Old Oct 25, 2008, 11:38 PM
jnyoun is offline
Find More Posts by jnyoun
Spritual Pilot
Silicon Valley, CA
Joined May 2001
Question
Tail servo at hobbycity.com. Recommendation?
I am going to buy some stuff from hobbycity.com soon. One of them I am considering is a 'tail servo'. Could you recommend a good tail servo in hobbycity.com? Of course, with similar performance, cheaper is better.
Currently, I am using 'hitec 56HB' in tail of the SJM400. It seems the tail is not solid... I am not sure whether it is because of the servo or not. However, I am going to try. The gyro is a 'telebee'.
Thanks.
jnyoun is offline Find More Posts by jnyoun
Old Oct 26, 2008, 12:08 AM
Slyster is offline
Find More Posts by Slyster
Google 'Blade 400 bible'
Slyster's Avatar
Joined Nov 2006
My only comment is that it's not the servo that's causing your tail to be not solid.. I have a Blade 400 and a Futaba 401 gyro and a HB65 on the tail an it's a ROCK!
BUT... I am interested in this same question since I still want a more tail designed servo for my heli as I am will be getting into more 3D stuff next summer.
Slyster is offline Find More Posts by Slyster
Old Oct 26, 2008, 12:16 AM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
KCinNC's Avatar
United States, NC, Mooresville
Joined Aug 2007
Originally Posted by jnyoun
cheaper is better.
only on a cheap Heli.....don't skimp on the tail servo/gyro
KCinNC is offline Find More Posts by KCinNC
Old Oct 26, 2008, 12:20 AM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
dido
mhills51 is offline Find More Posts by mhills51
Old Oct 26, 2008, 12:32 AM
jnyoun is offline
Spritual Pilot
Silicon Valley, CA
Joined May 2001
I have two gyros, Futaba GY401 and Telebee.
I am using the GY401 in my HBFP. SJM400 has the 'Telebee'. I know I have to swap the gyros. However, if I use the telebee in my HBFP, the tail is wagging. With the telebee, I need to upgrade the tail to direct drive which I don't want to do. With the GY401, the HBFP tail is solid with stock tail setup.
Now, the SJM400 has 'Telebee'. I heard many times in this rcgroup that Telebee gryo is solid in T-tex 450. It should work well with SJM400 too. However, I have a tail wagging problem with this gyro. That's why I am trying to change the servo.
Complicated...right?
Old Oct 26, 2008, 12:36 AM
grnbrg is offline
Find More Posts by grnbrg
Still a n00b.
grnbrg's Avatar
Winnipeg, Canada
The GWS Park HPX servo works nicely for me on my Blade 400 w/ stock G110 gyro.
Weight: 19g
Speed: (4.8v: 0.07sec)(6v: 0.05sec)
Torque: (4.8v: 3kg)(6v: 3.6kg)
Price: $12.35
Fast and strong, if a bit heavy. You'll need to boom mount it, more than likely.
grnbrg.
grnbrg is offline Find More Posts by grnbrg
Old Oct 26, 2008, 10:11 AM
kiteman78 is offline
Find More Posts by kiteman78
Canada, ON, Simcoe County
Joined Oct 2007
Have this servo with a Logictech 2100t and it is awesome. Price is double what it used to be though.
HDG 201 digital
kiteman78 is offline Find More Posts by kiteman78
Old Oct 26, 2008, 11:30 AM
jnyoun is offline
Spritual Pilot
Silicon Valley, CA
Joined May 2001
Can I use a digital servo with the telebee gyro?
Old Oct 26, 2008, 02:57 PM
BowerR64 is offline
Find More Posts by BowerR64
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
I agree, i think he needs to try some other things. Move the linkage around on the holes in rate mode and readjust the gain.
What i find is when i use a hole on the servo horn close to the horn mounting screw i need alot more gain like 70-80% when i move it out further from the screw i need less gain.
BowerR64 is offline Find More Posts by BowerR64
Old Oct 26, 2008, 04:30 PM
JustinMoore12 is offline
Find More Posts by JustinMoore12
JustinMoore12's Avatar
USA, VA, Woodbridge
Joined Sep 2007
The servo Kiteman linked to is probably a clone of the logitech servo. I know first hand the LT servo holds very well. Put the 401 on the SJM and get a decent servo (used 9650 is a good canidate)
JustinMoore12 is offline Find More Posts by JustinMoore12
Old Oct 26, 2008, 10:39 PM
asw20rr is offline
Find More Posts by asw20rr
Real wings, RC rotors
asw20rr's Avatar
Colorado
Joined Oct 2007
HDG 201 digital
Whoa, it did more than double! I bought one a couple weeks ago for like $19. So far I am liking it in my Dragonus.
- Doug
asw20rr is offline Find More Posts by asw20rr
Old Oct 26, 2008, 10:43 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
- Doug
If you log in the price will be much better.
The HG servos are probably the best servos HC sells.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Oct 26, 2008, 11:04 PM
asw20rr is offline
asw20rr's Avatar
Colorado
Joined Oct 2007
Pat MacKenzie
LOL - I forgot you have to be logged in to see the good prices.
Old Oct 26, 2008, 11:43 PM
Gino CP is offline
Find More Posts by Gino CP
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
Your Telebee is the weak link. Keep the HS56HB and change the gyro instead. There are better gyros out there...
GY401
Logitech
Hitech
Spartan
S J G D P G - 800
Gino CP is offline Find More Posts by Gino CP
Discussion Whats the best tail servo for E Trex 600 at 5 volts? djdaveq Electric Heli Talk 20 Jul 30, 2008 11:14 PM
Help! Tail Servo Arm Not At 90*, What Should I Do?! Minimole Mini Helis 9 Apr 07, 2006 01:43 AM
Discussion [TREX] Mounting tail servo at the end of tail? thanhTran Mini Helis 26 Jan 22, 2006 03:20 PM
Sale at x10.com for DIY aerial video yb2normal Power Systems 5 Jul 09, 2001 10:49 AM
Filip E Rear Mounted Tail Servo Jon Baker Electric Sailplanes 1 Jun 27, 2001 10:11 PM
