Old Feb 19, 2003, 09:17 AM
TurboRacer's Avatar
United States, CT, Waterbury
Joined Oct 2002
GWS MC2002 charger.. Can it be plugged into a wall outlet?
I have this charger, and was wondering if there's anyway to get it to plug into a wall outlet? If not, what is a good, fast charger that I can buy to plug into a wall outlet? One that's around $50-$75 preferably...
Thanks for any and all help.
TurboRacer is offline Find More Posts by TurboRacer
Old Feb 19, 2003, 11:16 AM
San Jose, CA
Joined Jun 2002
DC ONLY CHARGER!!!!
NO!!! This excellent charger is designed for only DC (direct current) operation. You will need to either charge off of a car battery or purchase a regulated DC power supply. There are many choices for regulated power supplies but they must be large enough to power the unit. Almost all regulated power supplies are at 13.8 Volts. The charger is designed to handle that or slightly less but very important to not use a power supply of less then 4 Amps with this unit. This is my third charger and I am extremely pleased with its operation as you will be also. If you want to get a power supply that should last you a lifetime and cover all your future needs,you should be able to go to Radio Shack and pick up their 25 Amp power supply for $70.00 as it is on sale at half price. A fine unit that is much lighter in weight then many of the supplys as it acheives ripple free regulation by using the method called switching which allows it to be made without a heavy transformer. Hope I have not made the answer too complicated, but your choice of charger is excellent. GUD FLYING.........Dick
Dick is offline Find More Posts by Dick
Old Feb 19, 2003, 11:19 PM
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Since you already have the MC2002 the best bet is to look for a 10-15A switching power supply - do a search and I'm sure you'll find several leads. The only AC/DC charger I can recommend right now is less capable than the MC2002 - and for what it costs you probably get an adequate power supply.
BEC is offline Find More Posts by BEC
Old Feb 19, 2003, 11:54 PM
Peter Khor's Avatar
Mostly in Norman, OK
Joined May 2002
This may not be the best solution, but you should be able to charge up to ~2A or so on 8 cell packs:
http://horizon.hobbyshopnow.com/prod...p?prod=HAN9521
If you can spend a little more, get the RS power supply. Last option is to kludge one yourself from a spare PC power supply.
Peter Khor is offline Find More Posts by Peter Khor
Old Feb 20, 2003, 12:07 PM
TurboRacer's Avatar
Joined Oct 2002
Alright, thanks for the help guys! It's appreciated!
Jeff
WTB: Battery charger that plugs into wall outlet TurboRacer Aircraft - Electric - Airplanes (FS/W) 2 Feb 21, 2003 05:55 PM
Can I charge a 12V Field Battery with a GWS MC2002 Charger? mrebman Parkflyers 6 Jan 17, 2003 06:23 AM
Can I use my new GWS MC2002 Charger to charge my Transmitter Batts? mrebman Batteries and Chargers 16 Jan 09, 2003 10:12 AM
FS: GWS MC2002 Charger Kevin P Aircraft - Electric - Airplanes (FS/W) 3 Dec 09, 2002 09:35 PM
GWS MC2002 Charger thoughts mt_100 Electric Plane Talk 8 Aug 29, 2002 09:32 PM
