Old Mar 25, 2009, 09:54 PM
Liquidity is offline
Find More Posts by Liquidity
YardGoat lives with mama
Joined Feb 2007
James - I had 2 small problems so far.
1. The back of the canopy that holds the washer did not fit with the rest of the canopy assemble as advertised. I had to trim off the legs of the back piece and glue it to the rest of the assemble with a piece or tri-stock.
2. The trim lines on the plastic canopy seem to be to off. If you follow them, then canopy will be just a tad too short (length wise). Ask me how I know
No real worries, but curious if anyone else has had these problems.
Liquidity is offline Find More Posts by Liquidity
Old Mar 25, 2009, 09:59 PM
_Lunchbox_ is offline
Find More Posts by _Lunchbox_
Hodgehound # 3
_Lunchbox_'s Avatar
Adrian, GA
Joined Mar 2005
I had the same problem with the fit up, and also with the canopy being too short.
I do have a question though. Which aileron servo mount do I need to use for the HXT500 servos?
_Lunchbox_ is offline Find More Posts by _Lunchbox_
Old Mar 25, 2009, 11:26 PM
jkarpy is offline
Find More Posts by jkarpy
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Trim the front of the base so the canopy goes further back.
Not sure what you are talking about on the head rest not fitting.
jkarpy is offline Find More Posts by jkarpy
Old Mar 25, 2009, 11:29 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
It's not designed specifically for the HXT500 servo. Your going to have to fit it . How much does that servo weigh?
Old Mar 25, 2009, 11:36 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Canopy mounted
Some trimming of the base and headrest are required.
Old Mar 26, 2009, 04:41 AM
Hodgehound # 3
_Lunchbox_'s Avatar
Adrian, GA
Joined Mar 2005
Here are the specs on the HXT500 servo.
Size : 22.9x11.4x22 mm / 0.9x0.45x0.87 in
Voltage : 3v ~ 6v
Weight: 5g / 0.18oz
Speed : 0.10 sec/60(4.8V)
Torque : 0.8 kg-cm
Working Temp : -30C~60C
Teflon Bushing, 15cm wire, coreless motor
Servo arms & screw included
Old Mar 26, 2009, 04:44 AM
Hodgehound # 3
_Lunchbox_'s Avatar
Adrian, GA
Joined Mar 2005
Looks to be about the size of a S60 servo. http://www.horizonhobby.com/Products...ProdID=EFLRS60
Old Mar 26, 2009, 07:10 AM
Joined Feb 2007
Thanks James. I will do a little trimming tonight.
Old Mar 26, 2009, 07:52 AM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Voltage : 3v ~ 6v
Weight: 5g / 0.18oz
Torque : 0.8 kg-cm
Try the servo mount labeled DSP60. That is for the Spektrum servo which looks like the same servo.
Old Mar 26, 2009, 06:04 PM
Hodgehound # 3
_Lunchbox_'s Avatar
Adrian, GA
Joined Mar 2005
Thanks James, I will do that!
Old Mar 30, 2009, 08:57 AM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Video of Micro3DX flying
http://www.rcgroups.com/forums/showt...5#post11912519
Old Apr 09, 2009, 04:59 AM
Hodgehound # 3
_Lunchbox_'s Avatar
Adrian, GA
Joined Mar 2005
James, I got the 3dx completed. I was planning on using the battery from my micro ssx in it, but it is too long to fit and still close the hatch. It is a PQ 400 mah 2s pack. What battery do you recommend?
Old Apr 09, 2009, 12:20 PM
btsai is offline
Find More Posts by btsai
It took me 30 years?!?!!!
Chandler, AZ
Joined Apr 2007
How 'bout these?
https://fusion-pack.com/productdetai...id=192&cat=112
btsai is offline Find More Posts by btsai
Old Apr 09, 2009, 01:07 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Originally Posted by btsai
The largest battery that will fit is 11mm X 53 mm X 33 mm. I recommend spending the extra 5-15 dollars for the thunder power, Vampower or one of the Dualsky batteries. Besides, the Fusion is only 360 ma so you will not get a long flight.
http://thunderpowerrc.com/html/prolites.html
http://www.vampowerpro.com/store/com...2_Cell&pid=144
http://www.2dogrc.com/ecommerce/os/c...nt-p-2174.html
James
Old Apr 09, 2009, 01:54 PM
btsai is offline
Chandler, AZ
Joined Apr 2007
Another option -- although currently out of stock...
http://www.hobbycity.com/hobbycity/s...0C_Lipoly_Pack
I have several sizes of Rhinos -- 2S and 3S -- some for several months -- and all have performed wonderfully.
Discussion Work In Progress.....My New AP Ship MarkJayne Aerial Photography 172 May 11, 2008 11:38 AM
Discussion My new F3P work-in-progress Doug Cronkhite Indoor Pattern/F3P 13 Jan 19, 2008 09:16 PM
Discussion The new Shop! A work in progress..... Joe Bennett Aerial Photography 46 Aug 10, 2006 12:46 AM
2 New Micros (Work in Progress) MPL0527 Scratchbuilt Indoor and Micro Models 7 May 08, 2005 03:11 PM
My new GWS Spitfire - work in progress mattski GWS (Grand Wing Servo) 2 Sep 07, 2003 05:50 PM
