Espritmodel.com Heli Air
Old Mar 25, 2009, 12:00 PM
Romania, Dolj, Craiova
Joined Sep 2007
This effect is not related to CCD vs CMOS, is due to missing of the so called hot mirror, an InfraRed filter.
http://en.wikipedia.org/wiki/Hot_mirror
Usualy in normal cameras it is placed on sensor, as a thin protection layer made from lithium niobate: http://en.wikipedia.org/wiki/Lithium_niobate.
For such small cameras it is in the lens, probably for costs reason.
You can easily recognize the lens having embedded such filter if you look the rear lens at an angle and see red reflections.
BTW, the CCDkiller is called so because it is a CMOS camera and Aiptek too is CMOS.
renatoa is offline Find More Posts by renatoa
Latest blog entry: JRSky - birth of a dream radio
Old Mar 25, 2009, 04:38 PM
acristobal's Avatar
Spain
Joined Oct 2006
Thatīs why I am asking for Lens with that filter
acristobal is offline Find More Posts by acristobal
Old Mar 26, 2009, 04:46 AM
Joined Mar 2009
the (secret) connector
Hey guys...I think this is the same (secret) connector as used in AHD+...
I got shot twice and had to jump off a building to get this so I hope its the one or have to go back in..but im a worrior, and will keep tryin
http://www.4uconnector.com
jabvat is offline Find More Posts by jabvat
Old Mar 26, 2009, 04:51 AM
Does it fly?
Gussy's Avatar
Melbourne, Australia
Joined May 2007
That's already been posted
Gussy is offline Find More Posts by Gussy
Old Mar 26, 2009, 05:20 AM
Joined Mar 2009
(secret) connector - male
http://www.4uconnector.com/
Old Mar 26, 2009, 05:24 AM
Joined Mar 2009
really..sorry..thought I found it...I dont wanna mess with the board, I want to find thisss thing!.. they had to get it from somewhere, lets bribe that guy somebody said is out there that worked for aiptek
Old Mar 30, 2009, 02:10 AM
Pepelatz's Avatar
Staten Island, NY, USA
Joined Aug 2006
Powering Aiptek A-HD+
I'm stripping down my Aiptek A-HD+ and I'd like to avoid usind an USB connector to power it. Can I feed 5v from RVOSD directly to battery terminals or I will fry it? Has anybody tried this? Those terminals are the only large enough to solder to with my limited skills, but the battery is only 3.7v.
Ro
Pepelatz is offline Find More Posts by Pepelatz
Old Mar 30, 2009, 02:24 AM
Does it fly?
Gussy's Avatar
Joined May 2007
Ro
Feed it to the USB connectors solder joints, it wants 5v, where as the battery terminals want 3.7v.
Old Mar 30, 2009, 10:26 AM
Pepelatz's Avatar
Joined Aug 2006
Thanks, Gussy, but USB solder joints are too small for me to solder to, this is out of question. If I only had such skills!
Anybody else?
Ro
Old Mar 30, 2009, 11:35 AM
mmormota's Avatar
Budapest
Joined Jul 2003
Anybody else?
Ro
Connect the usb cable, cut it and solder the wires...
mmormota is offline Find More Posts by mmormota
Old Mar 30, 2009, 01:37 PM
Pepelatz's Avatar
Joined Aug 2006
Aiptek will not go to recording mode when powered from USB connector.
So, my question to electronics gurus: is there an easy way to drop 5v from RVOSD to 3.7v to feed battery terminals? Or can they take 5v without smoke? Has anybody tried this?
Ro
Old Mar 30, 2009, 02:01 PM
Torrance
Joined Feb 2005
I have the Aiptek mounted on my AP Swift Heli, and it works great, but I would like to find a 90 degree video jack for the video feed to my tx. If I can get a 90 degree jack it will put less tension on the video out jack connector durring pan and tilt.
JustinONE is offline Find More Posts by JustinONE
Old Mar 30, 2009, 02:56 PM
tychoc's Avatar
Austin, TX
Joined Feb 2006
Ro
Try this: http://www.dimensionengineering.com/DE-SWADJ.htm
-tychoc
tychoc is offline Find More Posts by tychoc
Old Mar 31, 2009, 01:16 AM
Joined Sep 2007
When the main goal is to see more ground than sky, I found very uneffective to place the Aiptek in the canopy in normal position, with lens up.
I am thinking to place it upsidedown, cut a hole in the belly, build a wall around lens opening (or a small dome) it to protect at landing, and reverse the goggles accordingly, to see normal.
What do you think about this approach, would it be effective?
Old Mar 31, 2009, 01:24 AM
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Sounds like it could work.
What plane are you putting it in?
galaxiex is offline Find More Posts by galaxiex
Discussion Need help with Aiptek wiring harness for FPV & flight recording MinneFlyer Video Piloting (FPV/RPV) 5 Oct 08, 2008 11:53 PM
Question Aiptek A-HD 720P for FPV? anci3nt Video Piloting (FPV/RPV) 17 Mar 02, 2008 02:23 AM
Cool Off topic use for my new Aiptek English Electric SCRAPS (Southern Counties Radio-control Aerial Photographers) 3 Oct 03, 2006 04:39 PM
