Old Oct 10, 2008, 10:10 PM
jbarr2000 is offline
Find More Posts by jbarr2000
Joined May 2008
Charging packs without balance taps with balance charger?
I've searched but I didn't see anything useful.
Basically I have a 3s lipo with no balance taps. LHS has a decent charger but is a balance charger only. Is there a way to charge the battery with that charger or should I just wait for shipping and get something else?
jbarr2000 is offline Find More Posts by jbarr2000
Old Oct 10, 2008, 10:25 PM
Zerts is offline
Find More Posts by Zerts
John,not Zerts.JOHN, NOT Zerts
USA, AZ, Chandler
Joined Nov 2007
This is sort of a no-win situation - that battery w/o balance taps isn't going to last nearly as long anyways, especially if it is in a high discharge rate application. It would make sense to just consider the battery expendable (all Lipos are anyway) and buy batteries with balance taps in the future.
You have 2 options for batteries with balancing taps - get a balance charger, or get a non-balancing charger and a separate balancer (which is not as failsafe- you have to be aware of the conditions that will spike a cell despite the balancer).
Zerts is offline Find More Posts by Zerts
Old Oct 11, 2008, 12:46 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
I emphatically agree that it's very wise to only consider lipos that are manufactured with balance taps as they're really the only way to fully understand the health of your packs. Whether packs with taps will last longer than packs without taps, however, is not so clear cut. I have some very high quality packs that are approaching three years old that are still performing as wonderfully as when I put them in service, yet have never required balancing. This is after over 160 discharges. The packs do have taps and I check them from time to time and all cells are generally within .01-.02V. Granted my application is not too tough on them and they've never been flown to LVC nor have they ever seen 120F.
Matter of fact, I cannot recall seeing any lipolys recently that did not have manufacturer installed taps ('cept the small TP's) so it looks like taps are approaching ubiquity.
mrforsyth is online now Find More Posts by mrforsyth
Old Oct 11, 2008, 01:10 AM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
Can't answer the posed question without knowing the charger the LHS is offering.
Bill
ebill3 is offline Find More Posts by ebill3
Old Oct 11, 2008, 09:38 AM
Joined May 2008
The other two batteries I have have taps, so it's just this one. I bought it used and didn't think to ask if it had taps and it wasn't disclosed, lesson learned. I got it for pretty cheap so no big deal. I'll be runnin the thing less than 18 amps, probably less than 15.
I wish I could remember the name of the charger now, but I can't. I may just end up ordering something online. Any suggestions to take care of my batteries?
Old Oct 11, 2008, 10:30 AM
Zerts is offline
USA, AZ, Chandler
Joined Nov 2007
The Bantam BC-6 is excellent.
Old Oct 11, 2008, 10:33 AM
So. Cal.
Another thing you may consider is to add balance taps yourself. This would require carefully removing the shrink wrap on the end of the pack where the discharge wires exit, soldering wires to the PCB, and then recovering. I've performed this exercise a few times when the manufacturer installed tap wires have broken off and it's really not too difficult if you're comfortable with soldering. Just need to be careful when removing the shrink wrap to ensure that you don't cut into a cell or tab.
Adding taps is really the only way to know that your pack is healthy an in balance and will eliminate any nagging concerns about a catastrophic event should the pack go grossly out of balance. This will also allow you to purchase the balance charger that you're considering and use it with all of your packs.
Most common tap types (TP, Hyperion, JST-XH) are very easy to find and quite reasonably priced.
Old Oct 11, 2008, 10:53 AM
Zerts is offline
USA, AZ, Chandler
Joined Nov 2007
The Align style taps are the most prevalent.
Old Oct 11, 2008, 11:06 AM
gulio is offline
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
I'm all for "tapping" the pack. Won't most balance chargers charge without having to balance?
gulio is offline Find More Posts by gulio
Old Oct 11, 2008, 11:56 AM
Joined May 2008
I thought I had seen some adapters that were a deans ultra to a balance (jst or whatever) plug so you could plug it into your balance charger. That's really what I was getting at.
Old Oct 11, 2008, 12:05 PM
Zerts is offline
USA, AZ, Chandler
Joined Nov 2007
I don't understand that. To have balancing capability, you need number of balance tap wires=number of cells+1
Old Oct 11, 2008, 02:33 PM
Joined May 2008
This is what I'm talking about....
http://www.parkzone.com/Products/Gal...KZ1040&Index=0
Old Oct 11, 2008, 04:12 PM
Zerts is offline
USA, AZ, Chandler
Joined Nov 2007
Ok, thats your charging lead adapter for when you don't have Deans on both the charger and the battery. Most people have Deans on both, but I can see a need for adapters if you can't solder.
Old Oct 11, 2008, 06:29 PM
Joined May 2008
Sorry for being a little slow on this but...
So that would charge the battery if you had a charger that didn't have deans connectors and a battery that didn't have balance taps? I think I've found a charger, but I'd still like to know.
Old Oct 11, 2008, 07:02 PM
Zerts is offline
USA, AZ, Chandler
Joined Nov 2007
What charger are you looking at?
A lot of chargers dont have the male Deans, or in some cases you pay extra to have them. If you can't solder, is there anyone local that could show you? If not, just get the adapters you need.
If you are buying this charger at a LHS, they should be answering these questions. If they don't, try another LHS.
Thats what I did to get started because I had 100's questions at first. But I did have soldering experience. The most common connector is female Deans Ultra on the battery.
For Sale DN Power NU GEN 25C 2150mah 11.1v 2 Packs with balance charger and power supply sircrashesallot Aircraft - Electric - Batteries & Chargers (FS/W) 0 Dec 06, 2007 08:25 PM
Help! Balance Charging Two LiPo Batteries at the Same Time with One Charger and Balancer write2dgray Batteries and Chargers 18 Aug 22, 2007 01:20 PM
Does Align Balance Charger work with Thunder Power batteries? kenster Mini Helis 2 Jul 30, 2005 07:09 PM
Rant Help With Charging Packs On A Dymond Charger!!!!! nieves50 Batteries and Chargers 9 Mar 20, 2004 05:20 PM
Charging 150 MaH Ni-cad with Apex charger YEAP CHIN POH Batteries and Chargers 0 Dec 19, 2002 08:18 PM
