Old Oct 16, 2008, 01:40 AM
Montezumas_viper is offline
Find More Posts by Montezumas_viper
Joined Jan 2007
NEED HELP :( F18C Ducted 70mm jet
Ok so I got a new jet and have flow it for a while. I recently played around with the esc settings and set the engine to CCW just to see if it worked, upon setting it back I noticed a nasty bearing like noise.
Does anyone have any idea where I can get a new brushless engine for it?
2836 Brushless Motor
http://www.nitroplanes.com/fho4brrecoed.html
Also, a bit of other information. I'm also getting a new battery because one of the cells on my 4cell pack is dead. When I tried it, it was hooked up to this half/working battery. Here is what the included speed control is
http://www.hobbycity.com/hobbycity/s...Simple_50A_ESC
Just to be clear, it is a 14.8 volt 4S 18C battery pack that is used
Montezumas_viper is offline Find More Posts by Montezumas_viper
Old Oct 16, 2008, 08:21 AM
kelberts is offline
Find More Posts by kelberts
Effumall
kelberts's Avatar
Joined Nov 2005
Check the thread in the foamy forum on this jet - lots of info, and different set-ups.
I have a 68mm Haoye fan and a Walkera 380M in mine. The fan cost about $10.00 and the motor was $35.00. The Walkera motor would probably fit into the stock fan.
Also, Hobby City has all kinds of different 28mm inrunners for not a lot of $$.
Re: the battery - what capacity is it? If it's a typical 2100-2200 4S, and it's only 18C, you'll be lucky to get more than a few flights from it.
Most 28mm inrunners in the 3000-4000 KV range in typical 68-70mm fans draw 40-50 amps, so even a 25C 2200 pack will be working very hard, and won't last too long.
kelberts is offline Find More Posts by kelberts
Help! Need help launching multiplex micro jet 840193 Parkflyers 7 Aug 14, 2007 09:49 PM
Need help deciding on a jet AndrewCSDunn Pusher Prop Jet Models 3 May 04, 2005 10:55 PM
New to board...Need help with first jet Smurfjet Electric Ducted Fan Jet Talk 2 May 14, 2002 12:02 AM
Pico Jet Combat - Need Help Patrick Plawner Foamies (Kits) 13 Jan 16, 2002 11:57 AM
Jet designers I need help DNA Electric Ducted Fan Jet Talk 4 Jan 07, 2002 02:20 PM
