Old Oct 17, 2008, 01:09 AM
aerospacepilot is offline
Find More Posts by aerospacepilot
Big Aerial Mission Flyer
Joined Oct 2008
Electric Motor Calculators
I have been using both Electricalc and the Neu Motor Calculator to do some Propulsion analysis for the RC aircraft I am building.
The Neu Motor calculator is great, but it only shows me the efficiency at the max amp draw. I would like to input an amount of current, and see what the efficiency is. Does anyone know of a program that I can use to do this?
Also, I am pretty sure that the Neu Motor calculator assumes you are at standard sea level. Since I will be flying at over a 5,000ft density altitude, is there a program that can adjust for the change in density?
I have also noticed there is a large discrepancy between Electricalc and the Neu Motor calculator. Which one should I trust?
Thanks again,
Aerospacepilot
aerospacepilot is offline Find More Posts by aerospacepilot
Old Oct 17, 2008, 06:56 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
http://www.rcgroups.com/forums/showthread.php?t=606703
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Oct 17, 2008, 03:25 PM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Motocalc and Drive Calculator have inputs for altitude and air temperature.
The NeuMotors calculator is a customized version of pcalc (which is based on Chuck Gadd's Electric Motor Calculator). Some of the math in pcalc is not quite right, but the results are usually close to other calc programs when using the same parameters.
The biggest source of error in any calc program is inaccurate input data. Drivecalc is probably the most accurate at calculating static performance because it uses independent bench test measurements, rather than motor and prop 'constants' (which often have dubious pedigree). Unfortunately that also means that it has a limited range of motors and props to choose from.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Oct 18, 2008, 01:43 AM
BEX is offline
BEX
Find More Posts by BEX
BEX
BEX's Avatar
South Africa
Joined Sep 2007
I have found this calculator to give accurate info on the E-flite power 60 motor
http://brantuas.com/ezcalc/dma1.asp
I dont know if it has all the features of the other calculators.
BEX is offline Find More Posts by BEX
Electric motor break in DaleM Power Systems 12 Jun 13, 2014 03:06 AM
Comm Drops on electric motor e-sailpilot86 Beginner Training Area (Aircraft-Electric) 11 Apr 21, 2009 12:32 AM
electric motor for 13 pound model? Steve_JR Electric Plane Talk 5 Oct 29, 2001 10:50 AM
electric motor direction foamman01 Electric Plane Talk 1 Oct 11, 2001 09:30 PM
Electric motor & prop for a HLG Butch B Electric Sailplanes 3 May 30, 2001 12:58 AM
