Old May 21, 2009, 12:01 PM
VF84Sluggo is offline
Find More Posts by VF84Sluggo
Wood flight decks, guns only!
VF84Sluggo's Avatar
Gulf Breeze, FL
Joined Nov 2007
Yeah, I got the "LOW BONES" light big-time!
VF84Sluggo is offline Find More Posts by VF84Sluggo
Old May 21, 2009, 01:40 PM
i3dm is offline
Find More Posts by i3dm
RC pilot by soul
Israel
Joined Apr 2005
OK guys, mine is almost ready to fly !
I just fired up my Medusa motor 036-050-2200V2 for the first time on stock fan, stock pack (5S 3700mAh chinese make) and Suppo Model 100A ESC.
Result - 70A and 1300W. I think it should fly *well* but i feel like i should go 6S on this bad boy ! i reckon it should be closer to 2kW.
Here are some pics of my plane with the mods i did.
i3dm is offline Find More Posts by i3dm
Old May 21, 2009, 02:09 PM
Pepperpete is offline
Find More Posts by Pepperpete
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
Originally Posted by MYC
Pete,
I gave you my watt/amp readings on the two so if you are still using the 1490/Haoye I would say you are going to see ~65 watts and close to 1500 watts.
oops! I missed that. Thanks. I just didn't do the math but that makes it pretty clear. Strange that your Amps went down to 65 WOT?
Pepperpete is offline Find More Posts by Pepperpete
Old May 21, 2009, 02:11 PM
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
Ooo! Magnets on the top deck to keep it in place better...I think I need to do that as well. It won't come off as it is but that should keep it locked down tight. What weight are you at with everything? You are getting identical readings on power as I am so I am curious to know how she flies. Mine fly's "fine" on 5C but it's lacking power. 6C should fix that right up. Currently I'm at 5.6 Pounds but I'm about to shed 100 grams of weight (making it 5.37) switching to the 6C. I wish I could get to a straight 5 but I like the rest of the gear as it is.
Old May 21, 2009, 03:11 PM
MYC is offline
MYC
Find More Posts by MYC
MYC
Inconceivable!
MYC's Avatar
USA, NY, Smithtown
Joined Jan 2005
Well, ~ = around... 65, the batt wasn't 100% and I bet it will spike up a bit more with more juice...
MYC is offline Find More Posts by MYC
Old May 21, 2009, 08:18 PM
merlinfan is offline
Find More Posts by merlinfan
Throttle Bender
merlinfan's Avatar
Joined Jun 2008
12 flights now. Got a nearly new TP 6s 5000 25c but am afraid to try it. Afraid of a smoke trail.
merlinfan is offline Find More Posts by merlinfan
Old May 21, 2009, 08:28 PM
jet-ster is offline
Find More Posts by jet-ster
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
Nah, it's just part of the show!
jet-ster is offline Find More Posts by jet-ster
Old May 21, 2009, 09:01 PM
obxfishfuzz is offline
Find More Posts by obxfishfuzz
Kill Devil Hills 27948
Joined Mar 2009
I3DM:
like the mods you did! but what did you do on the upper side of the wings? looks like a slice from one side to the other??and did you do anything to the nose wheel to get the slop out?I have the Jolly Rodger one plus got the Blue Ang. to do the mods on,still not crazy about the landing gear
http://s267.photobucket.com/albums/i...t=DSC02784.jpg
http://s267.photobucket.com/albums/i...t=DSC02779.jpg
obxfishfuzz is offline Find More Posts by obxfishfuzz
Old May 21, 2009, 09:29 PM
jet-ster is offline
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
rcvincent, WOW 1700 for js1490 would be great! Please tell me how to reach this goal! I really like this motor for it has a GREAT flight time. How did you get it to near 1700 watts? 6 cell? 8cell? As for the KILLER 90mm motor that thing is MAD CRAZY! Gezz 4000 watt, I might have to bring my power generator to run that thing . Midi fan might not be for that motor. What fan are you gona recommend for that one?
Old May 21, 2009, 09:44 PM
rvincent is offline
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
6 cells and 77 amps is 1700 watts Yeah the killer motor will need like a TJ100, or a Stumax, or a DS-51 Something that will be able to handle it.
rvincent is offline Find More Posts by rvincent
Old May 22, 2009, 05:20 AM
i3dm is offline
RC pilot by soul
Israel
Joined Apr 2005
Originally Posted by obxfishfuzz
I3DM:
Upper side of the wings has a FLAT carbon spar sliced and glued into the wings.
Here is what i have done with the nose gear so far. the black plastic piece is a Futaba servo horn.
I noticed most of the side slop comes fromt he channel in which the strut bolt runs in. how can i fix this ?
Old May 22, 2009, 07:00 AM
MYC is offline
MYC
MYC
Inconceivable!
MYC's Avatar
USA, NY, Smithtown
Joined Jan 2005
I ran up the twin Haoye/LS 1490 setup yesterday. The first part of the clip shows the watts up meter...
http://www.rcgroups.com/forums/show...05#post12291448
try this one if the above doesn't work...
http://www.rcgroups.com/forums/showt...5#post12291448
Don't watch the rest of the clip if you don't want to see an "ugly" A-10
Old May 22, 2009, 07:08 AM
i3dm is offline
RC pilot by soul
Israel
Joined Apr 2005
MYC - link is dead.
Old May 22, 2009, 07:13 AM
MYC is offline
MYC
MYC
Inconceivable!
MYC's Avatar
USA, NY, Smithtown
Joined Jan 2005
Ok, this is the link to the blog page 2... the link works from there
http://www.rcgroups.com/forums/showt...=973767&page=2
Old May 22, 2009, 07:24 AM
MYC is offline
MYC
MYC
Inconceivable!
MYC's Avatar
USA, NY, Smithtown
Joined Jan 2005
i3dm, The strut is the culprit up front. Guys have tried everything from sleeving the channel to locking it out but ultimately it comes down to poor design/execution and the only real fix is replacement. Due to my own bad luck/incompetance my original strut is fubar so I adapted the Haoye FA-18 nose strut and it works great. I'm sure there are other alternatives out there, it might just take some looking
Discussion List of EDO, Elapor, or Z-foam Jets with Landing Gears MinneFlyer Foamy EDFs 8 Dec 08, 2009 09:05 PM
For Sale almost new ds285 with metal gears for sale driftinsequence Aircraft - General - Radio Equipment (FS/W) 2 Mar 25, 2007 10:44 PM
Discussion for Trex 450 owners-new landing gears skid set/yellow-durable,sturdy ELERC Mini Helis 68 Jan 20, 2007 07:09 PM
***Heliup new STRONG LANDING GEARS*** HighFreq Mini Helis 83 Feb 09, 2006 09:06 AM
3D foamy Cap 232, New in package with optional carbon fiber landing gear set JPA2002 Aircraft - Electric - Airplanes (FS/W) 3 Jan 25, 2005 10:33 PM
