Old Oct 23, 2008, 05:56 AM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Mini-Review
HY propellers
Hi
Some results concerning my first test of a HY (Haoye) propeller
Andre (ADB2) bought by Hobby King
Model 9x3.8 , blade shape in the style slow fly (elliptical shape)
Engravings:
Front : Hy 228.6 x 88.9 ; 9x3.8
Back : Haoye
weight 8.5 g
Colour : black
Material : ?? black nylon or some polymer ??
Surface a little "grainy" or "granited" (I don't know the right word in english)
Hole 6mm + partial 8.1 mm (for the ring)
5 Rings : OD 8.10 mm ; ID : 2.9 ; 3.1 ; 3.95 ; 4.9 ; 5.9 mm
I used the ring 5.9 mm on a 6mm collet adapter. Slightly "forcing" but good
The central external cylinder diameter is around 12.9 mm, so remaining meat in the central crown is (12.9-6)/2 = 3.4 mm
Cylinder axial height = 7.35 mm
General stiffness = comparable to GWS black HD props
I have tested on a Hacker A30-10L up to 12000 rpm, no problem
I have not tested airflow velocity nor spatial distribution.
Results are also translated in formulas .. see graphs
Note that absorbed power is not estimated from dyno testings
(I have none dyno bench)
Just via Power In minus losses (iron losses, copper losses, estimated ESC losses)
Louis
Fourdan is offline Find More Posts by Fourdan
Old Oct 23, 2008, 06:56 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
108,000rpm/diameter without disintegration - perhaps about the same as GWS HD, and a lot better than a 9x3.8 APC SF (stated limit 65,000rpm/diam). I wonder how it compares with an E-flite (those seem a bit tougher than APC SF).
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Oct 23, 2008, 07:30 AM
ADB2 is offline
Find More Posts by ADB2
Build, fly, learn!
Versailles, France
Joined Jul 2008
I have to say I really like the way Louis adjusts his formulas and parameters to get best curves fitting to measured data, having seem him doing it.
Here is the link to the prop:
http://www.hobbycity.com/hobbycity/s...dapters_(Black)
ADB2 is offline Find More Posts by ADB2
Old May 03, 2009, 06:47 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
Some more results on Haoye (Hy) propellers
Louis
Old Mar 05, 2016, 05:10 PM
santanig5 is offline
Find More Posts by santanig5
santanig5's Avatar
United States, NJ, Roxbury Township
Joined Nov 2014
Prop conversion
Hi, I have a Haoye propeller that reads 203 x 88.9 can anyone tell me what size this is in the U.S.?
santanig5 is offline Find More Posts by santanig5
Old Mar 05, 2016, 05:26 PM
AirBornOne is offline
Find More Posts by AirBornOne
I'm All Thumbs
AirBornOne's Avatar
S.F. Bay Area
Joined Aug 2002
http://www.metric-conversions.org/area-conversion.htm
AirBornOne is offline Find More Posts by AirBornOne
Old Mar 05, 2016, 05:38 PM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
203mm /25.4 = 8" (1 inch = 25.4mm)
Your prop is a 8x3.5 (inches)
The physical dimensions are the same in Europe, USA or China or anywhere in the world
meter, mm are "more international units" than "inch or foot"
Louis
Old Mar 06, 2016, 06:31 AM
santanig5's Avatar
Joined Nov 2014
THANKS Louis
