Espritmodel.com Heli Air
Old Feb 18, 2003, 07:02 PM
WiLd`
Guest
n/a Posts
rotor speed bleed-off
Just wondering if anyone has any insight on my problem
when the heli is just ready to lift off the rotor speed bleed's off at the
same time the engine is not racing(clutch slippage) ?it keep's running fine
maybe a little lag
could the engine be too rich? if it was lean it should cut out......ran and
flew excellent before this happened???
WiLdWiNg
Old Feb 18, 2003, 09:02 PM
Bill Price
Guest
n/a Posts
Re: rotor speed bleed-off
What machine? engine?
The XCell SE had a problem with the one-way bearing slipping in its housing.
RPM went up a bit when this happened, but not screaming like a blown clutch
would cause.
"WiLd`" <wildwing0@rogers.com> wrote in message
news:luA4a.9302$Zr%.747@news01.bloor.is.net.cable. rogers.com...
the
fine
> maybe a little lag
and
> WiLdWiNg
Old Feb 19, 2003, 02:02 AM
Guest
n/a Posts
Sounds to me like the engine is just over-rich and therefore can't cope with
the increased load of applying flying pitch. I suggest you lean it out some
and check again.
JB
"Bill Price" <Bill@classTools.com> wrote in message
news:MdC4a.10054$0q5.9805@fe01.atl2.webusenet.com. ..
housing.
clutch
> would cause.
> the
> fine
> > maybe a little lag
> and
> > WiLdWiNg
Old Feb 19, 2003, 11:42 AM
Mikespruce99
Guest
n/a Posts
Also check the pitch of the blades throughout the range.
A large ATV at the bottom end and small at the top or vice versa, or a trim
setting on some radios that affects only one half of the travel, could
introduce a pitch curve that is not what you would expect.
Old Feb 19, 2003, 04:22 PM
WiLd`
Guest
n/a Posts
Also I might note it is cold outside!...can it be to lean
due to the air density?
the
fine
> maybe a little lag
and
> WiLdWiNg
Old Feb 20, 2003, 03:32 PM
WiLd`
Guest
n/a Posts
Well folk's I tried lean ing it out but it only became worse
so I richened it 1 turn(wow) and it actually fly's now!
Thanks you all for the helpful advice
WiLd`
the
fine
> maybe a little lag
and
> WiLdWiNg
Rotor speed and piniong size? Mats Johansson Micro Helis 1 Apr 22, 2004 01:33 AM
Pinion gear to rotor speed question Bud Morrison Micro Helis 8 Dec 05, 2003 07:51 PM
Rotor Speed Calculator Fitz Walker Electric Heli Talk 27 Sep 26, 2003 11:35 PM
