Old May 25, 2009, 06:04 PM
Pepperpete is offline
Find More Posts by Pepperpete
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
Originally Posted by rvincent
And this plane is better just a bit forward of the recomended CG point I fly mine about 5mm forward
Just to clarify...you mean towards the nose right? So you recommend 95mm then? I just received my 6Cell so I have to redo this.
Pepperpete is offline Find More Posts by Pepperpete
Old May 25, 2009, 06:36 PM
cray2602 is offline
Find More Posts by cray2602
Fan-atic
cray2602's Avatar
Plain ole KS
[QUOTE=merlinfan]I got a good deal on a TP 6s 5000 and the plane balances at the forward CG limit with it.QUOTE]
Good to know. I should be fine with a 5s larger than the stock recomendation then.
Im having some problems with my retracts. I can get the nose gear to lock in both directions. But i can only get the rear wheels to lock in down position. With all 3 gears running off of the same TX channel i cant adjust the throw of the front and rear independantly. When the front wheels lock in up position the rear wheels are just a hair short of getting locked. The instructions included are beyond basic. Maybe i will just run the front and rear gear off of seperate channels.
cray2602 is offline Find More Posts by cray2602
Old May 25, 2009, 08:36 PM
jet-ster is offline
Find More Posts by jet-ster
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
Crazy2602-from what we have learn so far is that yes stock setup can be flown on six. It's pretty fast i believe. BUT there was only one were the stock fan has blown-up. About retracts you will most likly spend more time tinkering with it then any part. I did split mine up to 3 channels and it worked great. THEN after that servos started to give up . O well over all this thing is a great in the SKY! If you feel that you have skipped any of the pages feel free to ask anyone of us. We have a REALLY GREAT GROUP HERE!
jet-ster is offline Find More Posts by jet-ster
Old May 25, 2009, 08:51 PM
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
I have two words for you.
JR Matchbox
No more problems. It lets you adjust each servo's end points independently even when they are all on the same channel. Saves you hours of screwing around. I've never had a gear fold and they make NO buzzing noises up or down because you can adjust them just right.
http://www.horizonhobby.com/Products...ProdID=JRPA900
It is a tad pricey though. It does work on all servo's (analog or digital).
[QUOTE=cray2602]
Old May 25, 2009, 09:22 PM
1bwana1 is offline
Find More Posts by 1bwana1
Gotta have toys!
La Jolla, CA. USA
Joined May 2006
You can also use the Smart-Fly Equalizer 3-D. It's smaller, lighter, less expensive, and even easier to use.
http://www.smart-fly.com/Products/Eq...qualizer3d.htm
Both the Smart-Fly and the JR-Matchbox are often available used in the "for sale" forums at really good prices. I highly recommend either.
1bwana1 is offline Find More Posts by 1bwana1
Old May 25, 2009, 10:11 PM
cray2602 is offline
Fan-atic
cray2602's Avatar
Plain ole KS
6s capable. Thats what i wanted to hear. A pair of 3s should be easier to match up than a 3s and 2s combined. Thanks for the tips, ill spend some time searching and picking through this thread. Im sure most of this info is probably burried in here somewhere.
Never heard of either of those products, ill look into that. My nose gear retract servo seems to buzz most of the time whether its up, down, or in between. Im wondering if they will last long. I set mine up to move via the flap trim knob on the Tx. I didnt like how fast they retracted using the gear switch, the trim knob allows me to move them at a nice slow speed up or down.
Old May 25, 2009, 10:12 PM
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
Even better! =)
Old May 25, 2009, 10:23 PM
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
Well guys...
I just installed my new 6C 3200 battery. I saved overall 107 grams of weight (not exactly a small amount) and had to move 7 grams to the nose to balance it out after some rearranging of internal component.
And holy hell... I am now getting 1540 watts at 79 Amps!!! Vs 1240 at 70 amps. The plane now holds itself up instead of dropping to the floor. I am so pumped to give this a go.
I have one major concern. I realize I am not in the air which should help but this pack is getting mighty warm even in testing. I've cut out the two oval area's in the main deck (which looks fine) but I am not sure if it's enough for airflow.
