Old Oct 12, 2008, 03:36 AM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
Mini-HowTo
U/C designs.. Removable and simple Under carriage systems, lightweight etc
I thought I would show various ways to hold those wheels...And I hope you will post any good systems you use..
The actual wheels are held on to the wire with a bit of silicone fuel tubing each side...and they have stayed on ok so far in use..for thin wires fix the tubes with hot melt glue
Both removable wire UC systems have proved usefull and all work a treat..
System for planes with a lower spline
1...Two wheels at the front type.. the bends are shown below.. the cross body lengths can be made to the width of your fuz..
The V section goes up the outside of the fuz then you use a rod to hold it in place..you can have shorter V lengths but the longer one like mine spreads the loading ..A short one will damage the depron in a heavy landing/crash
shown below on my 24" nutball
RC nutball flying disc (2 min 45 sec)
after a bit of thought ive also made a trike system
and now 19-7-2010 a 4 leg version for lightweight floats
davereap is offline Find More Posts by davereap
Old Oct 12, 2008, 03:44 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
method 2.. A system for flat bottom wings or a wide Fuz.... a trike system
The bends are shown below.. made in two sections the wire is bound together with fishing line (dacron or firewire type), then cyano'd.. This is then bound to a 2" wide thin ply plate, again fishing line and cyano..Two velcro strips along the ply are enough to hold the unit to the bottom of your wing or fuz
this was made for a flat bottomed delta wing and holds on perfectly, but there is no reason you couldnt fit it to any flat bottomed foamy fuz ...
The rear pair of wheels should be fitted just behind the COG
It is use on the delta in this video
RC Delta KFm4 (7 min 46 sec)
and on this V wing.
HO229 KFm4 (3 min 34 sec)
Old Oct 12, 2008, 03:51 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
Please add on your methods below
The bend drawings were made with Google Sketchup..which took all of 1 minute..
thread here..
http://www.rcgroups.com/forums/showthread.php?t=920416
Old May 16, 2009, 04:09 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
Twin legs for a flat bottom wing
Heres another one that ive made..Used for my 36" KFm4 Nutball or any plane that is built with a flat bottom.
The triangle of velcro holds it very well - its a b.... to get off
make the UC to the size and weight you require...
I used 2mm ply and a heavy gauge wire on the one in the pictures. it added 3oz and was for a plane that already weighed 25oz ... so the AUW was 28oz
an alternative to the triange shape would be a T shape for the ply, with all the bars 1" wide to take the velcro..
I required a heavy unit so just made a simple triangle shape
Old May 16, 2009, 02:26 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
"the velcro holds it very well - its a b.... to get off"
Try a blunt thin blade knife, I use one and it works quite well without damaging the hooks or 'fuzzy'. Just slip it in between the two pieces and gently pull as you slide it about.
eflightray is offline Find More Posts by eflightray
Old May 18, 2009, 03:38 PM
Learjets is offline
Find More Posts by Learjets
Learjets
United States, IN, Lebanon
Joined Nov 2003
I use my 6 inch ruler, and its about a 1/2 inch wide.
Learjets is offline Find More Posts by Learjets
Old May 19, 2009, 02:41 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
cheers I wil try that... it might stop me swearing at it
oh you clever people..that works a treat.. on the triangle two rulers does it easy...now why didnt I think of that.....duh!
Old May 19, 2009, 02:51 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
Here is a link to a simple float system that can be easily modified for either the spline or flat plate fitting
build here..
http://www.rcgroups.com/forums/showt...ghlight=floats
here they are on a Nutball
RC Nutball on floats (1 min 9 sec)
Old May 19, 2009, 07:02 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Great thread Dave!
The tip of a prop blade is a great tool for parting Velcro.
It is also an OK tool for removing adhesive backed Velcro from surfaces that are covered with tape.
I usually have a couple of broken off propeller blades around the work bench and in the field gear bag. They make great PU spreaders too, especially the SF props.
Dave's probably never broken one... :>)
Jack
jackerbes is offline Find More Posts by jackerbes
Old May 19, 2009, 08:07 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
Some time back JIMSP had a nutball flying from water with nice simple add on floats.
see above
Ive now drawn them up in sketchup..now using the sketchup file from the zip they can be scaled to suit any sized Nutball or remembering the nutball cog for this 24" plan is at 6" back these floats could be added to almost anything.
Remember
the floats should be scaled up for the weight of the plane... a 24" nutball weighs about 8-10oz
the floats need to be positioned with a few degrees + for the wing and for the cog to be in the correct position
..for this size float the back of the front leg should be 1" in front of the COG of your plane..if you scale up remember to scale up this distance as well
Old Jul 20, 2009, 05:12 PM
davereap is offline
davereap's Avatar
Joined Feb 2005
video by Parrot Pilot nice one
Nifty RC plane landing beer gear (4 min 26 sec)
Old Nov 03, 2009, 06:59 AM
Jimmy JFlyer is offline
Find More Posts by Jimmy JFlyer
For us He died, in me He lives
Jimmy JFlyer's Avatar
United States, MI, Saint Clair Shores
Joined Dec 2008
Just bumped into this thread from the NB thread. Nice stuff!
This is gonna help out a lot in the future on the build list that never ends.
THX!
Jimmy
Jimmy JFlyer is offline Find More Posts by Jimmy JFlyer
Old Nov 03, 2009, 03:03 PM
philba is offline
Find More Posts by philba
Prop Buster Extraordinaire
philba's Avatar
Seattle
Joined Aug 2009
Interesting ideas. I've been using more velcro of late and liking it a lot more.
One idea for a tail dragger that I've played with is similar to post #4 but used a plywood plate on the bottom and several small screws to mount the wheel assembly to that. I didn't like the weight implications but you don't have a lot of choice for a tail dragger.
philba is offline Find More Posts by philba
Old Dec 09, 2009, 06:36 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
The velcro strips grip more than strong enough.. the systems can be made lighter or scaled up for larger designs, As yet I havnt had one come loose despite all I put the models through.
I did rip one loose in a heavy crash, but I am sure this acted to lessen the damage on impact, like the softer crash areas built into cars, The motor shaft got broken the UC came off the model was just fine.. and boy did it hit with a bang..
Old Dec 21, 2009, 06:13 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
A new trike version is added at post 1..as its suitable for planes with lower spline fuzes
also here is my horten using system no:2 the flat plate trike held with velcro
Collector's U/C Kit plans (convert to R/C?) iker3 Aircraft - Fuel - Airplanes (FS/W) 0 Jan 22, 2005 06:59 PM
GWS Spitfire/109, Lithium Ion's and U/C mattski GWS (Grand Wing Servo) 6 Sep 13, 2003 05:40 AM
Twin Star plug-in trike u/c ... pictures Bill Glover Foamies (Kits) 9 Feb 18, 2002 07:44 AM
4/5's sub c's for power tool use.. Looooeeee! Power Systems 0 Sep 30, 2001 03:20 PM
C S R buzz3476 Electric Sailplanes 2 Jul 14, 2001 09:48 PM
