Joined Sep 2008
questions on kyosho spree sports power system
Hi guys, we have 2 spree sports - the first we built, and tried to fly - but the battery pack we bought was too heavy for the plane - please could someone recommend a suitable battery for the plane? with decent run time...we went and returned the battery we bought (a nicad one, with tamiya plug) but unfortunately they didn't have any lighter ones.
it has a 380 brushed motor, with a 20A esc. and needs a 8.4v/9.6v nicad battery. also, for the 2nd spree we plan to upgrade with system (motor, gear reduction and prop). since we are beginners, i am not sure if this would be sufficient:- http://i13.ebayimg.com/02/i/001/0f/7d/6d80_1.JPG what kind of ratio gear box would we need with this motor and ESC, and what kind of prop? any advice is much appreciated - we would really love to get flying!
Ok, so here's a little bit od advice for eBay items:
If it has "Mystery" clearly labeled on the motor/ESC, then it's probably crap and don't even bother with it. As for a power system, just upgrade both to brushless. Ditch the heavy geared application, and go with an outrunner. Here's a nice power upgrae system, with motor, ESC, and battery ready to go: http://www3.towerhobbies.com/cgi-bin...?&I=LXRNF8&P=7 Pricey, but is high quality, and ready to go and is perfect for the spree sports. Much more power ready on hand (should give you near vertical performance). Also, you WILL need a lipo charger. You can get a decent one for less then $100, like the Triton Jr.: http://www3.towerhobbies.com/cgi-bin...&I=LXMAH9&P=ML This is the more expensive end of the power systems you can get. I'm certain people will chime in here with cheaper power systems. Also, I really suggest finding a local flying field, and hooking up with one of the members on a buddy box if you have not flown before. They can ensure your success in the hobby, and help you earn your wings faster then you can alone. Also, The Academy of Model Aeronautics (AMA) is a good idea. AMA membership is required at most flying clubs in the U.S., and it can eally help out incase something happens. In basic terms, they are model aircraft insurrance (no, they won't pay to fix your plane if you crashed it). It's a good idea to have it, just incase. |
Outrunners eliminate the need for the gearbox. The prop just mounts to the shaft using either a prop saver (collet with 2 screws) or a clamp style mount.
As for acheaper power system (price, not value), here: Motor: http://www.hobbycity.com/hobbycity/s...less_Outrunner ESC: http://www.hobbycity.com/hobbycity/s...eed_Controller Battery: http://www.hobbycity.com/hobbycity/s...00mAh_3S1P_20C Prop: http://www3.towerhobbies.com/cgi-bin...?&I=LXGXB0&P=7 Charger (I have this one, it's the best I have used): http://www.hobbycity.com/hobbycity/s...idProduct=7028 That's about all you need. Should be a drop in upgrade, and most certainly will give you more power then that junky 380 system. Total price: Less then $100. |
| Thread Tools | |
| Suggestions on Nike 2 Power System | car4 | High Performance | 25 | Jul 11, 2004 10:57 PM |
| Spinner on an Endo power system? | mad mike | Electric Plane Talk | 2 | Sep 29, 2003 08:15 PM |
| GWS Beaver on an IPS power system. | pc_pilot | Parkflyers | 6 | Jun 25, 2003 03:57 PM |
| Removing the dihedral on Kyosho Spree wings... | tnsfrk | Electric Plane Talk | 3 | May 11, 2003 10:10 PM |
| Questions on Dymond charger power supply? | snowman610620 | Electric Plane Talk | 7 | Feb 22, 2002 06:59 PM |