Those running 6C, have you had any problems with heat?
Old May 25, 2009, 10:38 PM
cray2602 is offline
Fan-atic
cray2602's Avatar
Plain ole KS
If your 3200mah lipo is a 25C then 80amps is the limit for it. You also can only get 2.4 minutes of WOT before the battery is drained to 0% if you pulling about 80amps out of it. But with that much power you wont need to fly at WOT much.
Old May 26, 2009, 11:31 AM
He builds stuff. :)
Pepperpete's Avatar
Canada, BC, Kelowna
Joined Sep 2007
I'll just have to be really careful.
It's a HobbyKing Zippy pack rated at 20-30C so I have no idea what it really is.
I am not too worried though as at 3quarter stick it drops down to 50 amps and at half stick it's at 35. So as long as I'm not doing curcuits in full afterburner...I'll probably get a solid 4 minute flight which is fine.
Old May 26, 2009, 11:50 AM
cray2602 is offline
Fan-atic
cray2602's Avatar
Plain ole KS
Zippy packs are actually pretty good packs. As good or better than alot of the high $ name brands. Im looking through the HC lipos today to find a combo i can wire up for 6s2p . I hate to spend $100+ on a single 5s or 6s lipo that i can only use on one plane. So i might just buy four 3s1p 2200mah packs and wire them up to make a 4400 6s2p pack. I also dont have a charger that can charge a 5s or 6s pack, so this route might kill two birds with one stone.
Old May 26, 2009, 12:33 PM
Mannyman535 is offline
Find More Posts by Mannyman535
edf flyer
Mannyman535's Avatar
United States, CA, Marina
Joined Feb 2009
cray2602
Let me know how that works for u. the two lipos wired together.
I was thinking of using a 18.5v 4000mah 15c, I think the 15c is low. though
Mannyman535 is offline Find More Posts by Mannyman535
Old May 26, 2009, 01:15 PM
MYC is online now
MYC
Find More Posts by MYC
MYC
Inconceivable!
MYC's Avatar
USA, NY, Smithtown
Joined Jan 2005
Guys. You do know you have to be real carefull running two "unmatched" packs in parallel, right? The theory is that if one pack has a cell or two that start at lower voltage than the other cells, when you run the whole "pack" down to LVC, the low cells could be below minimum voltage and well... poof. My workaround when I do this is to make sure not to get near LVC and/or balance charge the packs before each use.
MYC is online now Find More Posts by MYC
Old May 26, 2009, 01:20 PM
rvincent is online now
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Hi Pete,
Yes I do mean 95mm or forward
rvincent is online now Find More Posts by rvincent
Old May 26, 2009, 01:22 PM
Lynxman is online now
Find More Posts by Lynxman
Lynxman's Avatar
Troms, Norway
Joined Jan 2004
That's when packs are connected in series. When they are ocnnected in parallel the current is distributed between the packs so that they drain at the same rate. Even if two packs of different capacity are used they will always have the same voltage. Such is the nature of a parallel circuit.
Never reach LVC with series packs because unless the packs are matched one pack will probably drain before the other and the first pack that runs out is then damaged.
Lynxman is online now Find More Posts by Lynxman
Discussion List of EDO, Elapor, or Z-foam Jets with Landing Gears MinneFlyer Foamy EDFs 8 Dec 08, 2009 08:05 PM
For Sale almost new ds285 with metal gears for sale driftinsequence Aircraft - General - Radio Equipment (FS/W) 2 Mar 25, 2007 09:44 PM
Discussion for Trex 450 owners-new landing gears skid set/yellow-durable,sturdy ELERC Mini Helis 68 Jan 20, 2007 06:09 PM
***Heliup new STRONG LANDING GEARS*** HighFreq Mini Helis 83 Feb 09, 2006 08:06 AM
3D foamy Cap 232, New in package with optional carbon fiber landing gear set JPA2002 Aircraft - Electric - Airplanes (FS/W) 3 Jan 25, 2005 09:33 PM
