Old Oct 22, 2008, 08:27 PM
HMX Dave is offline
Find More Posts by HMX Dave
3DHS Koolaid Fan
Alberta, Canada
Joined Oct 2007
Help!
CMP Yak 54 question
Hey guys....converting this plane to electric and nearly finished. It has a 52" span and the wing cord is 12.25" where it attaches to the fuse. The manual says the CG is 80 to 90mm (3.125 - 3.5") measured out from the fuse 150mm (6"). It seems very nose heavy. This point falls about an inch forward of the thickest part of the wing. Any experience here? My gut tells me that 4" or so would be more realistic....
I would like to nail this down for sure as it is going to determine where I build the battery box and hatch on this beast.
HMX Dave is offline Find More Posts by HMX Dave
Old Oct 22, 2008, 11:03 PM
SCALEFAN is offline
Find More Posts by SCALEFAN
Done it all
United States, CA, Corona
Joined Feb 2006
Dave,
Whenever I have doubts, I use this on-line calculator.
Remember CG is not absolute, it is a range that will allow the plane to fly safely. If you change the MAC % you will see the range in your results. I use the average % that is suggested on the screen for MAC.
http://adamone.rchomepage.com/cg_calc.htm
Al
SCALEFAN is offline Find More Posts by SCALEFAN
Old Oct 22, 2008, 11:10 PM
HMX Dave is offline
3DHS Koolaid Fan
Alberta, Canada
Joined Oct 2007
Thanks! I'll get out the measuring tape tomorrow and see where she goes.
Old Oct 23, 2008, 11:27 PM
HMX Dave is offline
3DHS Koolaid Fan
Alberta, Canada
Joined Oct 2007
Well....it turns out the instructions are correct.
The most I can jam into the front is 2x 22004s (in parallel for 4400 4s) and I still had to add a few OZ's to get the CG .....but I got 'er. A bigger motor would probably be better for this plane...but I had everything laying around, so I'll try it this way for now. Should be 850w and 110 oz of thrust.....
Old Oct 24, 2008, 01:09 AM
Dbox is offline
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
In saw this one in the air and up close.Beautifull plane with fiberglass fuse.
But I doubt I want to convert this particular one to electric------IT IS HEAVY.
Needs lotsa speed and WAY more then 850W .
Yuri.
Dbox is offline Find More Posts by Dbox
Old Oct 24, 2008, 08:35 AM
HMX Dave is offline
3DHS Koolaid Fan
Alberta, Canada
Joined Oct 2007
It's just over 6 lbs with a 52" wing .....I'm sure it'll fly.
Old Oct 24, 2008, 01:20 PM
chalmrast is offline
Find More Posts by chalmrast
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
Oh I'm sure it will fly. 140 Watt's per pound may not let you hover at 1/2 throttle but I'll bet the power will be more than sufficient.
The wing-loading works out to 27 oz/sq foot so it shouldn't be too much of a handful.
I just can't believe a CMP plane came in anywhere near the published weight, especially an e-conversion!!!
850 Watts on 4S seems like alot of amps (57 or so?). Hope you've got a good ESC & cooling!!! Also, as amps go up, efficiency goes down so your watts out may be 10% less than your watts in, depending on the motor.
Good luck! Let us know how it goes!!!
Chad
chalmrast is offline Find More Posts by chalmrast
Old Oct 24, 2008, 03:50 PM
HMX Dave is offline
3DHS Koolaid Fan
Alberta, Canada
Joined Oct 2007
Thanks for the calculations Chad! I hope its just one of those "nice to fly around in circles" planes for lazy afternoons. The plan from the start was to just have a nice looking scale-type plane. The plane fell in my lap as a buddy ordered one on-line...his computer froze and he accidentally ordered two. So I said I would build a e-version from spare parts. I'm pretty sure this baby was never intended to be a 3D Yak54....the manual's suggested throws are pretty short. I have an E-flite 60a switching ESC runiing the Scorpion 3026-12 motor. I've pushed these two items in my Ultra Stick 25e to a lot more than this....so I hope it'll be OK.
Old Oct 26, 2008, 01:30 PM
HMX Dave is offline
3DHS Koolaid Fan
Alberta, Canada
Joined Oct 2007
Maiden this AM....she's no screamin' powerhouse....but she flys OK. Big loooong rollout on the grass field, up and out.....4 clicks of left,2 clicks of up...and she flew fine. Something amis in my power set-up though....when I went wide open, it would surge. 3/4 throttle was no problems, but as soon as you pin it, it would surge. Going to check my timing settings on the ESC.
Edit: and cooling was no problem: it was -4C (22 F) hehehe.
Yippee! T3D-lll Yak 54,question?? Extra 3D 3D Flying 2 Nov 02, 2007 02:56 PM
For Sale CMP Yak-54 140 size 72" Backwing Aircraft - Fuel - Airplanes (FS/W) 2 Sep 16, 2007 08:39 PM
For Sale New CMP Yak 54 with TT91 Four Stroke Stewby Aircraft - Fuel - Airplanes (FS/W) 1 Dec 20, 2005 05:04 PM
For Sale New CMP Yak 54 W/ TT91 FS/Futaba T6XA Stewby Aircraft - Fuel - Airplanes (FS/W) 0 Nov 19, 2005 03:10 PM
Question on 36" Yak 54 H-tail Foamies (Kits) 3 Dec 13, 2003 07:29 PM
