Old Oct 18, 2008, 03:39 AM
Rob_G is offline
Find More Posts by Rob_G
Regina, SK
Joined Nov 2006
Futaba 6EX FASST replacement antenna
My LHS tells me that after talking to Futaba, this is not a normal inventory item so he was unable to get one for me. I've searched online and cannot find a part number or any place that even sells a replacement antenna for a 6EX. My guess is that they will want me to send the TX in for repair, but that's silly since I'm sure I could do the repair myself easily. I've sent an email to futaba to ask about a replacement antenna and will wait for their reply.
Rob
Rob_G is offline Find More Posts by Rob_G
Old Oct 18, 2008, 04:31 AM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by Rob_G
My LHS tells me that after talking to Futaba, this is not a normal inventory item so he was unable to get one for me. I've searched online and cannot find a part number or any place that even sells a replacement antenna for a 6EX. My guess is that they will want me to send the TX in for repair, but that's silly since I'm sure I could do the repair myself easily. I've sent an email to futaba to ask about a replacement antenna and will wait for their reply. Rob
Futaba 6EX Antenna. Manufacturer Stock # ANT5 is same for 6XA, 6XH, 6YF, 6YG, 6EXA
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Oct 18, 2008, 04:14 PM
Rob_G is offline
Regina, SK
Joined Nov 2006
Regards
Alan T.
Sorry, maybe I needed to be clearer. It's a Futaba 6EX 2.4GHZ FASST radio. That antenna is for 72mhz radio.
Rob
Old Oct 18, 2008, 05:23 PM
A.T. is offline
Joined Aug 2002
Sorry, my mistake in not reading correctly late at night... try
Futaba Transmitter Aerial - 2.4 GHz TM-7 Antenna
Regards
Alan T.
Old Nov 02, 2008, 09:40 PM
Sgt_Ric is offline
Find More Posts by Sgt_Ric
R/C, FPV, UAVs
Sgt_Ric's Avatar
Alberta, Canada
Joined Nov 2007
I have had great luck replacing the exact antenna connector you mention, the Futaba 6EX 2.4GHZ FASST one, with a pigtail with an SMA connector for my patch antenna for FPV flying.
The circuit board end is a U.FL / IPX end which is rated for only a couple on/off cycles, so be carefull!
I have the 6" pigtail cable run internal to the back case where I have installed the connection for the external antenna.
I have then hung the patch fron the TX's handle.
See http://stores.ebay.com/QualityChinaGoods for the diff pigtails avaiuable.
Sgt_Ric is offline Find More Posts by Sgt_Ric
Old Nov 03, 2008, 02:15 PM
8pointroll is offline
Find More Posts by 8pointroll
Joined Oct 2008
Also check out their WiFi Antenna 2.4GHz - 5$ instead of 13. But you will have to wait longer for delivery
8pointroll is offline Find More Posts by 8pointroll
Old Apr 12, 2009, 02:21 PM
ballemann is offline
Find More Posts by ballemann
ballemann's Avatar
Norway
Joined Jun 2007
Pictures?
Do you have any pictures of your rig? I havent even opened my 6EX yet, but been pondering for a while about modifying it to take some sort of external antenna (SMA-plug in the side?!), so I can use one of the RaydioWarm mitts (I live in the North of Norway, need to keep both my hands and my tx warm ). On the RaydioWarm itself I plan to have a fixed external antenna.
Would appreciate any help here.
ballemann is offline Find More Posts by ballemann
Question Futaba 6EX-2.4 Ghz FAAST R606FS ReceIver Antenna rckowal Radios 6 Aug 19, 2008 11:18 AM
Sold Futaba ANT12 style TX replacement antenna ncpiperpilot Aircraft - General - Radio Equipment (FS/W) 1 Dec 26, 2007 02:00 PM
Discussion UK stores for replacement antenna for Futaba TX arukum17 Radios 2 Sep 16, 2007 08:06 AM
Futaba 9C replacement antenna source? RSCherry Radios 2 Apr 22, 2004 08:52 AM
Replacement antenna for my Futaba Receiver? gtslabs Radios 1 Nov 26, 2003 12:38 PM
