This thread is privately moderated by Heat Sink, who may elect to delete unwanted replies.
Old Oct 09, 2008, 11:40 PM
Heat Sink is offline
Find More Posts by Heat Sink
Trader Rating: 7
Custom User Title
U.S.A ~Florida
Joined Jul 2008
Trader Rating: 7
Sold
NIB E-flite 60-Amp Pro Switch-Mode BEC Brushless ESC
Brand new in the box. I am not going to use and I just missed the dead line to return. Nice ESC, can run many servos.
75.00 shipped to your door.
Key Features
Up to 60A continuous current with proper air flow with 75A peak
5V Switch-Mode BEC circuit capable of 2.5A continuous current on any recommended input voltage
Drives up to 7 analog or 6 digital standard-sized servos, with the BEC on any recommended input voltage
3–6S Li-Po, 9- to 18-cell Ni-Cd/Ni-MH input voltage
Finned heat sinks
Programmable motor braking
Safe power-arm mode prevents accidental starts
Programmable low voltage cutoff with settings for 3-cell Li-Po (9V), 4-cell Li-Po (12V), 5-cell Li-Po (15V), 6-cell Li-Po (18V), or 70% of battery starting voltage
Programmable soft start for helis and airplanes
Auto motor shut down if signal is lost or there is interference
Programmable timing—5 user-selectable ranges for use with a larger variety of brushless motors
Programmable throttle input range (1.1–1.9 ms or 1.2–1.8 ms)
Utilizes new smaller MOSFETs technology to minimize weight
Radio System Power On/Off Switch
Optional RS232 Serial Link available for programming
Pre-wired connectors—E-flite EC3 on battery input and 3.5mm female gold bullets on motor output leads
Specs
Brake:Yes - Programmable
Continuous Maximum Current:60A with reasonable cooling
Input Voltage:10.82–2.2V
Input Connector Types:13 AWG with E-flite EC3 connector
Output Connector Types:13 AWG with 3.5mm Female Gold Bullet Connectors
Momentary Peak Current:75A (15 sec)
Dimensions (WxLxH):76x33x13 mm (3x1.3x.5 in)
Weight:66 g (2.3 oz)
Wire Gauge:13 AWG
Cells w/BEC:3-6S Li-Po or 9-18 Ni-MH/Ni-Cd
Heat Sink is offline Find More Posts by Heat Sink
Old Oct 10, 2008, 11:19 AM
dinchl is offline
Find More Posts by dinchl
Trader Rating: 84
USA, CO, Grand Junction
Joined Feb 2005
Trader Rating: 84
I'll take it. PM sent
dinchl is offline Find More Posts by dinchl
Old Oct 10, 2008, 12:27 PM
Trader Rating: 7
Custom User Title
U.S.A ~Florida
Joined Jul 2008
Trader Rating: 7
Payment Received. Thank you!!
Sold 60-Amp Pro Switch-Mode BEC Brushless ESC by E-flite ultimate lvr Aircraft - Electric - Power Systems (FS/W) 3 Jul 24, 2008 06:32 PM
Sold E-flite 25-Amp Pro Brushless ESC chuckpee Aircraft - Electric - Power Systems (FS/W) 0 Jul 22, 2008 01:39 PM
Found E-flite 10-Amp Pro Brushless ESC EFLA1010 nitrodude71 Aircraft - Electric - Power Systems (FS/W) 3 Feb 03, 2008 08:29 AM
For Sale Two E-flite 25-Amp Pro Brushless ESCs fiveoboy01 Aircraft - Electric - Power Systems (FS/W) 2 Sep 28, 2007 02:29 PM
For Sale E-Flite Park 300 Brushless Motor and E-Flite 10 Amp Pro ESC! 1 use each! RCisAddicting Aircraft - Electric - Power Systems (FS/W) 0 Apr 03, 2007 05:11 PM
