Old May 30, 2009, 04:27 PM
dro56595@bigpo is offline
Find More Posts by dro56595@bigpo
dro56595@bigpo's Avatar
Australia, ACT, Symonston
Joined Aug 2008
Finally got a start on the build.
First job - see how the RC-Lander fan fits. First hurdle - a bit too big! Spent the evening carefully Dremelling foam.
It's starting to get cold here. The workshop is very chilly at night, and so is the wife
Next job - determine cable lengths and solder connections.
dro56595@bigpo is offline Find More Posts by dro56595@bigpo
Old May 30, 2009, 04:50 PM
jet-ster is offline
Find More Posts by jet-ster
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
Lithonion
HOLLY COW! thats going to be one hell of a paint job!
jet-ster is offline Find More Posts by jet-ster
Old May 30, 2009, 07:08 PM
Pepperpete is offline
Find More Posts by Pepperpete
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
The Hayoe fan was a bit too big as well. Was pretty easy to make the room though. I am extremely curious to see how the RC Lander fan will perform.
Pepperpete is offline Find More Posts by Pepperpete
Old May 30, 2009, 11:03 PM
Joined Aug 2008
Me too!
Old Jun 02, 2009, 08:58 AM
cray2602 is offline
Find More Posts by cray2602
Fan-atic
cray2602's Avatar
Plain ole KS
I got my 2200mah 3s batterys in and installed them in the F-18. They fit perfect and the CG is close to spot on, however the wireing is a mess with four batterys wired together to make a 6s2p pack. Havent come up with a solution yet to get all the wire mess to fit under the hood. I think im going to also install a switch between the batterys and the BEC/ESC, the spark that jumps out when i connect the main battery wire is scary.
My nose retract servo quit locking the nose wheel in the down position with the extra weight of the batterys and the nose steering servo doesnt have enough torque to even turn the front wheels with the batterys in. This jet is driving me crazy. By the time im going to be done fixing all this junk i would have been able to build this jet from scratch. Im going to just lock all the retracts down with collars for now and fix it all someday later on.
cray2602 is offline Find More Posts by cray2602
Old Jun 02, 2009, 11:08 AM
QueeQueg is offline
Find More Posts by QueeQueg
12S Or Bust
QueeQueg's Avatar
Joined Apr 2009
All the time effort and money that it seems to take to get the retracts working reliably it's looking possibly more cost effective to go with some of current smaller air setups.
It's taking something like the HS 225MGs with 55 to 65 in ozs of torque to operate them properly. One of these weighs as much as up to 3 of the stock servos. And the trouble to get them fitted.
I looked at the BH photo spread on the V2s and if you look closely the front retracts aren't sitting all the way into the recess in flight although when turned over for a close up they are. So I'll bet they just stuck some of the same 9 to 12G, 20 or so in oz MG servos in place of the original plastic gears and that's not likely to fix the issue long term.
QueeQueg is offline Find More Posts by QueeQueg
Old Jun 02, 2009, 11:16 AM
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
Once you are rolling the nose wheel will probably steer as it doesn't take much. Mine hardly moves either when I am not moving forward but has plenty once the friction of being dead stopped is removed so I wouldn't worry about that.
That spark is normal. I get that all the time on my planes/heli's. It's alot of juice. It won't cause any harm.
Your front gear locking down. You need to loosen off the screw that is holding your pushrod to the servo itself, pull on the wire so that it is totally locked down in the down position, and then resecure the screw. Do that to all three. And THEN retract the gear and use the travel ajustment to get them up as far as you can into the belly. Honestly the weight has nothing to do with locking the gear. It's setup.
