Old Dec 30, 2012, 12:44 PM
X10an1 is offline
Find More Posts by X10an1
Helicopterpilot
Norway, Vestfold, Sandefjord
Joined Dec 2012
I measured resistance on the HK USB-dongle and found it to be in the 2-5 Mohm range. This is a sure way to make the S/N ratio way to low for safe noise free operation. Think they just feed the PPM signal direct to the IC without using an input resistor (in the range of 10k+/-) between input-signal and ground.. This is _in my opinion_ a design error from the dongle manufacturer, and Futaba is not to blame.
With this "knowledge" it is easy to understand why it often works just fine.
It is for sure a old thread, but I really hope this posts will help some lost soul in the future :-)
X10an1 is offline Find More Posts by X10an1
Old Dec 30, 2012, 01:20 PM
Wintr is offline
Find More Posts by Wintr
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
That could explain it - I have the GWS USB cable.
Wintr is offline Find More Posts by Wintr
Old Apr 27, 2013, 01:09 PM
Stryver is offline
Find More Posts by Stryver
Joined Apr 2013
I have a very similar problem with a 72mhz Futaba transmitter (T4VF) and a GWS USB cord. It sometimes connected/sometimes didn't, and when it did, the control inputs bounced every which way.
I checked out the board the DIN mount is on (I have a big round Futaba plug, I think it's a DIN-6), and found two potential signal pins, one was a large square wave that looked like PPM signal, and the other was a small (~1V) wave form that moved with the square wave. When I tried nanofarad-range capacitors, it killed the signals, so I put a 7pF cap across what looks like a resistor in series with the ground pin. This flattened the background transmitter noise from all the signals, but didn't decrease what looked like actual signal.
Subjectively, using js_demo (from FlightGear) and FSM, this looked like it reduced the jumpiness slightly, but didn't kill it. Then I noticed that anytime I had something connected to the ground (like one end of my multimeter), the jumpiness on the computer side dropped almost completely. I ended up wrapping a stripped wire around the slightly-exposed base of the DIN plug, and holding it under my fingers. This much grounding seemed to make the computer happy.
But it's not fixed. Things are still _incredibly_ squirrely, and at the bottom end of the ranges, they flip-flop to max. So a little stick back causes a little nose up, but a lot stick back causes full nose-down elevator, and this is the same across the baord on all the channels, it's not some odd aerodynamic effect of a stalled elevator.
Needless to say, this is not very useful. Any ideas?
Stryver is offline Find More Posts by Stryver
Discussion Futaba 7c 2.4 mixes mlesher2 Radios 9 Jun 15, 2008 09:28 AM
Sold BRAND NEW FUTABA 7C 2.4 GHz FASST TX rcfunhouse Aircraft - General - Radio Equipment (FS/W) 3 Mar 02, 2008 04:42 PM
Discussion Throttle lockout on Futaba 7c 2.4?? ronrandle Radios 1 Feb 07, 2008 04:06 PM
Question Futaba 7c 2.4 skyking1231 Radios 2 Dec 06, 2007 01:52 PM
Discussion Does anyone have any new info on futaba 7c 2.4? antennahead Radios 2 Jun 27, 2007 11:49 AM
