Old Oct 17, 2008, 04:33 PM
darticus is offline
Find More Posts by darticus
United States, NJ, Sparta Township
Joined Mar 2007
Lipo Battery Connectors
I received some batteries today and two had the JST plugs 360mah 11.1v and balanced plugs and two had deans plugs 500mah 11.1v. and balance plugs . Can I use the same Jst plugs on both batteries? Wondering about the wire thickness and plug type conductivity. Can I cut wire lengths to get rid of wire weight? How about making an JST to DEAN adapter. Thanks Ron
darticus is offline Find More Posts by darticus
Old Oct 17, 2008, 04:47 PM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
YES, thick wire JST can handle up to 12 amps
hall woo is offline Find More Posts by hall woo
Old Oct 17, 2008, 04:51 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
The contacts in the JST connectors are rated at 2 Amps, the Dean's Ultras (not the Minis) are rated at about 41 Amps or more.
The wire is also a limiting factor. The ampacity of different gauges of wire can be seen here (rule of thumb, some variation will occur):
http://www.powerstream.com/Wire_Size.htm
Are there any "C" rating on the batteries? A 15C 360 mAh battery would be good for 5.4 Amps and a 15C 500 mAh batter for 7.5 Amps. What kind of loads are you planning to apply to the batteries? The peak or max amperage stated in the description for the motors or whatever?
And the wire size? Is that marked on the wire?
I think I'm right about the 2 Amp rating on the JST contacts but am not positive about it. At any rate, I seem to think that maybe the JST contacts are routinely used at over 2 Amps in may RC applications.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Oct 17, 2008, 05:21 PM
hall woo is offline
Permanently Banned
Joined May 2003
NO, the E-flite Blade CX1, CX2 pass 6 amps thru those JST connectors with no problems and the TP 1320 have JST connectors with thick 16 awg silicone wire
Old Oct 17, 2008, 05:40 PM
darticus is offline
Joined Mar 2007
Connectors
The Eflite 800mAh 3S 11.1V 15C LiPo, uses the 20GA JST/Balance plugs. The battery I'm using is 500mah at 20-30c. The ESC uses the same 20 guage wire to connect. If the wire was too thin what would I see happen? Over heating, bogging down. Thanks Ron
Old Oct 17, 2008, 05:45 PM
hall woo is offline
Permanently Banned
Joined May 2003
it will burn connector and short out LIPO pack, with the insulation also burnt up
Discussion LiPo Battery Connectors hoghead385 Batteries and Chargers 2 Jul 27, 2007 02:37 PM
Discussion LiPo battery connectors question with pics. Scott_S. Power Systems 11 Jul 08, 2007 11:57 AM
Battery Connectors for GWS fliir Parkflyers 6 Oct 03, 2001 06:48 PM
Battery Connectors rcbrust Parkflyers 3 Sep 24, 2001 12:14 PM
Battery connectors smithrl Electric Plane Talk 2 Aug 06, 2001 07:58 AM
