Old Oct 19, 2008, 05:44 PM
Bobnormal is offline
Find More Posts by Bobnormal
Aim to Misbehave
Bobnormal's Avatar
United States, CA, Upland
Joined Mar 2006
Yet another VTOL
Hello all,Since I began too suck lately with successful designs,I thought I'd try something different,and since I've always wanted a driveway toy I figured what the hey.After looking thru the VTOL forum I came up with a hybrid ducted/airfoil design of sorts.
Since the problem with all VTOL seems to be rotational torque(sic)I offset all for vane/wing /control surfaces 6 degrees,as if it flew horizontal,get it?
I built a 12"dia. by 12" tall duct that will eventually control the airflow over the positioning vanes and the control surfaces.but for now I'm leaving it off until I get my equipment positioned well,I Will Finish This,and I Will Shoot Video,next comes the electronics layout.
I know this should probably be in the VTOL forum,but it's a foamie,it's scratchbuilt,and you guys are my friends in the lonely world of scratchbuilding,
Any help would be appreciated,
Bob
Bobnormal is offline Find More Posts by Bobnormal
Old Oct 19, 2008, 06:32 PM
Aim to Misbehave
Bobnormal's Avatar
Joined Mar 2006
I just threw some gear on it for a static test,no servos just motor,it seemed fine rotationally but rolled over just after liftoff,Broke prop...........'
Bob
Old Oct 19, 2008, 06:39 PM
kram242 is offline
Find More Posts by kram242
-+- PhlatBoyz -+-
kram242's Avatar
New Jersey
Joined Sep 2003
Looks cool,
One thing I would say is that and edf unit will be to weak to lift that in vertical takeoff.
I have built a few of these type of VTOL flyers and the best unit for hover seems to be a 12" prop.
Seems the larger the prop the better to keep it from wanting to tip over all the time.
Large bottom control fins (like you have) and keeping all the electronics weight to the top right under the motor helps to keep it balanced as well.
I have a few out there one called the NightOWl and the other is GoldenEYE
Do a search and you will find some info on them.
I am going to make a plan set to cut the NightOWL out on the Phlatprinter soon.
Mark
kram242 is offline Find More Posts by kram242
Old Oct 19, 2008, 06:58 PM
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Bob, looks interesting , good luck!
Kram, I'll be looking up your VTOl's.
leadfeather is online now Find More Posts by leadfeather
Old Oct 19, 2008, 07:44 PM
Aim to Misbehave
Bobnormal's Avatar
Joined Mar 2006
Kram thanks Leadfeather as well,Kram I'm just using the EDF housing to mount a motor,at least 12" prop on a bp 2108 or 09(trying both). This is a fun experiment as for once I don't have clue.Actually yes I do. thrust is a very predictable thing,I predict you will be affected by it.Now I cut the duct at a 3degree up to match the the vanes,I'm not going permanent with the duct just yet,until I get the servos squared away,
Bob
Old Oct 19, 2008, 07:47 PM
Aim to Misbehave
Bobnormal's Avatar
Joined Mar 2006
Kram you would think to put the weight low, why does it seem to work opposite?
Bob
Old Oct 19, 2008, 07:51 PM
Aim to Misbehave
Bobnormal's Avatar
Joined Mar 2006
As far as Electronics goes it's something like this...
Power is not an issue,as I have multiple powerplants and props to experiment with....
I plan on startng with an Elevon setup for 2 surfaces and thinking about setting up rudder on the other 2 using a simple aileron splitter to create a type of Rudderon as it were,Ideas?
Bob
Old Oct 19, 2008, 08:38 PM
Winging it >
Joined May 2006
This full size VTOL was done back in the 50's. Cg was actually well above the props and yet it was inherently stable...not intuitive at all.
http://www.youtube.com/watch?v=dmSCyy0_OX4
Old Oct 19, 2008, 08:54 PM
Aim to Misbehave
Bobnormal's Avatar
Joined Mar 2006
Amazing and something to be explored.CG above the prop?I'm not the human on top so it's hard to say how I could control that,I've read some crazy things,battery on top of the prop on a swashplate etc, but there has to be a better way,
Bob
Old Oct 19, 2008, 11:28 PM
poweredlawndart is offline
Find More Posts by poweredlawndart
Joined Aug 2004
How about gyros to help contol your elevons and hold it in the vertical position until you push over into level flight????
poweredlawndart is offline Find More Posts by poweredlawndart
Old Oct 21, 2008, 01:33 PM
Winging it >
Joined May 2006
Another high cg craft
Check this out, talk about high cg
Inverted Heli-Max AXE-EZ Coaxial R/C Helicopter (1 min 55 sec)
Old Oct 21, 2008, 03:11 PM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
Concerning the heli, I tend to think the blades (varible pitch) force it to remain steady, the pilot merely adjusting the blade pitch to maintain upside down orientation. The heli's natural tendency is to flip rightside up though.
You guys are doing cool research with your various designs, and making the VTOL planes very interesting of late. Keep up the good work.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Oct 21, 2008, 05:02 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Having flown some beginner's helicopters (fixed pitch), I can tell you that the words "steady" and "helicopter" do not go together all that well.
Even right side-up (and as normal, with a gyro controlling the rudder), helicopters have a tendency (at least for beginners) to tilt and move all over the place when one is trying to hover them
(the phrase 'swinging pendulum of death' comes to mind).
An exception are the co-axial helicopters.
Some VTOL threads (all within RC Groups):
sloper steve has a "hoverfoam" thread
VTO: http://www.rcgroups.com/forums/showthread.php?t=200470
Mini JAR: http://www.rcgroups.com/forums/showthread.php?t=459443
Sumo 3D: http://www.rcgroups.com/forums/showthread.php?t=710077
When comparing RC planes and helicopters:
1. with planes, I can flat turn (well left turns, anyways), split-S, loop
2. with helicopters, I am still working on right-side up hovering,
and I started with helicopters
flying-llama is offline Find More Posts by flying-llama
Old Oct 22, 2008, 10:31 PM
Aim to Misbehave
Bobnormal's Avatar
Joined Mar 2006
Shameless bump
Update,Work and lot's of(economy anyone?)it.Ready for servos. I still don't buy the High CG thing but am making provisions for it,to be sure.
The duct is currently removable,as it should be for access to the gear,but I will find a way to attach it like we do with wings,Black and White anyone?
Bob
P.S. Firefox does not handle text below your pix,tends to crash,,,beware,
Bob
Old Oct 22, 2008, 10:34 PM
Aim to Misbehave
Bobnormal's Avatar
Joined Mar 2006
Just looking at that hacked round shape,remember we use wirenuts! for ESC to everthing,HAHAHAHAA!,
Bob
Just can't build yet another Spitfire ? ChrisP Scale Kit/Scratch Built 0 Jun 25, 2001 04:42 AM
yet another hornet problem new2heli Electric Heli Talk 5 Jun 24, 2001 10:52 PM
Yet another Twinjet flies for the first time jbrundt Foamies (Kits) 1 Jun 17, 2001 10:17 PM
From the Ashes Comes Yet Another PhrankenFilip!!! dr.E Electric Sailplanes 18 May 15, 2001 05:23 PM
Yet another newbie wondering what to buy... Dro Electric Heli Talk 2 Apr 26, 2001 03:03 PM
