Old Oct 26, 2008, 06:45 PM
Seahawk82 is offline
Find More Posts by Seahawk82
Joined Mar 2007
9303 2.4 how do I switch my lever settings
I fly Sailplanes and currently have my 9303 set for right lever as Motor and left lever as camber
I would like to switch them so camber is on right lever and throttle for motor is on left lever but do not how to switch the settings for the levers
my "Device Sel" screen is currently :
Speed ___Laun___Moto___Flap___Aux 2___Aux 3___Aux 4
R3P_____L#P____Aux 4__Flap___Aux 3___Aux 3___Aux 4
SW______SW___SW_____Lev___Lev_____Lev_____Sw
____TRIM:com__out:INH____Act___Act___Act____Act
any ideas how to reverse the lever settings
Any help appreciated
thanks
Allan
Seahawk82 is offline Find More Posts by Seahawk82
Old Oct 26, 2008, 06:50 PM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Have you tried changing things in the Device select menu?
It is accessed from the System Menu.
I think you can do what you want in there.
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Old Oct 26, 2008, 06:52 PM
pmackenzie's Avatar
Joined Dec 2002
Now that I read your post more carefully, you are obviously already in the DEV SEL menu
You just scroll to the item you want to change and press the scroll wheel.
The new options for each function should be there.
Pat MacKenzie
Old Oct 26, 2008, 07:48 PM
Joined Mar 2007
I copied the original settings from someone else as a guide to set up my sailplane
after some tweaking
I think I got it
by looking at the monitor screen I exchanged flap lev and Aux 3
my "Device Sel" screen originally :
R3P_____L3P____Aux 4__Flap___Aux 3___Aux 3___Aux 4
new screen
R3P_____L3P____Aux 4__Aux3___Flap ___FLap ___Aux 4
it seems to have worked ...not sure why the "Moto " remained untouched .....
and why Aux 2 and AUX 3 are set on the same switch ?
something in this menu is not clear to me ....
Allan
Old Oct 26, 2008, 08:08 PM
pmackenzie's Avatar
Joined Dec 2002
That DEV SEL screen is pretty powerful, and can be confusing.
Just keep fiddling till you get everything to work as you want.
Things you are not using can be left set "wrong".
Make sure the prop is not on the plane while you fiddle!
You can also use the MONITOR screen to see what is going on instead of powering up the plane.
Pat MacKenzie
Old Oct 26, 2008, 09:18 PM
Joined Mar 2007
thanks seems I found it
by trial and error
clearly not due to me even remotely understanding of the on screen descriptions
oh well..
off to test fly
Allan
Discussion Is it normal for my JR 9303 2.4 to buzz? Tumbler Radios 2 Sep 15, 2008 09:50 PM
Question How do i modify my 4 in 1 receiver? omloro DIY Electronics 3 Jan 22, 2007 01:09 PM
Question Pet project:How do i modify my 4 in 1 receiver? or do i need to? omloro Modeling Science 1 Jan 22, 2007 11:10 AM
How do I fix my XP-4 elevator, its warped RandyK1 Hand Launch 11 Aug 02, 2005 06:43 AM
Help! How do I retime my 6327 Graupner Speed 480 race motor for a gearbox. Joe Elston Electric Plane Talk 6 Apr 20, 2001 11:56 AM
