Old Oct 22, 2008, 12:48 PM
ipsmotors is offline
Find More Posts by ipsmotors
3DHS Junkie
United States, CA, Fullerton
Joined Nov 2007
New Product
3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED#
Lookie what I see.
http://www.3dhobbyshop.com/detail.aspx?ID=2409
http://www.3dhobbyshop.com/detail.aspx?ID=2408
From the 3D Hobby Shop website:
This 47" Edge 540, developed by Scott Stoops, is a fantastic performer. Light KE coupling, no wing rock, excellent pitch authority, great all-around flight performance....all in a durable lightweight package. The Edge is really, really easy to assemble, too. The wings are easily removable, and ride on a strong carbon-tube wing spar. The landing gear is one-piece, molded carbon-fiber and mounts to a strong, composite-reinforced plate. The motor box is pre-assembled and pre-drilled and nutted for many popular 28-30mm outrunners. The tail feathers are fully-airfoiled for highest performance.
The Edge includes ball-link/phenolic control hardware, and is covered in genuine Oracover (Ultracote) covering. The green version is done in beautiful pearl metallic green. The red version is beautiful true red, just like the full-scale RedBull air racer.
Specs:
Wingspan - 47"
Wing Area - 450 sq. inches
Weight - 37-41 oz. depending on setup, lipoly pack
Spinner - 40-42mm or 1.75"
Use Hitec HS-65HB or HS-65MG servos. Long servo arms are required for full 3D throw.
The Edge 47" requires a brushless outrunner motor 108-148 grams weight. Good choices include: Torque 2818T-900 or Hacker A30-16M for lightweight setups with 3S 2100-2500mah lipoly packs. For more power, use a Reaper GR-35 on 3S or 4S, or a Torque 2814T-820 on 4S 2200.
Build videos:
3D Hobby Shop 47" Edge 540 build movie #1 (4 min 54 sec)
3D Hobby Shop 47" Edge 540 build video #2 (5 min 11 sec)
3D Hobby Shop 47" Edge 540 build video #3 (6 min 11 sec)
3D Hobby Shop 47" Edge 540 build video #4 (5 min 35 sec)
ipsmotors is offline Find More Posts by ipsmotors
Old Oct 22, 2008, 01:02 PM
sun.flyer is offline
Find More Posts by sun.flyer
Test your skills....fly IMAC!!
sun.flyer's Avatar
Swanton, Ohio
Joined Feb 2005
The green one is very sharp (actually they both are). The green does not appear to be as fluorescent as the 40" version.
Good find Kevin!!!
Tim
sun.flyer is offline Find More Posts by sun.flyer
Old Oct 22, 2008, 01:10 PM
blucor basher is online now
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
Tim - it's pearl metallic ultracote green on the 47" and 55"....not flourescent at all.
blucor basher is online now Find More Posts by blucor basher
Old Oct 22, 2008, 01:17 PM
3DHS Junkie
Joined Nov 2007
I just happen to have to have all the gear for this one. I'm in!
Old Oct 22, 2008, 01:26 PM
sun.flyer's Avatar
Swanton, Ohio
Joined Feb 2005
I like it. Sounds like it will have that simmer to it like the pearl blue on the Slick. I might have to change my SR order for a green 47" Edge.
Tim
Old Oct 22, 2008, 06:40 PM
Berean is offline
Find More Posts by Berean
Palmdale, CA
Joined Oct 2008
What's the length of the fuselage on this one?
Berean is offline Find More Posts by Berean
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
OK........I want the first red one off the boat!
Doc Austin is online now Find More Posts by Doc Austin
Old Oct 22, 2008, 07:21 PM
blakevan is offline
Find More Posts by blakevan
Ta-dah!
blakevan's Avatar
United States, TX, Richardson
Joined May 2007
WOW, that green is way cool. How does this fly in comparison to the S/R?
blakevan is offline Find More Posts by blakevan
Old Oct 22, 2008, 09:16 PM
BoneDoc is offline
Find More Posts by BoneDoc
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Checking in .
BoneDoc is offline Find More Posts by BoneDoc
Old Oct 22, 2008, 09:20 PM
Joined Jun 2003
Edge 540 47" Video #1 (Harrier/Slow Flight)
Old Oct 22, 2008, 09:39 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Looks like it harriers even better than the SHP.
Ben, is the rudder pull-pull on that?
Old Oct 22, 2008, 09:42 PM
Joined Jun 2003
Yes, pull-pull.
Old Oct 22, 2008, 09:59 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Will the 4s 2814 package harrier almost as well as the videos? I'm working my harrier two full packs a day and the Edge looks like the best plane for that. I still want the thing to punch out like a Saturn 5, but right now harrier and hover work is my priority. I've got 3s 2200s if I need them.
Also, I'm guessing the 2600 Pro-lites would work well in this plane, right? This is great because the plane will use the same motor, esc, batteries and servos as my other 47" planes.
Old Oct 22, 2008, 10:03 PM
Joined Jun 2003
A little more video.
Old Oct 22, 2008, 10:04 PM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
If harrier and hover is your priority, you really want to keep the plane as light as possible (3S 2818/900). There's plenty of power, and it makes doing high alpha stuff easier.
Discussion 3D Hobby Shop 47'' Yak 54 Get Real 3D Flying 1869 Aug 11, 2011 08:39 PM
Article 3D Hobby Shop 47'' Yak 54 ARF Review Get Real 3D Flying 21 May 29, 2011 11:00 PM
Discussion 3D Hobby Shop 47" Katana sukhoi26mx 3D Flying 1279 Jul 31, 2010 08:41 PM
Discussion 3D Hobby Shop 47" Extra 300 SHP sun.flyer 3D Flying 8726 Feb 29, 2008 09:58 AM
Video 3D Hobby Shop 47" Extra SHP sukhoi26mx Electric Plane Talk 4 Mar 12, 2007 09:19 PM
