Old Oct 23, 2008, 04:02 PM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
New Electrifly EP Sopwith Camel
I just noticed this one while searching the dealer site! How did I miss it? It looks pretty good!
turbonut is online now Find More Posts by turbonut
Old Oct 23, 2008, 10:58 PM
cadconversions is offline
Find More Posts by cadconversions
Around the World
cadconversions's Avatar
Scottsville, KY
Joined Jun 2002
I'm realling digging these old WWI fighters and the $69 price tag sale going on right now on a few of them are making it difficult to not hit the trigger.....
cadconversions is offline Find More Posts by cadconversions
Old Oct 23, 2008, 11:01 PM
Merkava is offline
Find More Posts by Merkava
Merkava's Avatar
Electrifly "great planes" are really cranking these things out...
I think there is already a thread about this Camel. I still think the Green Models / BP hobbies / whatever Sopwith Camel looks better, but how the fly is the real key.
Great planes also have a Sopwith Pup electric coming, but it is a foamy, not as scale and looks to be a R, E, T control scheme.
It is also mentioned in the other thread announcing this bird.
Edit... just found the post...
http://www.rcgroups.com/forums/showthread.php?t=941315
Merkava is offline Find More Posts by Merkava
Old Oct 23, 2008, 11:41 PM
Dora Nine is offline
Find More Posts by Dora Nine
The sky is my playground.
Dora Nine's Avatar
United States, NH
Joined May 2005
Ahh man. I take it you'll be carrying these Scott? When is the release date??
Dora Nine is offline Find More Posts by Dora Nine
Old Oct 23, 2008, 11:53 PM
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Hi John, yep on back order already! should be around the end of the month!
Old Oct 24, 2008, 02:07 AM
Dora Nine's Avatar
United States, NH
Joined May 2005
Hmm. What about the Rimfire motor?
<---Is looking for an excuse not to get it.
Old Oct 24, 2008, 03:33 AM
guapoman2000 is offline
Find More Posts by guapoman2000
Account closed
Joined Oct 2002
Rim Fire 28-30-950 has performed well in my Fokker DVII without any issues except a bad Hitec Electron-6 Dual Conversion Receiver that caused a crash during the first flight. Even though the crash, the motor has worked flawlessly.
However, another motor of same type and Kv, installed in my S.E.5a has had numerous instances of the Motor shaft exiting while the model in flight and I have been lucky not to crash my beloved S.E.5a as it floats down without any ugly stall manners. Numerous RC Flyers have had the same issue with the shaft coming out as the two rearward screws at the End Bell are the only thing keeping the output shaft from coming out.
Some here have used a machine tool to etch a notch on the output shaft itself where the two screws make contact and problem is pertty much solved as the screws now have a grove to rest on and provides much better gripping power during hard throttle use. I myself have not performed this modification and instead, I have used my Gorilla hands and a pyler to hold the screw driver and apply extra torque pressure and it seems to have helped in my case!
Hope this helps!
Carlos
guapoman2000 is offline Find More Posts by guapoman2000
Old Oct 24, 2008, 04:08 AM
Account closed
Joined Oct 2002
Here's my maiden flight with the Fokker DVII using the RIM FIRE 28-30-950.
http://media.putfile.com/Great-Plane...I-Full-Version
Old Oct 24, 2008, 08:06 AM
CyberJay is offline
Find More Posts by CyberJay
Rsetiegerd Uesr
CyberJay's Avatar
USA, AR, Cave Springs
Joined Apr 2005
I've got a himax 2812-0850 in my SE5 with a Xoar 10x5 electric wooden prop. I have nothing to compare it to, but I can say that it flies great. I have no desire to experiment any further. It doesn't have unlimited vertical but it does some nice long tail slides.
It's $55 vs $50 for the rimfire. But the Himax does come with a collet style prop adapter which I believe you need to buy separately with the rimfire. I did have to make a motor mount out of a piece of birch though. The rimfire should bolt right in.
-Jay
CyberJay is offline Find More Posts by CyberJay
Old Oct 24, 2008, 11:33 AM
Dora Nine's Avatar
United States, NH
Joined May 2005
guapoman2000: I was really just asking Scott if he had them in stock. I've got plenty of experience with the one I have in MY Fokker. Which works just fine
CyberJay: Any pics of that Xoar prop? I'm thinking a wood prop would look darn cool...rather than a plastic one painted brown.
Old Oct 24, 2008, 11:49 AM
CyberJay is offline
Rsetiegerd Uesr
CyberJay's Avatar
Joined Apr 2005
Sure thing. This is an older pic. I've got my pilot done and I put the exhaust on. Need to get a new pic I guess.
I also included a pic of the same prop when I had it mounted on my P-47.
-Jay
Old Oct 24, 2008, 03:14 PM
Dora Nine's Avatar
United States, NH
Joined May 2005
Thanks! That looks good. Definately gonna keep that route in mind. Do you remember what size hole that was for the prop adaptor? I think Xoar makes a vareity. Thanks!
Old Oct 24, 2008, 04:45 PM
CyberJay is offline
Rsetiegerd Uesr
CyberJay's Avatar
Joined Apr 2005
You know I don't remember. It fits perfectly on a park 450, might be SLIGHTLY loose on the himax adapter, but it's fine once you tighten it down.
-Jay
Old Oct 24, 2008, 07:50 PM
hpiguy is offline
Find More Posts by hpiguy
If it's R/C, it's all good.
hpiguy's Avatar
USA, WI, Wausau
Joined Jul 2005
RimFire 28-30 replacement for those not wanting a $50 that has stories of spittting shafts out for these planes, this is what I'm using in my DR-1 build:
http://www.hobbycity.com/hobbycity/s...idProduct=2112
With the Turnigy ESC and programming card, still under the price of one RimFire motor.
hpiguy is offline Find More Posts by hpiguy
Old Oct 24, 2008, 11:06 PM
Dora Nine's Avatar
United States, NH
Joined May 2005
What are you doing for mounting your motor? The Rimfire motor has a very specific 3 bolt mount as does the plane.
Discussion Lookout RED BARON !!New Sopwith Camel 60 Arrived! Coastwatcher Electric Warbirds 359 May 10, 2016 02:12 PM
Mini-Review New Powerline Hobbies/Green RC Micro Sopwith Camel Thomas B Parkflyers 11 May 31, 2012 11:10 PM
Build Log New AerodromeRC 1/9 Sopwith Camel sleonard Scale Kit/Scratch Built 15 Sep 14, 2006 05:22 PM
Sold Wattage SOPWITH CAMEL EP ARF punkindrublik Aircraft - Electric - Airplanes (FS/W) 2 Jul 12, 2006 09:15 AM
The new Ep Glider, "Terry" Yoda Dog Foamies (Kits) 1 Aug 06, 2001 09:26 PM
