Old Oct 27, 2008, 01:02 AM
masa is offline
Find More Posts by masa
masa's Avatar
Japan
Mini-HowTo
Gaui GU-365/Trex500
I put GU365 on Trex500. GU365 shows very good performance now.
Because I tested it in various ways, I decide to introduce it to here.
I am weak in English. Please allow for me not to have enough explanation.
This is my Trex500 it had flybar.
http://www.rcgroups.com/forums/showthread.php?t=817122
masa
masa is offline Find More Posts by masa
Old Oct 27, 2008, 01:22 AM
FrankW is offline
Find More Posts by FrankW
Danger! Danger!
FrankW's Avatar
Portland Intl, Oregon, United States
Joined Dec 2002
Very interested in your flybar conversion. Do you have more pictures of the rotorhead? Any video of it flying?
I'm looking to convert my 500 to flybarless when I have the funds available, but I'm still leaning heavily towards the Mikado system.
-Frank
FrankW is offline Find More Posts by FrankW
Old Oct 27, 2008, 01:32 AM
masa is offline
masa's Avatar
Japan
-Frank
Frank
There is all in my PC. Please wait slightly till I contribute all.
GU365 is cheap, but works well.
masa
Old Oct 27, 2008, 01:38 AM
masa is offline
masa's Avatar
Japan
I was connected from swash to the rotor grip directly first. I changed servo arm length to 13mm from 16mm.
I was not able to raise Gain enough. In addition, the cyclic was very sensitive.
I understood that this method was difficult by illustrating it. I understood need to change the ball position of the grip greatly.
Old Oct 27, 2008, 01:58 AM
masa is offline
masa's Avatar
Japan
Therefore I decided to go through a mixing arm.
Ball link position of a mixing arm is 15mm and 25mm.
By using mixing arms, I can get servo movement enough.
The washout base does top and bottom upside down. And it is fixed only in three Orings.
I carryed out these methods in trex600(SK360) too.
Old Oct 27, 2008, 02:15 AM
masa is offline
masa's Avatar
Japan
I understood that GU365 caught the influence of vibrating very much.
I tried a lot of double-stick tape. I changed size or how to put on and tested it. It did one solution to put double-stick tape thick.
In addition, it was effective very much to use weight according to the manual.
Here is the video at this point in time.
http://eyevio.jp/movie/182222
Swash Mix Air/Ele/Pit=60/50/60
EXPO 10%/0%=Nomal/IdleUP
Aileron gain :90 degfrom 0.
Elevator gain :100 degfrom 0.
It was not very bad, but I felt need to get Gain a little more.
Old Oct 27, 2008, 02:27 AM
masa is offline
masa's Avatar
Japan
this is latest anti-vibration method on my T500.
This effect was very splendid, and I was able to raise Gain easily.
As a result, Trex came to be very stable.
In addition, GU365 is affected by the difference of the main rotor very much.
I tested four kinds of main rotors, but a 465mmCF blade of HIROBO was the best.
So,I do not need another SK360 for T500.GU-365 works enough for me.
masa
Old Oct 27, 2008, 12:30 PM
aaronredbaron is offline
Find More Posts by aaronredbaron
Spektrum Dev Team
aaronredbaron's Avatar
United States, IL, Champaign
Joined Apr 2002
cool! thanks for posting! Have you ever tried Zeal tape? http://www.heliproz.com/prodinfo.asp?number=138006
I have found this stuff to be my favorite for tail gyros, maybe it would be worth a try (??)
aaronredbaron is offline Find More Posts by aaronredbaron
Old Nov 05, 2008, 07:26 PM
masa is offline
masa's Avatar
Japan
I have not used the ZEAL tape. GU365 is much affected by the double-sided tape. The tape for gyros is worth trying it. But I finally thought the stock tape to be one of the best.
masa
Old Nov 05, 2008, 08:28 PM
masa is offline
masa's Avatar
Japan
In Flybarless system, it is important that how reduce the slop.
This is eazy method for T500 swash plate to reduce the slop.
Old Nov 06, 2008, 09:41 AM
blade strike is online now
Find More Posts by blade strike
DJI Testing / US Support
blade strike's Avatar
United States, CA, Big Bear
Joined Jan 2006
More important is to get your direct links to blade grips at 90. I would reconsider your setup. Then slop comes into play... and with using mixing arms you will have alot more slop than direct link. Spend the $70 and get a head conversion IMHO!
blade strike is online now Find More Posts by blade strike
Site Sponsor
Latest blog entry: Dji m600
Old Nov 06, 2008, 06:58 PM
masa is offline
masa's Avatar
Japan
Thank you for advice. As for me, 100% understand that you say.
Please understand it. In my flight skill, my priority is different from you.
I tested it in various ways, but do not think that the difference of the delta three effect is important. In addition, I do not think that the play of the mixing arm origin is the most important.
Sorry abot negative answer.
My T500(GU-365) and T600(SK360 show good performance by using the mixing arm. I am not an expert, but I think that they show enough performance for many RC-heli users without additional investment.
Furthermore, I am doing various tests,and I enjoy them. As for using money for Flyberless head, low-priority for me.
I try a direct link now. It satisfies approximately 100% things that you say in linkage. The head of Gaui and mikado does not satisfy your theory 100%.
masa
Old Nov 06, 2008, 07:43 PM
masa is offline
masa's Avatar
Japan
Using mixing arm with Gu365 show good paerfomance for stable mild 3d.But I want more quick cycric and quick pitch response for my T500 with Hirobo465.
1.Using short pivot balls for swash plate.
2.0 delta three hinge.
3.True 90 degree linkage from swash to main blade grips.
4.Nearer right angle servo linkage.
5.Adding weight is effective.
6.GU365 is sensitive to overreaction of rudder servo. When you use 6V BEC, add a step down regulator to get high gyro gain.
Stock(with Flybar) :
Swash servo horn length :16mm(S9650)
Swash mix:Air/Ele/Pit=75/65/60
Flybarless with mixing arm:
Swash servo horn length :13mm(S9650)
Swash mix:Air/Ele/Pit=75/65/65
GU365 gain:Air/Ele=180-225 degree/150-180 degree from 0
Flybarless without mixing arm:
Swash mix:Air/Ele/Pit=55/55/43
Picth:Collective -15/+15,Cycric -11/+11
GU365 gain:Air/Ele=135 degree/135 degree from 0
TailGyro gain(FUTABA12FG,S9257)
6.0 V : Nor/IdlUp=60/50
5.1 V : Nor/IdlUp=90/70
Note!:
I'm very satisfied now.But,I think that this method needs special main blades,such as Hirobo 465mm.GU365 is very sensitive to main blades,which you use.If you can't get enough gain,you must better to use mixing arm or buy another flybarless head.
masa
Old Nov 07, 2008, 09:20 AM
Joined Jan 2006
masa
No problem man, I am happy that you are happy
Site Sponsor
Old Nov 07, 2008, 02:34 PM
desert_flyer is offline
Find More Posts by desert_flyer
Volts < Amps
desert_flyer's Avatar
USA, UT, Salt Lake City
Joined Feb 2007
I guess this will be the entertaining side of Gaui/Assan etc. producing cheap flybarless gyros - we're going to be seeing a lot of interesting el cheapo head/rotor hacks.
desert_flyer is offline Find More Posts by desert_flyer
Discussion GAUI GU-365 Flybarless E-Stabilizer System Thread fung Micro Helis 422 Apr 18, 2010 05:16 AM
Discussion Gaui Flybarless E-Stabilizer GU-365 borneobear Electric Heli Talk 6 Oct 07, 2008 03:08 PM
