Old Oct 27, 2008, 07:40 AM
Bob Chiang is offline
Find More Posts by Bob Chiang
Ithaca, NY USA
Joined Oct 2000
Twin Boom Pusher w/ inverted V-tail
Hi all,
Almost finished my latest aerial photography model built from fan fold foam. The wing is six foot span with a spar made of bass wood and balsa caps and foam web. The center section is sheeted on the bottom to create a D-tube. The leading and trailing edges are reinforced with poplar dowels and sticks. Flight loads are also supported by kevlar flying wires. The fuselage is built of poplar and bass sticks. I haven't decided if I'll cover the front of the fuselage pod or leave it open.
Power system is a Turnigy 28-30 outrunner, APC 10x4.7 prop, Super Simple esc and 3S 2200 mah batteries. The weight should be about two pounds including the camera and mount.
-Bob
Bob Chiang is offline Find More Posts by Bob Chiang
Old Oct 27, 2008, 07:49 AM
ADB2 is offline
Find More Posts by ADB2
Build, fly, learn!
Versailles, France
Joined Jul 2008
Looks good!
I would like to see more build pictures of it if you have some!
ADB2 is offline Find More Posts by ADB2
Old Oct 28, 2008, 08:40 AM
springer is offline
Find More Posts by springer
treefinder
springer's Avatar
SE MI
Verrrry interesting! a really different spin on the foamy idea. I like the "structure" think I'd leave it open/unskinned. Although more aero with skin, but you don't want a speed demon for ap.
springer is offline Find More Posts by springer
Old Oct 28, 2008, 02:29 PM
Steve Mills is offline
Find More Posts by Steve Mills
Steve Mills's Avatar
England
Joined Dec 2005
Thank you Bob... food for thought.
Steve Mills is offline Find More Posts by Steve Mills
Old Oct 28, 2008, 06:06 PM
Gwelan is offline
Find More Posts by Gwelan
Peakaboo!
Gwelan's Avatar
Sakinee, Canada
Joined Sep 2004
I love it !!!
I will be following your next posts with attention.
Gwelan is offline Find More Posts by Gwelan
Old Oct 28, 2008, 06:08 PM
Gwelan is offline
Peakaboo!
Gwelan's Avatar
Sakinee, Canada
Joined Sep 2004
It will be easy to balance with a wide range of camera size. Simply beautiful !
Old Nov 01, 2008, 06:45 PM
Ithaca, NY USA
Joined Oct 2000
Well I'm happy to report the maiden flight was a resounding success. When I got to the field, it seemed reasonably calm, but the wind picked up as I was assembling the plane. As I held the plane up, it felt very buoyant like it wanted to fly, so what the heck. Gave it a toss and with maybe 1/4 throttle it went climbing. Nice and stable, though I had to hold in some control pressure.
Shut down to tweak the power-off trim, then gave it full throttle: this turns out to be my only model that climbs vertically (or close to it). And, I have learned that without a camera, the glide speed is about 15 miles per hour. I know this because with power off, it held it's position in the sky for at least 15 seconds, and even moved backwards very slowly There happens to be a weather station less than a mile away, and it reported about 15 mph max wind speed during the time I was flying.
I'll need to do more testing and adjusting in calm conditions, but this model has exceeded my expectations. It should provide a very capable load capacity and be very stable.
-Bob
Old Nov 24, 2008, 05:21 AM
Cybernaught is offline
Find More Posts by Cybernaught
Onward through the fog.
Cybernaught's Avatar
Bohol Philippines
Joined Aug 2008
-Bob
NIce work Bob!
Looks very interesting. Kind of like a seletonized Slow-Fly Pushycat I tend to be drawn in by the unorthodox. I don't suppose you have in-flight pictures or a vid do you?
How's the control response with the "A" tail and can you give me an idea of the tail area compared to the wing area and the approximate angle at the apex of your inverted vee??
Steve.
Cybernaught is offline Find More Posts by Cybernaught
Old Nov 24, 2008, 06:56 AM
FlattyFlier is offline
Find More Posts by FlattyFlier
Team LightRC
FlattyFlier's Avatar
Joined Dec 2003
Looks like if you covered the fuselage it would make a good seaplane from the nose's shape.
FlattyFlier is offline Find More Posts by FlattyFlier
Old Nov 24, 2008, 03:00 PM
LittleG is offline
Find More Posts by LittleG
LittleG's Avatar
Raleigh, NC
Joined Jan 2007
Interesting design... Post videos of it in action... I like to see how well it flies.
LittleG is offline Find More Posts by LittleG
Discussion New Build: Twin Boom Inverted V-Tail AP Foamie w/Magpie AP Wing SpinningInPres Aerial Photography 16 Sep 12, 2008 09:30 AM
Twin Boom Inverted V-Tail Polyhedral Pusher Qrome Parkflyers 10 Aug 05, 2005 12:11 PM
help with inverted v-tail trim corosplat Modeling Science 7 Jun 25, 2003 07:06 AM
inverted v-tail opualuan Power Systems 9 Nov 16, 2001 03:26 PM
