Old Oct 14, 2008, 12:18 PM
CVO is offline
CVO
Find More Posts by CVO
CVO
Joined Oct 2008
Question
Servo Futaba S3801 Heavy Duty Arm Type Sail Control
Hello.
They know that with this amp must be used Servo.
This is the technical information that I found:
SPECS: Torque: 156 oz-in@4.8V - 194 oz-in. @ 6V
11.2 kg-cm@4.8V - 14.0 kg-cm @ 6V
Transit Time: 33 sec/60 @ 4.8 Volt - 26 sec/60 @ 6V
Arm Travel: 125 (under optimum conditions)
Length: 2.4 "(61mm)
Width: 1.2 "(30mm)
Height: 2.0 "(51mm)
Weight: 3.7oz (107g)
Thank you
CV
CVO is offline Find More Posts by CVO
Old Oct 14, 2008, 12:55 PM
martin richards is offline
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
Hola Carlos, I'm guessing that you're interested in the current under load of the servo. Manufacturers don't usually give this in their technical specs. But I have a boat of similar size to your ETNZ with a servo of similar power and the 5xNiMH power pack seems to provide enough amps for the servo.
martin richards is offline Find More Posts by martin richards
Old Oct 14, 2008, 03:38 PM
CVO is offline
CVO
CVO
Joined Oct 2008
Martin thank very much.
Greetings
Old Oct 14, 2008, 04:30 PM
Norman2 is offline
Find More Posts by Norman2
Norman2
Norman2's Avatar
Connestee Falls, Brevard, North Carolina
Joined Mar 2006
Servo 3801
Carlos,
Use a 3802
Norman
PS A little less torque at 6 volts but more speed
Norman2 is offline Find More Posts by Norman2
Old Oct 16, 2008, 02:34 AM
tigerbay is offline
Find More Posts by tigerbay
Joined Sep 2006
current usage is very low. You can get a days sailing out of a set of batteries. It is not like using a motor running a prop.
tigerbay is offline Find More Posts by tigerbay
Wanted One (1) Heavy Duty FUTABA servo arm or wheel Jonathan Ott Aircraft - General - Radio Equipment (FS/W) 2 Sep 28, 2008 12:49 PM
Sold 3 packs of Futaba heavy duty servo arms Steve H. Aircraft - General - Miscellaneous (FS/W) 1 Jan 25, 2007 12:05 PM
Heavy Duty Futaba Dual Charger FBC-19B(4) DPage Aircraft - Fuel - Airplanes (FS/W) 0 Dec 17, 2003 07:19 PM
Heavy Duty Servo? daveWCO Electric Plane Talk 10 Apr 13, 2003 12:13 AM
Where to get DuBro heavy duty servo arms in the UK? Ben C Sport Planes 8 Feb 23, 2002 06:04 AM
