Old Mar 04, 2009, 10:32 PM
RotorCycle is online now
Find More Posts by RotorCycle
Thermals the path to elevation
RotorCycle's Avatar
United States, AZ, Chandler
Joined Jul 2004
Originally Posted by raynet11
Where is my Sniper V2?
I have it on good authority it's nice and safe with all the other Sniper V2's
RotorCycle is online now Find More Posts by RotorCycle
Old Mar 04, 2009, 10:41 PM
pwkpete is offline
Find More Posts by pwkpete
ElektroRC.com - MSH,LAHeli,YGE
Pewaukee, WI, USA
Joined Mar 2002
Yep, good points Ray!
Re Sniper V2:
You guys will be the next to know after I hear from LAHeli...
There is no estimated release date... When it gets closer, I'm sure we will hear something so it must be a bit out yet....
pwkpete is offline Find More Posts by pwkpete
Old Mar 04, 2009, 10:59 PM
rotaryguy is offline
Find More Posts by rotaryguy
Jacksonville, Florida
Joined Jul 2004
Solved my Ricco tail buzz...got tired of messin with the pins...Just need to trim the extra bit off the end of the shaft....now I can run @ 100% throttle curve with ZERO vibrations. About 2850HS, I can even remove the head and run it up to 100% smooth as silk and without the head, blades, paddles its got to be running faster.
With the stock setup I always had to spend too much time tinkering with it, I tried the bearing mods, checked bolts, blah, blah...I was never able to get over half throttle before the heli would start to vibrate itself to death.
Forgot to mention the bling factor as well, Aluminum grips, slider.
rotaryguy is offline Find More Posts by rotaryguy
Old Mar 05, 2009, 09:57 AM
pwkpete is offline
Pewaukee, WI, USA
Joined Mar 2002
What parts are those?
Looks nice!
I'll mention it to LA...
Old Mar 05, 2009, 10:31 AM
raynet11 is offline
Find More Posts by raynet11
Sponsored by Team Me
raynet11's Avatar
Montgomery, IL
Joined Aug 2005
Figured you would be the one holding them all..
After the Ricco build and flight time it only increases the want / need factor for a Sniper, I live in the open plains so dancing the Ricco around can be quite a workout on some days. I have a TR500 going into service which is nice but the weight will require more HS and thus shorter flight times.
Do you think I could re-use the 6S 3000mah packs from the TR500 on the Sniper or do I need more mah then that?
raynet11 is offline Find More Posts by raynet11
Old Mar 05, 2009, 10:32 AM
raynet11 is offline
raynet11's Avatar
Montgomery, IL
Joined Aug 2005
That's great news, that's a lot of HS you have going on there, I think I'm sitting around 2500 or so.
Old Mar 05, 2009, 10:33 AM
raynet11 is offline
raynet11's Avatar
Montgomery, IL
Joined Aug 2005
Re Sniper V2:
I know where to find you.. I'll try to reduce my Sniper nagging down to once every 2-3 weeks..
Old Mar 05, 2009, 10:38 AM
pwkpete is offline
Pewaukee, WI, USA
Joined Mar 2002
You should have gotten a Protos while waiting, then you wouldn't have that weight problem
Yep, I'm not that far from you... Road trip distance!
Old Mar 05, 2009, 11:19 AM
RotorCycle's Avatar
Joined Jul 2004
The Sniper is so light (~1500 grams) that the 6S 3000mAh batteries would work. When we were flight testing 5S and 6S back-to-back, we were getting more than than 8-mins on the 6S 3300mAh. We never utilized even 80% of the pack so don't know how long it would have flown.
I ended up using a very light 5S 2500mAh setup since the Scorpion motor kv was too high for 6S.
Old Mar 05, 2009, 12:39 PM
Joined Jul 2004
Looks nice!
Metal tail assembly- trex 250. $13.99
Metal slider -trex 250. $9.99
Old Mar 05, 2009, 01:20 PM
raynet11 is offline
raynet11's Avatar
Montgomery, IL
Joined Aug 2005
That's great news, I love it when I can get dual use out of my Lipo's, seems like a waste to drop the coin for dedicated packs with no other use. I was contemplating doing a 40-Size Edge 300 just so I would have something else to use them with.
So LA Heli is slow in releasing the Sniper but l hope it's only because they are perfecting it rather then a resource allocation problem.
Old Mar 05, 2009, 01:24 PM
Ecaf is offline
Find More Posts by Ecaf
Heli Addict....
Ecaf's Avatar
West Dundee, Il.
Joined Nov 2003
Are those Trex 250 blades or the plastic Maxir tail blades?
Ecaf is offline Find More Posts by Ecaf
Old Mar 05, 2009, 01:45 PM
Joined Jul 2004
The longer maxir tail blades, trex blades are too short. You have to sand the roots a little
Old Mar 05, 2009, 06:13 PM
Giovanni Day is offline
Find More Posts by Giovanni Day
Gettin back into it!!
Giovanni Day's Avatar
KY
Joined Apr 2002
what is the ID on those blade grips where the blade is held in? Wondering how they will work with the CF tail blades? Did you have to change the original pitch arm also?
Giovanni Day is offline Find More Posts by Giovanni Day
Old Mar 05, 2009, 06:16 PM
JustPlaneChris is online now
Find More Posts by JustPlaneChris
www.rctodayshow.com
JustPlaneChris's Avatar
Austin, TX
Joined Sep 2005
I tried to convince him, Pete... but he just wouldn't listen.
-Chris
JustPlaneChris is online now Find More Posts by JustPlaneChris
Article Hobby Lobby's Honey Bee II Micro Heli RTF Review Stocker Micro Helis 22 Jul 27, 2009 01:05 PM
Build Log LA Heli MaxiR Standard Kit Full Build Thread... Lots Of Photos and Full Text kdill2160 Micro Helis 452 Sep 12, 2008 06:54 PM
Barnstormer Boats 1:72 scale LA Class kit review. Nemo Submarines 8 Mar 21, 2007 08:51 AM
Poll To be or not to be.....A full LA Heli MaxiR build & reveiw kdill2160 Micro Helis 29 Sep 09, 2006 05:33 PM
