Old Oct 23, 2008, 09:08 PM
Brother2 is offline
Find More Posts by Brother2
from another mother
Brother2's Avatar
Plumas Lake, CA
Joined Nov 2007
A great fly day and estimating run time
I finally fixed up my MS composit boom. I got it hot glued back together and put a new e flite park 370 motor on it. I'm running 9x4.7E apc props and a 2S 610mah zippy battery.
I flew all three packs after work today. It flies well. I'm pretty much still in sport mode until I get the brain and thumbs a little more training. Thanks to all of those on this board who have helped. It was a blast. With the flaperons down, I can pretty much slow it to a few knots crawl. Awesome and light little plane.
1 question. Do you guys set your timers based on the max current draw or some percentage of that? I can kill the pack in about 4 minutes at full throttle. So I set my timer for 3:30, but I'm only putting about 250-350 mah back in to each pack. Do you just experiment or is there a quantitative way to do this?
Brother2 is offline Find More Posts by Brother2
Old Oct 23, 2008, 10:15 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Well, I wouldn't run the motor full throttle the whole flight. Try working the htrottle, like using half the majority of the time. You should be able to get 5 or so minutes then.
Xpress.. is offline Find More Posts by Xpress..
Old Oct 23, 2008, 11:10 PM
R/C_Addict is offline
Find More Posts by R/C_Addict
That's me.
R/C_Addict's Avatar
San Francisco Area, CA
Yeah, like Xpress says, you will run the throttle at about half for most of the flight. On my Airfoilz Yak, the motor pulls 19 amps and I'm using a Rhino 1050mah pack. At WOT, it could last about 3.3minutes. I set my timer for 5 minutes and that gives me time to land.
If you know how many amps the motor pulls you can do that math to find out about how much time you have.
R/C_Addict is offline Find More Posts by R/C_Addict
Old Oct 23, 2008, 11:39 PM
Brother2 is offline
from another mother
Brother2's Avatar
Plumas Lake, CA
Joined Nov 2007
I don't fly at full throttle the whole time. I tested the pack duration with the plane at full throttle. I'll bump up the time and see what I am getting. I think I put 400 mah back into the pack that I flew about 5 minutes on so that should be about right.
X250 on 8 X 600AE's (run time) Sluf7 Electric Plane Talk 7 Feb 15, 2002 02:07 PM
Average Run time Hornet & Pico mjsimon Electric Heli Talk 6 Dec 05, 2001 08:47 PM
A Great E3D Day!!! Mike Z Sport Planes 51 Nov 14, 2001 06:07 AM
Too short run-time. What's wrong ? jnyoun Power Systems 9 Jun 24, 2001 11:17 PM
800AR Run time in a Zagi 400 mt_100 Foamies (Kits) 13 Jun 19, 2001 12:10 AM
