Old Oct 24, 2008, 11:33 AM
dwreel is offline
Find More Posts by dwreel
United States, NC, Southern Pines
Joined Jan 2004
Help!
Engine Test Stand
I've seen several photos of the engine test stand that several clubs are useing at their fields. Does anybody know where I can find plans for one of these ?
Thanks in advance for any help.
dick.
dwreel is offline Find More Posts by dwreel
Old Oct 24, 2008, 12:13 PM
Zor is offline
Zor
Find More Posts by Zor
Zor
Ontario,Canada
Joined Feb 2007
dick.
Dick,
I cannot help you much right now. No time to search.
Just wanted to tell you that I have seen such a plan with drawings in this forum a few months ago. It was painted yellow and looked much like an enverted V stool with a wide top about a foot wide.
Now, if you see a picture of one you like, you can pretty well build one from the pic.
Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Oct 24, 2008, 03:49 PM
I TOBOR is offline
Find More Posts by I TOBOR
I TOBOR's Avatar
Joined Feb 2007
Zor, I think the one you saw was a common saw horse with a 2x4 flat across the top. I built my own and it has two 50 lb solid cement blocks built right into it. It has four pressure treated 4x4s for legs. Even my SuperTigre 4500 doesn't move it.
I TOBOR is offline Find More Posts by I TOBOR
Old Oct 25, 2008, 02:00 PM
Zor is offline
Zor
Zor
Ontario,Canada
Joined Feb 2007
HI I tobor,
No. It had a top with some width, not a 2 x 4.
Trying to remember a little better I think i was also illustrated sitting on a wheel carrier and could move around easily (when it was on the wheel carrier).
I'll try to find time later today and see if I can find it.
Here is a pic of my test bed .
Zor
Old Oct 25, 2008, 06:54 PM
rc_sjo is offline
Find More Posts by rc_sjo
Beaver Boy
rc_sjo's Avatar
Joined Nov 2001
One of these perhaps?
rc_sjo is offline Find More Posts by rc_sjo
Old Oct 25, 2008, 07:40 PM
EJWash1 is offline
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
I bought one of these a while back and mounted it on a folding steel sawhorse (Home Depot, $20, 18lbs) Yeah, it's pricey, but the last one I'll ever have to buy. Instead of buying the back mount for the gassers from PSP for $45, I bought a two foot long piece of 4" angle aluminum from the a metal supply for $10.00. I cut mounts for each of my four gassers.
http://pspmfg.com/EngineTestStandDeluxe.html
EJWash
EJWash1 is offline Find More Posts by EJWash1
Old Jan 13, 2009, 08:22 AM
Alumitech is offline
Find More Posts by Alumitech
Joined Jan 2009
Guys theres is something less expencive then a PSP MFG out there but great quality.. its new on the market it a All Aluminum RC test stand at http://www.ellisdrilling.com/6.html?sm=65875 this is a well thought out design that incorperates both styles of motors gas engines and nitro all in one . made out of 3/16 thick 5052 aircraft aluminum , I looked at psp .. and to do the same job it would cost aprox $150.00 to do both styles of motor .
there were options to go simple for just the stand using my own gas tank and motor mount for aprox $75.00 or go the full boat with everyting i needed for gas engines , nitro and using the add on servo set up to be able to use my radio for throttle ,insted of standing behind the unit and manualy operating the throttle .. this came in handy on my DA-150 I felt much more comfortable off to the side. and stayed clean. great break in stand in my opinion
You know the old story you get what you pay for .
Alumitech is offline Find More Posts by Alumitech
Old Mar 01, 2009, 06:38 PM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
Nice stands! I really need to get one.
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Mar 03, 2009, 02:05 PM
skysfallin is offline
Find More Posts by skysfallin
Rising Sun, Md
Joined Feb 2009
RC SJO Where did you get that engine stand? What a clean design and simple. Did you make it yourself or buy it? I need one!!!!!!
skysfallin is offline Find More Posts by skysfallin
engine test stand andramalech Fuel Plane Talk 4 Mar 25, 2005 09:34 AM
Simple Engine Test Stand Atlantis Engines 2 Feb 04, 2005 06:00 AM
Yippee! Wtb. Engine Test Stand dumbthumbs Aircraft - Fuel - Airplanes (FS/W) 3 Apr 30, 2004 03:49 PM
FS: CBA/Tatone Engine Test Stand w/Tank gromitvt10 Aircraft - Fuel - Airplanes (FS/W) 1 Mar 16, 2004 06:06 PM
