Old Aug 20, 2012, 06:31 PM
Rickflaguy is offline
Find More Posts by Rickflaguy
United States, FL, West Melbourne
Joined May 2011
Firefly Mount
This worked really well. Add a washer or two to adjust thrust angle.
Rickflaguy is offline Find More Posts by Rickflaguy
Old Aug 21, 2012, 11:22 AM
Jefte is offline
Find More Posts by Jefte
Fly Low Fly Fast
Jefte's Avatar
United States, FL, Melbourne
Joined Sep 2010
Nice mod Rick!
Weighing in on the spar question: it depends on the foam used. I found epp to be too floppy without spars for my taste and wind conditions I fly in. With stiffer foams or different batches of epp your mileage may vary.
Jefte is offline Find More Posts by Jefte
Old Aug 21, 2012, 01:49 PM
Flyboy Steve is offline
Find More Posts by Flyboy Steve
Joined Nov 2007
I have found that a composite build can have the best of both worlds. I've built foamies like this with an EPP "core" and used fan fold polystyrene for the KF layers.
The fan fold is stiffer but more prone to break in response to "pilot error".
The EPP is more forgiving, but floppier.
The two TOGETHER give me a structure that is both stiff and impact resistant.
Fiberglass tape on the leading edge also helps to stiffen the structure, and protects the LE's....
Flyboy Steve is offline Find More Posts by Flyboy Steve
Old Aug 21, 2012, 03:42 PM
Joined Nov 2007
Rick, what it the lower plate made out of?
That's a GREAT way to mount and have the thrust angle adjustable.
Steve
Old Aug 21, 2012, 04:15 PM
Joined May 2011
Steve
Thin sheet of bass wood. Light ply would work. I glued the plate to the foam which distributes the force. I used two 3mm socket head black screws and then the black strip determined the color.
If I was to paint a different color I might pick up some fusion (plastic) paint or testors paint and paint the mount first. I picked up the mount at HURC
http://www.headsuprc.com/servlet/the...nts/Categories
where they only charge $2 for shipping. Quick too. Hollow plastic. You remove the firewall mount and stick the motor in. Quick motor change too.
Old Aug 23, 2012, 02:41 PM
stallion explosi is offline
Find More Posts by stallion explosi
United Kingdom, England, Hackney
Joined Aug 2011
I souped up my firefly - I've mounted a funfighter motor. Tried it today ith a 4s 1000 mah nanotech lipo.
It works! But boy is it loud. Like REALLY loud. But great fun though!
Firefly scratchbuilt rc plane with 4 cell lipo battery and funfighter motor (1 min 22 sec)
stallion explosi is offline Find More Posts by stallion explosi
Old Aug 24, 2012, 02:14 AM
bentoad is offline
Find More Posts by bentoad
bentoad's Avatar
Melbourne,Fl
Joined May 2008
Firefly flies squirlley
]I built a 16" FF with foamboard. I used carbon fiber for a spar and bamboo skewers for supporting the tail. I used elevon and ruddder. I didn't like the flexing of the tail .I probably have it overpowerd. 31 oz thrust with a hand wound E Max 2208. 54 grams. I just finished winding a MP JET with 20 oz thrust at 34grams. That might work but I gave MY FF to a friend thad has a lighter power set up. will see how it flies before I attempt another. I flew FLYGUY RICKS and it flew pretty good but I don' like any expos in my plane .(personal pref)His adjustable mount is interesting.He turned me on to a " CHEAP N EASY" and I put in one of my E/MAX specials and did a destruct test video. this was a blast to do.
DESTRUCT TEST A CHEAP N EASY (7 min 5 sec)
bentoad is offline Find More Posts by bentoad
Old Aug 24, 2012, 06:55 AM
Cherokee Flyer is online now
Find More Posts by Cherokee Flyer
Cherokee Flyer's Avatar
United States, KS, Rose Hill
Joined Sep 2007
Looking at where the battery is and the size I would venture it is tail heavy and heavy and they don't fly well like that, not at all!!! C/G needs to be atleast 8.5" from the nose. Do you have the doubler on the bottom, that also effects the airfoil.
L.
Cherokee Flyer is online now Find More Posts by Cherokee Flyer
Old Aug 24, 2012, 07:07 AM
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
L.
Bentoad states that his FireFly is a 16" span. The cg has to be adjusted proportionately. 16/24 x 8.5 = 5.7 inches from the nose.
Swap the Rx and battery positions and itmight be pretty close.
leadfeather is online now Find More Posts by leadfeather
Old Aug 24, 2012, 08:24 AM
Joined May 2011
I am not 100% sure but I believe his was a 24" He flew mine. If anyone has not seen his cheap N easy video you are missing out on a rare treat. His motor was a bit heavy too.
I't ask the new owner what size the Firefly was.
Old Aug 24, 2012, 08:31 AM
Joined May 2011
Old Aug 24, 2012, 08:33 AM
Winging it >
Joined May 2006
In Bentoad's post #2842 he states a 16" FF.
Old Aug 25, 2012, 11:13 AM
Joined May 2011
I think he made the 24" but with no kf on the bottom. Not sure of the length but he told me this AM about the KF.
Old Aug 27, 2012, 05:47 PM
rcrich is offline
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
flying at the beach with the fire fly (2 min 38 sec)
at the beach with my travel fire fly
rcrich is offline Find More Posts by rcrich
Old Aug 27, 2012, 07:21 PM
Marty Slater is offline
Find More Posts by Marty Slater
Ceder Rapids,Ia
Joined Jan 2007
very nice rcrich
Marty Slater is offline Find More Posts by Marty Slater
