Old Oct 24, 2008, 09:38 PM
missle is offline
Find More Posts by missle
missle's Avatar
West Chester, Ohio
Joined Nov 2006
Help!
How to measure resistance of a motor
Like the title states, i want to measue the resistance of a motor (and even lipo bats) cause I've got a chinese motor and don't know it's resistance. Could you break it down real simple. I've got one of those voltage/resistance things you can buy at a hardware store but have no clue how to use it properly. I'm not looking for "exact" figures but would like to have some value to put into Motocalc. BTW, it's a 600kv motor that's suggested to have 6S lipo with 14x9 prop for watts in the 1300 range. Thanks
missle is offline Find More Posts by missle
Old Oct 24, 2008, 11:59 PM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
You can measure your motor's DC resistance with a multimeter, but not directly, because the value will be very low (~0.05 Ohms). To get sufficient resolution you need to feed about 1 Amp into a motor winding, while measuring the voltage across it. If the current is exactly 1A then the resistance equals the voltage. If the current is not exactly 1A then you can apply Ohm's Law (Resistance=Volts/Amps).
The tricky bit is, how do you get a known current of about 1 Amp? You will need a stable power supply (eg. 12V car battery) and a high power resistor of the correct value (12 Ohms for a 12V supply). If you can't get an appropriate resistor then you can use a light bulb (eg. 10~15W auto bulb). To find out how much current the resistor/bulb draws, connect it to the power supply and in series with your multimeter set to its 10A range. Record the measured value. Now switch the multimeter to its lowest voltage range (eg. 200mV) and connect any two of the motor leads in series with the resistor/bulb. Measure the voltage across the motor leads. For greatest accuracy the multimeter probes should be placed directly onto the motor wires or bullet plugs (otherwise you will also be measuring the resistance of the connections!).
However, DC resistance is not what Motocalc wants! It needs the Dynamic Resistance (Rm), which can only be determined by measuring Volts, Amps and rpm with different loads. Therefore I recommend using a Wattmeter and tachometer to obtain the necessary data. If this is not practicable then multiply the DC resistance by about 0.8 to get a reasonable guesstimate (eg. if you measured 0.05 Ohms then use 0.09 Ohms in Motocalc).
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Oct 25, 2008, 07:27 AM
missle is offline
missle's Avatar
West Chester, Ohio
Joined Nov 2006
Bruce, you definately da man! Thanks so much.
Old Oct 25, 2008, 09:02 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Or, do a search for Mumtats; it a spreadsheet that calculates all of a motor's paramters from a few tests.
DriveCalc is very good too; but no Rm -- its not needed!
jrb is offline Find More Posts by jrb
Old Oct 25, 2008, 09:03 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Links to Mumtats and Drive Calculator in this e-flight calculator compilation:
http://www.rcgroups.com/forums/showthread.php?t=943538 (sticky in this forum)
Prettig weekend Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Oct 25, 2008, 01:54 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Jim,
Isn't "Rd" in Drive Calc the same as Rm: - I have used Motocalc and Drive Calc for certain motors and the Rm from Motocalc and Rd from Drive Calc are essentially the same.
Here are a couple of Drive Calc graphs;
For the 28-37-3 Motocalc gave Rm = 0.10 ohms: Drive Calc Rd = 0.103 ohms
For the 28-47-1.5 Motocalc gave Rm = 0.045 ohms: Drive Calc Rd = .0433 ohms
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Oct 25, 2008, 04:01 PM
Alan Hahn is offline
Find More Posts by Alan Hahn
Chicago 'burbs
Joined May 2006
Here's how I do Lipo's.
Set up the lipo with a Watt-meter, ESC, and motor. Choose a prop that loads down the motor, but I recommend something smaller than you normally fly with, just to make sure you don't overheat things.
Run the setup at WOT for 10-20 seconds, and note the voltage and current call them Von and Ion), then pull the throttle to zero. On the Watt-meter you will notice the voltage quickly jumps upwards to a more or less steady value---note its value (="Von"). I calculate the lipo pack resistance (=Rpack) to simply be
Rpack=(Voff-Von)/Ion.
For cells in series, the individual resistance is just the Rpack/#cells. For cells in parallel, multiply by the number of cells.
I seem to get values which are similar to those given by the manufacturer.
This is easier with a data recorder of course--just because the battery voltage and current is changing pretty fast under load, but you should be able to get reasonable values with the watt-meter.
Alan Hahn is offline Find More Posts by Alan Hahn
Discussion How to Measure Motor Resistance? asm_ Power Systems 16 Oct 08, 2006 03:56 AM
How to measure no load current of a brushless motor? Hovertime Power Systems 21 May 23, 2004 08:28 PM
How to measure motor constants Danal Estes Power Systems 5 Nov 16, 2003 07:30 PM
How to Measure Motor Kv?? Lhotta Power Systems 6 Nov 26, 2002 11:13 AM
How Do I measure resistance in a battery pack? Rob0101 Batteries and Chargers 8 Oct 24, 2002 02:52 PM
