Jun 28, 2001, 04:16 PM
Sunnyvale, California, United States
Joined Jul 2000
Greg & Mike;
I got my second Honey today!!! Can you believe, it is the same color as my old one. I guess Sal remembered what color my old one was.
My wing sat high in the saddle, but my wing hole lined up but I didn't consider Dremeling the wing mounts. It flew well, although the wing sat a little high. Like you say, it isn't a perfect fit. Let me know the improvements work, and if they improved the flight of the Honey.
I used a 10x8 folding prop and it would go vertical. The 11x8 just rides to close to the leading edge of the wing. I think the wing clearance is 11 mm to 11.5 mm, I guess you can make it fit.
Just cut out enough of the wing to mount your servos, and allow for adjustment for proper alignment of your servos. Trial fit the servos before you attach double sided servo to them. Once the double sided tape is down there is no turning back, if you know what I mean? I don't know how you can get the servo back up again, once it is stuck.
Mike let me know how your first flight goes? And if the Honey was everything we said it was? It will stand on its tail and go vertical, and soar with the birds. Just make sure you do a good preflight check, and everything will go well.
Henry
P.S. Your in for BIG surprise, it will fly like no other Hotliner.
[This message has been edited by hmhoshi (edited 06-28-2001).]
