This thread is privately moderated by CGReload, who may elect to delete unwanted replies.
Old Oct 25, 2008, 02:40 PM
CGReload is offline
Find More Posts by CGReload
Trader Rating: 62
Registered "e" Flyer
CGReload's Avatar
Monterey Park, CA
Joined Dec 2007
Trader Rating: 62
Sold
E-Flite 60-Amp Pro Switch-Mode BEC Brushless ESC $65 Shipped
Hey guys,
I have this 60-Amp Pro Switch-Mode BEC Brushless ESC from E-flite taken from my DHC-2 Beaver which only had 6 flights, it is in great "like new" condition.
Specs below,
Key Features
Up to 60A continuous current with proper air flow with 75A peak
5V Switch-Mode BEC circuit capable of 2.5A continuous current on any recommended input voltage
Drives up to 7 analog or 6 digital standard-sized servos, with the BEC on any recommended input voltage
3–6S Li-Po, 9- to 18-cell Ni-Cd/Ni-MH input voltage
Finned heat sinks
Programmable motor braking
Safe power-arm mode prevents accidental starts
Programmable low voltage cutoff with settings for 3-cell Li-Po (9V), 4-cell Li-Po (12V), 5-cell Li-Po (15V), 6-cell Li-Po (18V), or 70% of battery starting voltage
Programmable soft start for helis and airplanes
Auto motor shut down if signal is lost or there is interference
Programmable timing—5 user-selectable ranges for use with a larger variety of brushless motors
Programmable throttle input range (1.1–1.9 ms or 1.2–1.8 ms)
Utilizes new smaller MOSFETs technology to minimize weight
Radio System Power On/Off Switch
Optional RS232 Serial Link available for programming
Pre-wired connectors—E-flite EC3 on battery input and 3.5mm female gold bullets on motor output leads
Specs
Brake:Yes - Programmable
Continuous Maximum Current:60A with reasonable cooling
Input Voltage:10.82–2.2V
Input Connector Types:13 AWG with E-flite EC3 connector
Output Connector Types:13 AWG with 3.5mm Female Gold Bullet Connectors
Momentary Peak Current:75A (15 sec)
Dimensions (WxLxH):76x33x13 mm (3x1.3x.5 in)
Weight:66 g (2.3 oz)
Wire Gauge:13 AWG
Cells w/BEC:3-6S Li-Po or 9-18 Ni-MH/Ni-Cd
I will let it go for $65 Shipped
Paypal only, CONUS
CGReload is offline Find More Posts by CGReload
Old Oct 26, 2008, 04:50 AM
hitem is offline
Find More Posts by hitem
Trader Rating: 50
United States, NM, Bernalillo
Joined Feb 2007
Trader Rating: 50
I take it, Pay Pal info please.
hitem is offline Find More Posts by hitem
Old Oct 26, 2008, 02:45 PM
CGReload is offline
Trader Rating: 62
CGReload's Avatar
Monterey Park, CA
Joined Dec 2007
Trader Rating: 62
sent reply
Old Oct 26, 2008, 06:56 PM
hitem is offline
Trader Rating: 50
Joined Feb 2007
Trader Rating: 50
Pay pal on it's way.
Sold NIB E-flite 60-Amp Pro Switch-Mode BEC Brushless ESC Heat Sink Aircraft - Electric - Power Systems (FS/W) 2 Oct 10, 2008 12:27 PM
Sold 60-Amp Pro Switch-Mode BEC Brushless ESC by E-flite ultimate lvr Aircraft - Electric - Power Systems (FS/W) 3 Jul 24, 2008 06:32 PM
Sold E-flite 25-Amp Pro Brushless ESC chuckpee Aircraft - Electric - Power Systems (FS/W) 0 Jul 22, 2008 01:39 PM
Found E-flite 10-Amp Pro Brushless ESC EFLA1010 nitrodude71 Aircraft - Electric - Power Systems (FS/W) 3 Feb 03, 2008 08:29 AM
For Sale E-Flite Park 300 Brushless Motor and E-Flite 10 Amp Pro ESC! 1 use each! RCisAddicting Aircraft - Electric - Power Systems (FS/W) 0 Apr 03, 2007 05:11 PM
