Old Oct 12, 2008, 12:13 PM
reefboy is offline
Find More Posts by reefboy
Luke 12:7
reefboy's Avatar
USA, CA, Sunnyvale
Joined Nov 2006
2s 1100 1100 mah a123 battery for rx pack?`
I was thinking of using a 2s 1100 mah a123 battery for a rx pack for a slope soarer. I need the weight anyways so I thought it could work out well. My only concern is that the voltage is over 6v. It will be used with a spektrum rx and those are good to 9v so no problem there. Will standard servos hold up to 6.6 v to 7.2 volts? I would rather not use a BEC just to keep things simple.
Have others used this setup w/o a BEC?
reefboy is offline Find More Posts by reefboy
Old Oct 12, 2008, 12:30 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Works great. Here ia a Thread which clearly shows volrage is no greater than a 5cell Ni. Post by users with many flights using 2S LiFePO4 receiver / servo battery.
http://www.rcgroups.com/forums/showthread.php?t=914941
Charles
Old Oct 13, 2008, 08:28 AM
mexico is offline
Find More Posts by mexico
mexico's Avatar
NJ
Joined Aug 2003
Charles - I was reading in another thread that someone wanted to use a 2 cell 1100 mah A123 pack to power the servos in a 50cc model running 4 digitial servos rather than the 2300 mah cells to save weight. What is their max current output that will deliver a safe 6v to the servos? I thought that sounded unwise.
mexico is offline Find More Posts by mexico
Old Oct 13, 2008, 10:15 AM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
I ain't Charles -but I do use the 1100's for rx packs
50 CC models - done a bunch of em
these are not sporty planes but full blown 3D capable models
1100 ma pack is fine -
there is no need for anything over 200 inch ounce servo in that size model and 150 inch ounces (actual measured torque ) is typically all you need -if the power is 6 volts .
You will likely get a few flights , then recharge as you fill the gas tank.
FWIW--
You must check your setup for no fighting servos or stalling servos too-
I bet you can't pull 200 ma per flight . One other thing -It isn't the size of the servo -it's the LOAD on the servo. which determines power draw. big servos like 8611s can pull more power but that does not mean they will.
richard hanson is offline Find More Posts by richard hanson
Wanted 2/3AAA nimh 350 mah 4 cell flat for rx pack jondon69 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jan 23, 2008 08:36 AM
Found 2S lipo >=2000 mah for RX pack (or 3S pack to cut down if good deal) Dukester Aircraft - Electric - Batteries & Chargers (FS/W) 4 Feb 18, 2007 07:17 PM
Sold ElectriFly 9.6v 2/3A 1100 MAh NiMH battery Spid Aircraft - Electric - Batteries & Chargers (FS/W) 4 Jan 09, 2007 07:42 PM
FS: Sanyo Hitec 9.6V 1100 mah Transmitter Battery PDX Slope Pilot Aircraft - Electric - Airplanes (FS/W) 2 Jul 06, 2003 12:49 AM
Hecell 1100 mAh nimh 9.6v power pack ddekel Batteries and Chargers 0 Mar 23, 2003 09:59 AM
