Old Nov 15, 2012, 07:12 PM
Tankogen is offline
Find More Posts by Tankogen
Tankogen's Avatar
USA, AZ
Joined Jun 2010
UPDATE-
Full flight 24minutes recording successful. Yesterdays Ground tests showed differences in the issue so HD 30 FPS today I switched to as did during test. It worked, but we all want our 60fps. So it must be that Quality of SD memory card matters much. Next time trying 60fps again, then also maybe it needs to record 1st 30fps a tad then switch to 60fps after a bit already within one power sitting/session. Flukes quarks
Tankogen is offline Find More Posts by Tankogen
Old Dec 08, 2012, 10:19 AM
Tankogen is offline
Tankogen's Avatar
USA, AZ
Joined Jun 2010
I really wish HAD a longer Data ribon cable then 5 inches
http://www.digikey.com/scripts/DkSea...=HFF-26U-06-ND
anyone Please help!
Old Mar 02, 2014, 09:08 PM
Tankogen is offline
Tankogen's Avatar
USA, AZ
Joined Jun 2010
Bump still using aiptek cameras I have a dv8800 records and wondering if ok to power off of five volts. Internal battery is 3.7 lithium ion rechargeable. Similar to aiptek hd cam Will five
Volts. Be safe ?
Old Mar 12, 2014, 01:37 AM
beladog is offline
Find More Posts by beladog
I Crash Therefore I Buy
beladog's Avatar
United States, CA, Del Mar
Joined Oct 2008
Hey.
I've toasted multiple cams with 5v.
Seems some are ok with it and some no.
4.2V all day long no prob.
beladog is offline Find More Posts by beladog
Latest blog entry: Speeeeeder
Old Mar 12, 2014, 01:41 AM
beladog is offline
beladog's Avatar
Joined Oct 2008
Old Mar 12, 2014, 02:30 AM
Tankogen is offline
Tankogen's Avatar
USA, AZ
Joined Jun 2010
Thanks. Well I have aipteks hd run of five volts all the time on couple planes no issues for all the times used. So thought dv 8800 will too.
Old Mar 12, 2014, 03:09 AM
Tankogen is offline
Tankogen's Avatar
USA, AZ
Joined Jun 2010
Hope I didn't already fry it. Will use three AA nimh2200 rechargables then.
Old Mar 12, 2014, 10:01 PM
beladog is offline
beladog's Avatar
Joined Oct 2008
They use different regulators. Some of the DVs were really sensitive. All the "Action" series cams are ok with 5V. All the "A-HD" seem stable.
I may have an "any volt micro" from Dimension that would suit you well.
I've buried those in a few cameras I was concerned about. They run all day long and don't get hot with the low amp draw.
Old Mar 19, 2014, 09:37 PM
Tankogen is offline
Tankogen's Avatar
USA, AZ
Joined Jun 2010
I'll go ahead and use a dimensions engineering adjustable volt regulator I only have one right now I have to shuffle between couple devices at the moment I'm also trying to figure out if I can run a transmitter that uses eight AA batteries off 12.6 or a three cell Lipo any suggestions ? Thanks
Discussion Need help with Aiptek wiring harness for FPV & flight recording MinneFlyer FPV Talk 5 Oct 08, 2008 11:53 PM
Question Aiptek A-HD 720P for FPV? anci3nt FPV Talk 17 Mar 02, 2008 02:23 AM
Cool Off topic use for my new Aiptek English Electric SCRAPS (Southern Counties Radio-control Aerial Photographers) 3 Oct 03, 2006 04:39 PM