Old Jun 02, 2009, 11:22 AM
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
I can't really agree with that. HS-225's are the same cost as the HS65's. The "trouble" to get them fitted is 20 seconds with an exacto knife so I'm not sure what you consider as trouble. As for weight...an air system is going to weigh just as much. Now this is all based on the kit version of the aircraft. If you are having to swap everything from the ARF...then yup it's a pain but no more so than installing an Air System. But as I've said before...without a JR Matchbox or some form of digital ajustment for the retracts, I would have been just as frustrated. And no I don't own stock in JR. :P
Old Jun 02, 2009, 12:13 PM
cray2602 is offline
Fan-atic
cray2602's Avatar
Plain ole KS
I did that to all of mine and it worked , however one of my rear servos had allready got worn out and stripped from to much torque needed by the time i got it working correctly. The nose gear i got working perfectly but after i put the batterys in all of a sudden it wouldnt stay locked in the down position because of the anlge of the servo arm and the retract pull rod is kinda whacky. Ill get it all working later on, i just want to get it in the air for now and make sure everything else is gonna hold up.
The spark on the 6s battery setup is enourmos, im used to the usual spark but man when i hook up that 6s battery it scares you if you arent ready for it.
Old Jun 02, 2009, 12:15 PM
QueeQueg is offline
12S Or Bust
QueeQueg's Avatar
Joined Apr 2009
I've already decided against the ARF. Mostly because I have a lot of stuff already usable for this.
I'm looking at doing the airframe only and if I can simplify things with airs than that's my plan.
You're probably right as far trouble to do but I'm also looking at the overall end product.
I've never had any airs and every set of mechanical retracts I've had have given me more grey hair so being a glutten for punishment I'm thinking about trying some since they're down to 130 bucks.
As far as spark you should try a 12S pack sometime. I've had spectators jump when I plug them up
Old Jun 02, 2009, 12:44 PM
cray2602 is offline
Fan-atic
cray2602's Avatar
Plain ole KS
Cant imagine the spark from a 12s battery, I almost ducked for cover the first time i hooked up the 6s. I suppose it would never arc across the Deans plug and cause a short while hooking it up could it?
Old Jun 02, 2009, 12:52 PM
QueeQueg is offline
12S Or Bust
QueeQueg's Avatar
Joined Apr 2009
Not with DC. Or at least I hope not!!
Some of the European ESCs like Kontronics don't spark. That have some sort of capacitor setup that absorbs the initial spike. Be nice if the rest would follow suit.
Old Jun 02, 2009, 01:03 PM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Tam sells the same style thing. Plug this into your lipo setup first, then into the ESC.
http://www.tamjets.com/original/prod...roducts_id=431
Sid3ways is offline Find More Posts by Sid3ways
Old Jun 02, 2009, 01:29 PM
QueeQueg is offline
12S Or Bust
QueeQueg's Avatar
Joined Apr 2009
That's neat.
I'm used to it by now. Been flying HV stuff since NiCads at 32 cells. Before Deans plugs were available the best around were the Astroflights and they were toast within about 50 flights.
Old Jun 02, 2009, 08:27 PM
cray2602 is offline
Fan-atic
cray2602's Avatar
Plain ole KS
Ran up the motor on my 6s2p setup. I shut it down at 92amps around 1950watts. Not sure how high the amps would have ended up at WOT, any more and im sure something would have smoked. And that run was at 50% battery capacity. I am going to try limiting my throttle end point and see if i can keep it around 75amps or so at WOT. No luck with that so far.
Also blew up the rotor spinner. Luckily it didnt shatter the fan to. Inspected the blades and didnt find any cracks. The spinner didnt come loose it just broke, the screw was still tight and had a round piece of spinner plastic still under it. I contemplated leaving it off in the first place cause i had a feeling that wasnt going to hold up.
Discussion List of EDO, Elapor, or Z-foam Jets with Landing Gears MinneFlyer Foamy EDFs 8 Dec 08, 2009 08:05 PM
For Sale almost new ds285 with metal gears for sale driftinsequence Aircraft - General - Radio Equipment (FS/W) 2 Mar 25, 2007 09:44 PM
Discussion for Trex 450 owners-new landing gears skid set/yellow-durable,sturdy ELERC Mini Helis 68 Jan 20, 2007 06:09 PM
***Heliup new STRONG LANDING GEARS*** HighFreq Mini Helis 83 Feb 09, 2006 08:06 AM
3D foamy Cap 232, New in package with optional carbon fiber landing gear set JPA2002 Aircraft - Electric - Airplanes (FS/W) 3 Jan 25, 2005 09:33 PM
