline
Find More Posts by gregw
gregw's Avatar
Hong Kong
Joined Nov 2002
End points for Corona Tail Servo
I seem to have too much range on my Corona's tail servo. At full twist in either direction, the servo is causing the link to bind. Has anyone set end points for the tail servo? What end points are you using? I'm using HS-81MG on the tail..
gregw is offline Find More Posts by gregw
Old Feb 21, 2003, 08:28 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
That depends on your gyro. If you have a GY240 you have to move the rudder control rod in toward the center until it does not bind in the HH mode. If you have a GY410 there is an adjustment on the gyro.
The Tx only controls the rotation rate and should not be used to set the end points, as that are controlled by the gyro.
What gyro are you using?
RC Man is offline Find More Posts by RC Man
Old Feb 21, 2003, 10:33 AM
gregw is offline
gregw's Avatar
Hong Kong
Joined Nov 2002
Futaba Gy240.
How do I move it to the center? Do I need to adjust the length of the link?
I did it based on the instructions in the Corona manual.. Turn on transmitter, turn on receiver, center stick, screw in the "horn" with the link install and adjust of the link until it is around 10 degrees off centre towards the rear..
Discussion Digital servo for Corona tail. uglyplane Electric Heli Talk 6 Feb 05, 2006 11:15 AM
corona tail servo question RabelRouse Electric Heli Talk 4 Aug 25, 2004 10:03 PM
CSM 540 and corona tail servo travel spacecase Electric Heli Talk 0 Jul 20, 2004 12:02 PM
Corona tail Servo Died in flight????? EP heli freak! Electric Heli Talk 8 Jul 14, 2003 03:34 AM
A Better Corona Tail Servo NewRotorSoon Electric Heli Talk 16 Mar 28, 2003 05:11 PM
