Bay Area, CA
Joined Sep 2007
Tilt rotor VTOL
Here is my VTOL project so far.
I still need to work on the left tilt section. I screwed up the control horn angle (not in sync with the right tilt section), but this gives you an idea. My build blog with few additional details. http://www.rcgroups.com/forums/showthread.php?t=898966 Bench testing of tilt mechanism. Project VTOL - Part 4 |
If you're trying to find the ideal prop, in general, a larger prop will give better static thrust for hover, and slower cruise speed using the same motor. There's no free ride, you'll have to find a balance that meets your purpose. A 24x6 prop will be too large for a motor that usually spins a 12x6 prop, you would have to change to a larger motor.
Since you're tilting your wing, blocking the thrust wouldn't be too much of an issue, I think 12" prop should be close to what you need. |
Bay Area, CA
Joined Sep 2007
v22chap,
I don't doubt your experience at all. I've followed all your posts and studied them carefully and learnt a lot. I'm just a pair of fresh new eyes approaching the problem from a different perspective. I have a clear understanding of how real Osprey works and what my plane lacks and trying to substitute or come up with alternatives. maxvtol, My intention is not to use a 24 X 6 prop on a motor capable of 12 X 6. Quote:
Number crunching is good to get you in the ballpark, but you'll need to do some testing. Lot of props and motors have been tested in this forum. If you can be more specific in what you want to do (the weight you have to lift and forward speed for cruise flight), somebody may have already tested what you're looking for.
| Thread Tools | |
| Discussion twin engine VTOL ( tilt rotor ) | persianpatient | Coaxial Helicopters | 0 | May 02, 2008 03:18 AM |
| R/C Tilt-wing VTOL: has anybody ever actually done this? | Bill Glover | Electric Plane Talk | 21 | Jul 22, 2002 11:00 AM |
| Logo 10 and 4 servo, 90 degree CCPM | Fred Bronk | Electric Heli Talk | 17 | Dec 26, 2001 02:58 PM |
| 90 degree CCPM on Hitec Eclipse! | Jon h | Electric Heli Talk | 2 | Nov 24, 2001 09:02 AM |
| TX with 90 degree ccpm? | rcastab | Electric Heli Talk | 26 | Jul 23, 2001 09:41 PM |
