Old Jul 09, 2009, 04:43 PM
Patscherpofel is offline
Find More Posts by Patscherpofel
Patscherpofel's Avatar
Patsch, Austria
Joined Jul 2007
Originally Posted by Rockboy_Pascal
Pathscherpofel, do you fly with the aiptek c100 on your plane? Do you have any video's you can show me:P?
nothing special...just some tests so far
check some videos on my vimeo site
you can also download the original if you are a member
random shots on the home field (2 min 51 sec)
Patscherpofel is offline Find More Posts by Patscherpofel
Old Jul 14, 2009, 11:06 PM
ch1 is offline
ch1
Find More Posts by ch1
ch1
Gainesville VA
Joined Dec 2007
How do you guys fly with this camera (Aiptek A-HD+). I tried it today and, yes very nice video (color and resolution) but the field of view (FOV) is very narrow and on an Easystar it bounces around quit a bit unless its dead calm. Another added it feature I got was the frame rate decided to drop half way in the middle of a flight (no fun). Any mods to improve the FOV and not have the frame rate drop?
Need to stick with FPV funjets (Easier to fly)
thx
ch1
ch1 is offline Find More Posts by ch1
Old Jul 17, 2009, 08:33 AM
Rockboy_Pascal is offline
Find More Posts by Rockboy_Pascal
Joined Feb 2009
http://www.vimeo.com/4481498
mmm, this looks much better, maybe becuase its compressed to a smaller resolution but still I dont understand the blurry images on my television. Even If I playback the recorder video on the camera self, it seem way better.
Rockboy_Pascal is offline Find More Posts by Rockboy_Pascal
Old Jul 20, 2009, 09:53 AM
Joined Feb 2009
Hey
The aiptek c100 has a little delay when playing it on my portable dvd player(a/v) but when I use it as a webcam on my computer, it doesnt. Is there any way how I can fix the delay between the camera-transmitter to receiver-portable dvd player?
Old Jul 22, 2009, 10:53 PM
FPVExtremer is offline
Find More Posts by FPVExtremer
Putting FPV to Business
FPVExtremer's Avatar
Joined Jul 2009
Subscribed, this is one interesting thread here.
Cheers,
Ernani
FPVExtremer is offline Find More Posts by FPVExtremer
Old Jul 22, 2009, 11:06 PM
philthyy is online now
Find More Posts by philthyy
UAV Integrations
United States, WA, Battle Ground
Joined Nov 2005
I have the Aiptek 720p and wanted to try it with my RV 900mhz 500mw system. So I cut off the yellow RCA and stripped it back on the included cord that you use for video out and hooked up the yellow to the yellow on the vtx and the outer shielding wire to the ground(black, shared by the 3s lipo to power the vtx) and when I powered it up, the camera started blinking(the green light on the camera) and the lcd screen just flashed off and on. It was ruined. What did I do wrong?
philthyy is online now Find More Posts by philthyy
Old Jul 22, 2009, 11:18 PM
Joined Jul 2009
So sad to hear that, and my knowledge on electronics are still very low to try to identify what may have caused this, but it could be something related to a current consumption overhead or a lower one, it could be a lower voltage or higher voltage issue, it could be a dc versus ac input, not exactly sure, but I am sure that someone else here knows better than me about it.
Cheers,
Ernani
Old Jul 22, 2009, 11:45 PM
scrape is offline
Find More Posts by scrape
Joined Mar 2006
I had to take the battery out of mine and put back in to get it working.
scrape is offline Find More Posts by scrape
Old Jul 22, 2009, 11:53 PM
Wobby is offline
Find More Posts by Wobby
Closed Account
Joined May 2007
Nothing wrong, no damage done i am sure, there is no voltage going to camera from your AV lead, you have done correctly..
Take the batery out of the camera as Scrape suggest (they crash every now and then), pop it back in, turn camera on with nothing connected.
Now power up your Video Tx, and now try connecting the AV .
The screen will BLINK OFF, but should show a menu to enable you to select AV-OUT.
You may not see this, but if you press the toggle donward one press, then press the toggle IN to select, you should see the live video now through your video reciever.
cheers
Wobby is offline Find More Posts by Wobby
Old Jul 24, 2009, 07:46 AM
Jack_LaLanne is offline
Find More Posts by Jack_LaLanne
Jack_LaLanne's Avatar
Germany, Berlin
Joined Feb 2009
guys I just tried finding the post where it says how to make the aiptek power on without display unit(power button)/magnet. I want it to power on once supply voltage is present. it's a pita to use the magnet. somebody knows where it is?
edit: -
Jack_LaLanne is offline Find More Posts by Jack_LaLanne
Old Jul 24, 2009, 07:55 AM
Gussy is offline
Find More Posts by Gussy
Does it fly?
Gussy's Avatar
Melbourne, Australia
Joined May 2007
See here:
http://www.rcgroups.com/forums/attac...mentid=2111800
The small SOT-23 part with the silkscreen box around it with the text 01 is the sensor which you need to fool/fix.
To fool it just glue a magnet on it, or you can fix it electronically if you like, but that's a bit more complex.
Good luck
Gussy is offline Find More Posts by Gussy
Old Jul 24, 2009, 08:26 AM
Germany, Berlin
Joined Feb 2009
thanks for the quick help. how to fix it electronically? I already removed the flash parts and everything
Old Jul 24, 2009, 08:43 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Originally Posted by Wobby
...The Toshiba Camileo Sander links too, would be similar to the AHD 700 or GVS, with the difference being the Toshiba has a CCD instead of CMOS....
Nope, 5M CMOS too
http://uk.computers.toshiba-europe.c...0_pressrelease
renatoa is online now Find More Posts by renatoa
Old Jul 24, 2009, 08:45 AM
Joined Sep 2007
Originally Posted by Gussy
The PCB's are being made, I should have them soon!!
One month... how soon ?
Old Jul 24, 2009, 09:23 AM
Germany, Berlin
Joined Feb 2009
now I have a different problem:
I wanted to get rid of the bulky A/V out connector so I soldered video and ground from the transmitter on top of the connector (first conductor ground, second conductor video). now when I plugin the tx, the ahd does not detect the A/V out connector presence and does not ask to activate A/V out.
How does the camera detect the presence of the A/V out connector?
edit: I thought the cam checks for resistance on the A/V line or so. but when you only plugin the normal connector with all wires cut off, the detection still takes place. maybe the detection is the connector shorting video/ground on plugin?
edit2:
SOLVED
the connector detection on the 3,5mm A/V output jack on the aiptek AHD is realized mechanically.
if you solder the wires directly to the board/connector you can put something of same diameter as original connector into the jack in order to maintain A/V out state. I used screw with shrinkwrap.
Discussion Need help with Aiptek wiring harness for FPV & flight recording MinneFlyer FPV Talk 5 Oct 08, 2008 11:53 PM
Question Aiptek A-HD 720P for FPV? anci3nt FPV Talk 17 Mar 02, 2008 02:23 AM
Cool Off topic use for my new Aiptek English Electric SCRAPS (Southern Counties Radio-control Aerial Photographers) 3 Oct 03, 2006 04:39 PM
