Here are some pics of the pylon assy.
The blades are flat bottom i.e. clarke Y type, the "Rotor bar" is made of a carbon look epoxy glass type sandwich plate material as is the pylon. I have made an Aluminium rotor bar 1/16" thick of the "springy type" so that I can adjust the negative pitch on the blades if req. |
Ok,
If the blades a turning anti clockwise and the head is not flexible enough or the blades arent up to speed it will roll to the left....take a look at me testing different heads out...the second 2 blade set up has a stiffish plate, you can see how it rolls to the left..you wont straighten it up no matter how much right roll you may give it Regards Rich
Phil P.S. I will try to get some thinner / more flexible plate if my local model shop supplies it which I strongly suspect does not. Can you suggest where to get the G/F sheet from, especially the plate I need for the Dag- R2 |
