Old Oct 28, 2008, 06:38 AM
1428 is offline
Find More Posts by 1428
Perth
Build Log
700ep arpro boats
hi i just bought a new arpro brushless* boat here is a video of it
ARPRO Radio Control RC ESC Brushless Motor Super fast Boat (0 min 40 sec)
1428 is offline Find More Posts by 1428
Old Oct 28, 2008, 11:37 PM
1428 is offline
Perth
does
hi does any one know how i can get my new boat going really fast
Old Oct 29, 2008, 10:45 AM
pompebled is online now
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Nice boat!
Please define real fast.
What's in the boat now: motor ESC, battery?
What's the size of the boat?
How quick is it now?
What's your budget?
Regards, Jan.
pompebled is online now Find More Posts by pompebled
Old Oct 29, 2008, 04:55 PM
j.m. is offline
Find More Posts by j.m.
Don't worry about it!
j.m.'s Avatar
Raleigh NC
Joined May 2008
And, most importantly, have you ever driven any RC vehicle over 30mph before?
Is the hull ABS or fiberglass?
j.m. is offline Find More Posts by j.m.
Old Oct 29, 2008, 04:58 PM
Sneek, Netherlands.
Joined May 2004
It's fiberglass, so at least the hull would be able to go fast, don't know about the driver....
Regards, Jan.
Old Oct 29, 2008, 05:58 PM
1428 is offline
Perth
oh yeah
specifications
LENGTH :650MM
BEAM :260MM
WEIGHT :1000G
PROPELLER : D42XP1.4
RADIO :2CH ESC40A+ SERVO
MOTOR :3536-1500 BRUSHLESS
BATTERY :11.1V 2200-3300 MAH
HULL :FIBERGLASS
Old Oct 29, 2008, 06:11 PM
ghostofpf1 is offline
Find More Posts by ghostofpf1
Joined Mar 2007
Any pictures of the inside ??That could be helpful in determining what will or will not fit.
HTH
Ghost
ghostofpf1 is offline Find More Posts by ghostofpf1
Old Oct 30, 2008, 01:39 AM
1428 is offline
Perth
oh
oh ok i just found this http://www.rctoys4less.com/wholesale...?ProductID=152
Old Oct 30, 2008, 03:17 AM
Sneek, Netherlands.
Joined May 2004
Did you read this?
http://www.rcgroups.com/forums/showt...ight=Arpro+700
Ignore the steering outdrive part, as it doesn't apply to the Arpro 700.
Should you go for a faster inrunner motor and a decent prop (not the flexing stock one), keep in mind you will flip it every once and a while.
The hull has room for it, so I'd think about installing a floodchamber, to make it selfrighting.
Regards, Jan.
Old Oct 30, 2008, 04:19 AM
Rex R is offline
Find More Posts by Rex R
Joined Nov 2005
that lipo pack would worry me...to me it is borderline on amp rating vs possible amp draw for the stock boat, any mods would probably demand to much of it. however since the motor has a 'low' kv rating...a fix that might solve the slow speed and battery worries would be, get a pair of 2s(7.4v) 25c 4800mah packs and run them in series to get 14.8v. that should get the boat moving and enough pack capacity to handle most mods/upgrades
Rex R is offline Find More Posts by Rex R
Old Oct 30, 2008, 06:37 AM
1428 is offline
Perth
any more
THANKS BUT I NEED RESOURCES. like web sits and info i lost all mine
Old Oct 30, 2008, 08:00 AM
Sneek, Netherlands.
Joined May 2004
Originally Posted by 1428
THANKS BUT I NEED RESOURCES. like web sits and info i lost all myn
The search function and google should cover most 'resources'.
Please make an effort to fill in your profile completely, it 'talks' easier.
Regards, Jan.
Old Oct 30, 2008, 11:03 AM
Mikedown is offline
Find More Posts by Mikedown
Closed Account
Joined Jul 2006
my new arpro boat
I don't remember the posters name but REX R and Mr. Pompebled are 2 GURU'S whom should be listened to they do know their stuff.
Mikedown is offline Find More Posts by Mikedown
Old Oct 30, 2008, 12:59 PM
Rex R is offline
Joined Nov 2005
thanks for the vote of confidence D. it is difficult to reccomend good sites when we don't know whether you are in the U.S. or somewhere else in the world.
that said, for folks in north America, cheapbatterypacks.com does have some decent batteries
Old Oct 30, 2008, 02:53 PM
j.m. is offline
j.m.'s Avatar
Raleigh NC
Joined May 2008
For all intents and purposes, I would get some LiPos from http://www.hobbycity.com
They have the lowest prices around, and will ship worldwide.
Normally for a boat, the minimum I would recommend is 4Ah and 25C. The best setup for this boat (because it is light) would be somewhere around 3.5Ah 20C 3S1P lipos.
If you want the boat to balance good, then get two 3S 1.8Ah 20C lipos to run in parallel for a total of 3.6Ah.
Put one battery on each side of the drive shaft, and the radio equipment in the center.
Leave room to adjust the batteries fore and aft for CG adjustment.
